Abnormal Styling ?
by HTSS_TR
05/06/16 07:22 PM
It's that time again.... Ford front-end stuff
by OVERKILL
05/06/16 07:03 PM
Addicts using anti-diarrhea medication to get high
by Mr Nice
05/06/16 06:36 PM
PureOne PL24011 cut open
by AuthorEditor
05/06/16 06:21 PM
Hidden gem for ex-K&N Filter users
by Reddy45
05/06/16 05:54 PM
Chemical Guys Car Wash 1 Gal $13 Amazon
by gallydif
05/06/16 05:43 PM
2006 Charger - rack getting replaced
by OVERKILL
05/06/16 05:38 PM
A Story Worth Living
by LoneRanger
05/06/16 05:37 PM
Snake Oil Detergent - 0.37 Cents
by Greg L
05/06/16 04:35 PM
Wax for silver car
by 007
05/06/16 04:32 PM
Trump's empty picture frames
by SumpChump
05/06/16 04:05 PM
Is 0w40 slightly Thicker than 5w30?
by Greg L
05/06/16 03:53 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
86 registered (aquariuscsm, Astro_Guy, 2015_PSD, Al, 137_Trenton, 9 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248563 Topics
#743029 - 10/08/06 09:10 AM Ball Joints will not accept grease
iceberg Offline
Loc: Michigan
I had some new ball joints installed on my 2000 Jimmy and the upper on the passenger side will not accept any grease. Has anyone ever had this happen in it just a defective ball joint?
#743030 - 10/08/06 09:14 AM Re: Ball Joints will not accept grease [Re: iceberg]
TheTanSedan Offline
Loc: Corpus Christi, Texas
I've used a finishing nail to carefully try to poke one open before. Just slightly frozen. But this was an old vehicle, more than 20 years.
2004.0 DODGE RAM 2500 QC LB Cummins 555 SRW NV-5600
14-cpm fuel cost last 37k miles
#743031 - 10/08/06 09:35 AM Re: Ball Joints will not accept grease [Re: TheTanSedan]
Dark Jedi Offline
Loc: virginia
zerk fitting bad? bad ________?
#743032 - 10/08/06 09:43 AM Re: Ball Joints will not accept grease [Re: Dark Jedi]
AcuraTech Offline
Loc: St. Paul, MN
Find a needle fitting for the grease gun. Just poke the boot with it and shoot some grease in. The hole is so small that grease will not leak out.
*The above post is not to be construed as professional advice. For entertainment purposes only.*
#743033 - 10/09/06 06:18 AM Re: Ball Joints will not accept grease [Re: AcuraTech]
alreadygone Offline
Loc: North Arkansas
DON'T PUNCTURE THE BOOT!!!!! Replace grease fitting first, take it back to shop that installed for fix second. Grease in boot is what is replaced when greasing. Will never go back into bearing surface.
Bob
To which version of reality would you like to convert me?
Bob
#743034 - 10/09/06 04:43 PM Re: Ball Joints will not accept grease [Re: alreadygone]
michaelc80 Offline
Loc: Central Iowa
I assume it has a zerk and is not the maintenance free type? If so, simply replace the zerk with a 59 cent new one.
#743035 - 10/10/06 04:11 AM Re: Ball Joints will not accept grease [Re: michaelc80]
iceberg Offline
Loc: Michigan
Shop put in a new one I went to put in a new zerk and the top of the ball joint just "spun" and the zerk would not come out.
#743036 - 10/10/06 05:03 AM Re: Ball Joints will not accept grease [Re: iceberg]
eljefino Offline
Loc: ME
are you talking about the taper that goes through your steering knuckle? That taper should not spin, ever. The tension of the castle nut should jam the taper in very tight.
I'm having a hard time picturing your issue, as my zerks have all been tapped into the "stationary" part of the ball joint or tie rod end.
#743037 - 10/10/06 06:10 AM Re: Ball Joints will not accept grease [Re: eljefino]
alreadygone Offline
Loc: North Arkansas
I thought they were only on MOPAR, but some ________'s are built with moving outer bearing surface(socket) the ball is the inner bearing surface. Try using a tiny pair of Vice Grips to hold part that zerk screws into, or wedge a small tipped screwdriver in gap to keep it from turning while zerk is removed.
Anyone who doesn't understand above needs to go to MOOG or TRW site and find cutaway view of ball joint. MOOG is especially proud of their "Problem Solver"tm. ball and socket line.
iceberg,
Have you consulted shop that did repair? I'd expect they would want to clear any issue instead of loosing a future customer.
Bob
Bob
#743038 - 10/10/06 06:14 AM Re: Ball Joints will not accept grease [Re: alreadygone]
alreadygone Offline
Loc: North Arkansas
Blank out in above post is where I used initials only for Ball Joint. Censor program must a thought I was refering to oral,,, oh well that't probably get blanked also!
Bob
Bob
#743039 - 10/10/06 08:05 AM Re: Ball Joints will not accept grease [Re: alreadygone]
iceberg Offline
Loc: Michigan
They replaced it with another. The metal cap that the zerk goes into was spinning when trying to remove the zerk fitting.
#743040 - 10/11/06 02:28 AM Re: Ball Joints will not accept grease [Re: iceberg]
another Todd Offline
Loc: Southern CA
So does it accept grease now? If not try taking the weight off the suspension ie jack that wheel off the ground. It might need to be unloaded to accept grease. good luck
2015 Ford F250 Diesel Crew Cab FX4
(2)2005 Ford Focus ZX4, and ZX5
2005 Ford Escape
2006 Ford Escape
#743041 - 10/12/06 07:09 AM Re: Ball Joints will not accept grease [Re: another Todd]
TheTanSedan Offline
And buy some plastic snap-caps with retainer ring to fit over afterwards. I found them at a motorcycle supplier.
#743042 - 10/20/06 07:52 AM Re: Ball Joints will not accept grease [Re: TheTanSedan]
ewetho Offline
Loc: Kankakee, IL
Sounds like you need another balljoint that is not falling apart.
2004 Neon SE 2.0L Current Fill
Motorcraft 5W-30, Motorcraft FL-300
#743043 - 10/20/06 10:46 PM Re: Ball Joints will not accept grease [Re: ewetho]
iceberg Offline
Loc: Michigan
Yes the new one accepts grease just fine. It was a defective ball joint.
