'91 Mazda B2600i transfer case and trans oil?
by Jason280
46 minutes 9 seconds ago
How to cut power to breaker box ?
by Merkava_4
Today at 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
Today at 01:07 AM
OK, before I lube it ...
by BrocLuno
Today at 12:53 AM
Toyota Japan Fluid SDS
by SXE10
Yesterday at 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
Yesterday at 11:25 PM
Considering a differential swap
by buck91
Yesterday at 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
Yesterday at 09:51 PM
Car Acronyms
by Marco620
Yesterday at 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
Yesterday at 09:41 PM
Carpet cleaning methods.
by Run
Yesterday at 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
31 registered (Char Baby, Atesz792, b1amgm47, 1foxracing, crainholio, 4 invisible), 732 Guests and 13 Spiders online.
58295 Members
66 Forums
250918 Topics
Page 1 of 2 1 2 >
#70887 - 02/26/04 02:16 PM Mobil 1 0w-40
Toyota18 Offline
Loc: Sydney
Hi.
I live in sydney Australia and my car is 2001 year model 2.2L toyota camry.Done 32000kms.Summer in sydney is very hot but not all the time, some days it can be go up to 42c' normally 28-38c' in winter 2-10c' but it can go down to 0c' in some mornings. Can i use 0w-40 grade engine oil as a year round oil? Such as mobil 1 0w-40? owners manual say above 0c' 10w-30, 15w-40 or 20w-50 and below 0c' 5w-30 doesn't say any thing about 0w grade. Toyota Australia recomended 20w-50 year round use.If i use 0w-40 will my engine damage? or shorten the life?
Thank you.
Prasanna.
#70888 - 02/26/04 07:37 PM Re: Mobil 1 0w-40
Eiron Offline
Loc: Loveland, Colorado
Since the recommendation is for a conventional oil & you're considering a fully synthetic PAO oil, you'll have more protection than what's required. I'm using the 0W-40 year-round here (0F - 100F) but will switch to their new 5W-40 in my turbo engine. In your temp range, you'll probably find the M1 15W-50 does great year-round for you as well (if it never got below 0C here I'd use this grade exclusively).
#70889 - 02/27/04 08:25 AM Re: Mobil 1 0w-40
Jeffrey Behr Offline
Loc: Phoenix, AZ USA
Prasanna, I believe you do NOT need a 0-vis. oil. Those are designed to flow at VERY low temperatures which you don't experience. Also, they contain viscosity-index improvers* that are best left unneeded. If you like M1, use the 5W-40 or the 15w-50. All will protect your engine better at the high temps you have.
*--or at least more of them than the narrower-range oils do.
#70890 - 02/26/04 09:46 PM Re: Mobil 1 0w-40
Nosmo King Offline
Loc: 98281
I use Mobil 1 0w-40 oil and love it.
However I do not live in your lovely warm country.
If I did I would use Mobi1 1 15w-50.
#70891 - 02/27/04 12:24 AM Re: Mobil 1 0w-40
Mobil 1 0W-40 is fine engine oil and is particularly well suited to vehicles living anywhere in Canada. I'm currently using it in my Porsche Cayenne Turbo. Its approved viscosities in my mild-temperature region* are 0W-40, 5W-40, and 5W-50, and Porsche LOVES M1. The 0W-40 is the ony one I can find locally, so that's what I'm using. However, I have a couple cases of Red Line 5W-40 on the way and will be changing soon.
Recognising the viscosities recommended by your importer, I'd go with M1 15W-50.
*--the Arizona desert, which sounds similar to your Australian weather.
#70892 - 02/27/04 12:27 AM Re: Mobil 1 0w-40
williar Offline
Loc: Eastern Idaho, south of West Y...
Mobil1 0w40 will perform quite well at those temperatures and is an excellent year-round oil for any climate. Don't let the low winter weight fool you; this oil is not just for cold climates.
I think you'd find 15w50 too heavy for wintertime use although it would be fine in the summer.
#70893 - 02/27/04 12:57 AM Re: Mobil 1 0w-40
DEWFPO Offline
Loc: High in the Rockies
I live in an area that goes down to the -teens F in the winter and I drive it in areas of 100+F in the summer. I use M1 0w-40 year round.
DEWFPO
#70894 - 02/27/04 04:04 AM Re: Mobil 1 0w-40
heyjay Offline
Loc: Manitoba Canada
quote:
Originally posted by Toyota18:
Hi.
Thank you.
Prasanna.
Hello Prasanna:
How fascninating that for your 2001 Camry Toyota of Australia recommends a 20W-50 year round, but here in North America a 5W-30 year round.
I doubt you will have a cold-flow problem with a 20W-50 or a 15W-50 at 0 C. Where I live, it can get down to -42, so cold flow is a VERY big deal.
If you want to use a full synthetic, Mobil of Australia offers Mobil 1 5W-50, why not try that?
Jerry
#70895 - 02/29/04 03:39 AM Re: Mobil 1 0w-40
sprintman Offline
Loc: Canberra ACT Australia
Toyota18 as an ex M1 0W40 user I have another thought. Buy a 20-litre drum of BP visco 5000 5W40 (13.95 cSt @ 100C) from your local BP distributor for under A$120. PAO basestock and ZDDP anti-wear that performs brilliantly on my mate Rons Timken. Best buy in oil available here in Oz IMO. M1 5W50 is over double the price.
#70896 - 02/29/04 09:30 AM Re: Mobil 1 0w-40
Sin City Offline
Loc: Las Vegas, NV
I think either Mobil 1 0W-40 or 5W-50 will work very well all year in your climate. You will of course get slightly better fuel economy with M1 0W-40. Delvac 1 5W-40 is probably an even better choice if you can find it. I would not use Mobil 1 15W-50 as it is too thick and you will waste fuel and not get any additional benefit in my humble opinion.
[ March 01, 2004, 01:35 AM: Message edited by: Sin City ]
#70897 - 02/29/04 09:44 AM Re: Mobil 1 0w-40
sprintman Offline
D1 is nearly double the price of Visco 5000 here even if purchased in a 20-litre drum. Hard to justify IMO. Good oil though.
#70898 - 02/29/04 06:56 PM Re: Mobil 1 0w-40
heyjay Offline
quote:
I purchased new a 1990 Toyota 4Runner with 3.0 V6. From new I ran Mobil Delvac 1 5W-40, as I have pails of the oil in my shop for my fleet.
When I moved to Salt Lake City, Utah, I switched to Mobil 1 15W-50, which I used year round. At the time, Mobil claimed the 15W-50 was safe down to -30 C / -20 F.
A lot of folks claimed I was wasting a huge amount of fuel by running so heavy an oil. I tried a short OCI with Mobil 1 5W-30.
Want to know how much fuel economy I gained?
Zero. Zip. Zilch. Nada.
Under the same high-speed Interstate driving conditions at high elevations, my 3.0 got the same fuel economy whether running the 5W-30 or the 15W-50. Except for one and only one short trip that I got around 0.25 MPG more, and I can't explain why I got that slight increase.
Most tests for claimed fuel economy "benefits" have uncovered a 1-3% max increase in fuel economy. In most driving, that would be statistically irrelevant.
FWIW: my official Toyota shop manual was obviously made in Japan, based on the grammer and typos. The shop manual recommended a 5W-30 cutoff of +50 F / +10 C, where the owner manual, made in Canada, recommended using 5W-30 up to +30 C.
So this isn't the first time we have seen such a glaring contradiction in what viscosity of oil to use here in North America and in the "rest" of the world.
BTW: BP recommends their "Visco 7000" 0W-40 in the Corvette sold in Europe. Here in North America, Chevy recommends Mobil 1 5W-30 year round. Why??
This BP Visco sounds like good oil for Oz, and it also sounds a LOT more reasonable than Mobil products.
Jerry
#70899 - 03/01/04 08:01 AM Re: Mobil 1 0w-40
toyvwbenz Offline
Loc: Ooooooooklahoma
I agree with you heyjay. No relevent difference in fuel economy using different grades of oil. Also, no mpg difference alternating between dino and synthetic. I think these mpg improvement claims are just bunk. Many other factors have a MUCH more significant affect on fuel economy.
#70900 - 02/29/04 11:53 PM Re: Mobil 1 0w-40
DEWFPO Offline
Heyjay, why did you switch from 5w-40 to 15-50 when you moved to SLC?
DEWFPO
#70901 - 03/01/04 03:25 AM Re: Mobil 1 0w-40
sprintman Offline
BP Visco 7000 0W40 and Castrol Formula R 0W40 are one and the same.
Page 1 of 2 1 2 >
