I have seen alot of negative posts here on BITOG toward the filtering ability of K&N compared to paper. I recently started a post under General Oil Topics in which I asked for the one single item between oil, oil filter, and air filter that is the most important toward wear in an engine. The airfilter was chosen by the vast majority of people. With this being said, can anyone show proof with lab reports or other data that could prove K&N filters show higher wear numbers. For example higher Si levels with a K&N compared to paper.
For the record, I have done two samples on my 2001 Civic and there was no difference in numbers between a Denso paper filter and a replacement K&N. However, I clean and reoil my K&N every 15K.
