HF shears
by Donald
05/24/13 11:19 AM
Brad Penn 15w40 - $3.53 per Quart
by Greg L
05/24/13 11:14 AM
Rotella Straight 40? Cheap at $18.09
by Greg L
05/24/13 11:09 AM
Amazon Deal - Valvoline VR1
by Greg L
05/24/13 11:00 AM
Looking To Book Hotel Near Disney 6/22 - 6/26
by crazyoildude
05/24/13 10:46 AM
556 XM193 Ammo and 115gr 9mm Remanufactured Ammo
by plrprecision
05/24/13 10:38 AM
Mobil 1 5qt $22.47 @ Walmart store pickup
by lemonade
05/24/13 10:18 AM
rough shifting with new fluid after spirited drive
by pickler
05/24/13 09:20 AM
P304 is very random - trim questions
by urdrwho
05/24/13 08:25 AM
Propane torch question
by GreeCguy
05/24/13 08:05 AM
AMSOIL AND MAXIMA ULTRA UOA COMPARO
by DockingPilot
05/24/13 08:02 AM
Ten year old propane bottles
by GreeCguy
05/24/13 07:59 AM
Biggles, mahler206, VintageMonte, runnerbl, slush
45538 Registered Users
114 registered (AlaskaMike, 99Saturn, 67King, 1345, 97f150, 190E26FTW, 7 invisible), 1701 Guests and 244 Spiders online.
45538 Members
64 Forums
193869 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#641232 - 04/19/05 09:52 AM 20W50 vs. 15W40
GreeCguy Offline
Loc: Elderly County, Florida
Good afternoon fellow oilers:
Other than the weight, (and price), what is the difference between 20W50 and 15W40?
Thanks for the imput!
#641233 - 04/18/05 10:00 PM Re: 20W50 vs. 15W40
wavinwayne Offline
Loc: North Alabama
AFAIK,
15w40 is primarily marketed/formualted for HD diesel engines, while 20w50 is aimed at the gas-powered crowd. [I dont know]
#641234 - 04/19/05 01:23 AM Re: 20W50 vs. 15W40
JohnBrowning Offline
Loc: USA
A 15W40 is going to have a much better aditive package and will more then likely be less volitile! 15W40's usualy are shear stable were most 20W50 shear badly some down to a 30Wt.! If you want a good 15W40 Delo 400 and Delvac 1300 are the easiest to find and have excellent formulas. If you can find them in their CI+4 form they are even better! 15W40 has better performance in it's dino form at both hot and cold extremes then most dino 20W50's!
#641235 - 04/19/05 08:31 AM Re: 20W50 vs. 15W40
bulwnkl Offline
Loc: Arizona
Bear in mind that, although I am a big fan of the all-fleet oils (Delo, Rotella, Delvac, etc), they are generally not recommended for use in strictly gasoline-powered fleets because they have a greater tendency to foul spark plugs. I believe this is due to their much higher DD additive levels. Most 20W50 oils would not be susceptible to this issue. In my experience, most 15W40s will not cause troubles either, but if you start fouling plugs more quickly/frequently, go back to a 20W50.
For my part, I have not experienced 20W50 shear-down.
#641236 - 04/19/05 08:48 AM Re: 20W50 vs. 15W40
TallPaul Online   confused
Loc: By Detroit
quote:
I don't know why 20w50 gets such a bad sheering rap. The amount of viscosity index improver in it should be similar to that of a 10w30 and therefore (if that is true) the 20w50 should be more sheer stable than a 5w30 or 10w40.
#641237 - 04/20/05 01:22 AM Re: 20W50 vs. 15W40
JeepZJ4.0 Offline
Loc: Katy, Texas
This is news to me... My Jeep doesn't burn oil though. I'm using Delvac 1/M1 T&S
