Saved a puppy
by barkingspider
08/24/16 10:39 PM
Slick 50
by CrackyWainwright
08/24/16 09:28 PM
Bmw twin power 5w30
by BTLew81
08/24/16 09:08 PM
Older car but low mileage. Change or not?
by Martin10
08/24/16 08:07 PM
F1 - 2016 Belgian Grand Prix
by gofast182
08/24/16 07:55 PM
Ethernet card uograde needed?
by NHHEMI
08/24/16 07:27 PM
2012 Suzuki DL1000 VStrom Oil Recommendations
by RHALL
08/24/16 07:24 PM
Audio/Micro Adapter Help
by coopns
08/24/16 07:18 PM
Purolator boss 2222 6,200 miles
by gabriel9766
08/24/16 06:49 PM
Fram Ultra paint peeling
by Run
08/24/16 06:26 PM
Cell phone mount suction cup doesn't stick
by mclasser
08/24/16 06:02 PM
2008 Nissa Versa 110,000 miles second report.
by Datarock
08/24/16 05:07 PM
ShadowSix, warfire, Brutus232, gojoneeded, jimmyangst
58911 Registered Users
56 registered (Americana, 79sunrunner, AZjeff, AntsinmyEyes, 29662, 5 invisible), 1242 Guests and 7 Spiders online.
58911 Members
66 Forums
253515 Topics
Page 1 of 2 1 2 >
#619471 - 07/13/05 09:21 AM '94 5.0 Mustang performance mods questions.
TallPaul Offline
Loc: By Detroit
My brother recently got a '94 5.0 Mustang with only 40,000 miles. It has a 5 speed stick and 2.73 rear end. He says it came with Flowmasters, K&N filter, and a Hypertech chip. He wants to increase the performance.
So here is the deal, bro is looking into a Powerdyne supercharger (likes that it does not have to tap the oil pan but is self lubricated). They have 6 lb and 9 lb boost options. It is the same unit, but different pulley sizes and the 9 lb comes with an upgraded fuel pump and chip for $400 more to get 105 to 110 more hp.. The 6 lb is suppose to use the stock pump and gets 75 to 80 more hp. Either one is supposed to work with the stock 19# injectors. He wonders which one to get and whether his chip is going to be ok with it. Car already had a hypertech chip when he got it. I was thinking the 6 pound boost would be best as he does not want to stress components too much and he always could upgrade by buying the fuel pump and other chip and pulley.
Now, not only his questions, but also how it all relates to Novadude and LT4Vette's advice quoted below from a previous discussion about this car.
So Novadude previously said:
quote:
Headers are a waste! Sure, the stock parts LOOK like they would really hurt flow, however, people with stock engines seldom see ANY gains by replacing them with aftermarket "shorty" headers. Longtubes are worth something.
Having messed with one of these cars for the past 4 years, here are the BEST bang-the-buck mods I would do if I was starting over. They are listed the order I'd do 'em.
1. Underdrive crank pulley. 75% of the gains of a full 3-pulley system with none of the headaches (charging system problems). Got mine through ASP for ~$40.
2. Gears. 2.73s are just too tall. 3.55s would make a HUGE difference in the "feel" of the car. Mine is an AODE car with 3.27s. IF he had an AODE, I'd say get a Torque converter before or instead of gears. My torque converter gave a better reduction in ET than any other single part I have added.
3. Tuning. 94/95 EECs have a lot of problems with the OEM calibration. Rumor has it that hypertech chips and the like make it worse! Look up a company called "SCT custom tuning". These are the guys that burned my chip, and it worked wonders to help eliminate the part throttle pinging. They also did lots of stuff on the chip to help the AODE work better, but that does not apply in your case.
4. Atfermarket H or X pipe. The OEM 4-cat pipe is the most restrictive part of the exhaust... not the headers, and not the catback. I am running a Magnaflow catted H-pipe (gotta keep the feds happy).
5. Intake manifold! Yes, that's right... intake manifold. The OEM GT lower intake is very restrictive. I am running a ported lower on mine with the stock upper manifold. Gave noticable SOTP gains. The Cobra or Edelbrock Performer manifolds would likely work even better.
6. Heads. Huge gains to be had from aftermarket cylinder heads.
After that, I would then start considering Headers, Throttle Bodies, and MAFs. Honestly, I do not feel that these parts are worth it on a stocker, as the heads and intake are the real bottlenecks.
Tell him NOT to waste his money on any of the Cold Air Intake kits... they are more hype than anything.
My 104k mile car went 14.49 @ 95.2 last November with nothing more than the following mods:
1. Pulley
2. H-pipe
3. Catback (FRPP)
4. Ported lower intake
5. 2600 rpm stall tq. converter
Everything else was 100% stock, including the airbox and paper filter.
Novadude also said, "The recipie posted by LT4 vette is a proven way to go... I'd start with the stuff I mentioned above, and work your way up to the full list in LT4's post." LT4Vette's "recipie":
quote:
Spend your $$$ on simple bolt-ons. I had an Off road H pipe, mufflers, Mac 1 5/8 headers, pullies, 3.55 gears, Cobra intake, bumped timing, Crane 1.7 roller rockers, adj FP regulator, K&N air filter and went 13.12 @ 102 MPH. I had a 1990 LX 5.0 and wished I didnt sell it.
Now I sent the above advice to him, but somehow he has gotten on to the supercharger idea. I would think the supercharger should more or less overcome all the intake inadequacies of the stock Mustang (though the upgrades may help some anyway), so the supercharger might be a pretty good idea, but (and this is a big but), since a supercharger boosts more with more RPM, would the stock 2.73 rear end not negate a sizeable chunk of the supercharger's benefits? So, I am inclined to think maybe he needs to get the rear end up to a 3:55. Now if he only did one thing (supercharger vs 3:55s) which would be the best overall upgrade?
Thanks
[ July 13, 2005, 12:35 PM: Message edited by: TallPaul ]
#619472 - 07/12/05 10:25 PM Re: '94 5.0 Mustang performance mods questions.
Ryan00TJ Offline
Loc: Lake Anna, VA
Aftermarket SC kits are sometimes hit and miss when it comes to daily driver reliability. Even at 6psi I don't think stock 19lb injectors and the stock fuel pump would be up to the task safely. Sure they might work but is it worth the motor to go cheap?
SC kit of your choice will need to address these issues. Injectors, Fuel Pump, and tuning is the most important. Blown applications require very good tuning or the motor will suffer. The Hypertech is far from up to the task. Your bro needs to have a custom chip burned along with a full on Wideband Dyno secession to work all things out.
Before I would go straight to a SC, I would open the exhaust and intake up.
Longtubes, mid pipe and catback along with a Cobra intake and 3.55s would be a good starting point before the SC. My friend has been doing mods to his 95 5.0 for awhile now and he's sitting at 363rwhp.
All boltons, mid headers, ported stock intake, blower cam, ported heads etc, Procharger @ 8psi.
His intake @ mid headers are hurting him as a H/C blown 5.0 should reach around 400rwhp.
#619473 - 07/12/05 11:16 PM Re: '94 5.0 Mustang performance mods questions.
novadude Offline
Loc: Shippensburg, PA
Ditto.
While I wouldn't run shorty headers with stock E7 heads and thier bottleneck exhaust ports, I agree that longtubes will increase power.
I have *heard* that Powerdyne stuff is junk. I don't know much about SC parts though, as I never had plans to go that way.
If you are asking which part will make the car faster, gears or SC, by all means choose the SC! Gears will make a SOTP improvement, but you won;t see much on the timeslip (a few 10ths). An SC will make a difference you can feel and measure, even with the 2.73 rear.
For a lot less money though, I'd go the 3.55/Cobra Manifold/Longtube route first if it were my car.
#619474 - 07/13/05 12:11 AM Re: '94 5.0 Mustang performance mods questions.
TallPaul Offline
Loc: By Detroit
So the blower is a good way to go, but have to do it right. Needs more research. Well, hey, anybody know a good blower for this car? Are there any with their own self contained lube oil that don't tap the engine oil pan?
Also, a car crafting accquaintance said:
quote:
Ford is no longer producing the Cobra manifold. He could get Ford's GT-40 intake manifold though, which is an upgrade from the Cobra.
#619475 - 07/13/05 12:27 AM Re: '94 5.0 Mustang performance mods questions.
Mr Nice Offline
Loc: Orlando, FL
Hello TallPaul,
If I was your brother, like I said before.....I would do the simple (and cheap) bolt ons first and then later if he has the $$$$ get an ATI intercooled Procharger. [Smile] I haven't heard anything bad about the Powerdyne, but I have seen some 5.0 Mustangs with bolts-ons & a Procharger that were mid 12's. Just remember that you will also need 24 Lb injectors and a 155 LPH fuel pump if you run any amount of boost.
3.55 gears are great for a street car and with a 5 speed Mustang, you will see a big difference....with an Auto trans Mustang, you won't see much. Since you brother's Mustang is 5 speed, he should be able to run 13.6 - 13.8's with bolt ons. I also had a Cobra intake, 1.7 roller rockers and an Adj FP reg and went low 13's.
The Cobra & GT 40 intake are 'almost the same thing. Super Ford magazine dyno'ed both intakes and there was only a 2 HP difference. The reason why I bought the Cobra intake, cause it was $180 cheaper. Supercharging is safe, but you can't go overboard with 12 PSI on a stock motor, thats how people blow head gaskets. [Cool]
#619476 - 07/13/05 01:09 AM Re: '94 5.0 Mustang performance mods questions.
Mr Nice Offline
Loc: Orlando, FL
The best place to buy used (cheap) Mustang parts is the Bargain Trader, next to the Auto Trader magazines. They always have tons of parts for sale.
#619477 - 07/13/05 04:54 AM Re: '94 5.0 Mustang performance mods questions.
DJ Offline
Loc: New London WI
Don't look at the kits considering the fuel pump, the fuel pump in his car is likely original and I would not trust a boosted engine to a 11 year old pump. As far as the limits of the engine you will probably be best to research that on a model specific site, I know some Mustangs came with forged pistons those would be more tolerant. The injectors they might get by with if they use an enrichment injector setup seperate from the stock fuel injectors.
Computer controlled cars can adaprt to a lot BUT getting the computer retuned is still a good idea to get the most out of your modifications, actually depending on cost for that application is it often a very good begining mod with the rest of the car basically stock.
#619478 - 07/13/05 09:27 AM Re: '94 5.0 Mustang performance mods questions.
jsharp Offline
Loc: Outside smalltown, IL
quote:
Originally posted by LT4 Vette:
Hello TallPaul,
With 3.55's and street tires what do you do with first gear? My '90 LX 5 speed with 3.08 gears is stock other than Flowmasters. With any street tires I've used on the street it has traction problems in 1st. You have to "drive it out" at about 1800 rpm and add trottle as traction allows. I can't imagine what it would be like with 3.55's.
Now if you were running a slick that was taller then stock on a surface that was sticky I could see it...
#619479 - 07/13/05 10:01 AM Re: '94 5.0 Mustang performance mods questions.
Mr Nice Offline
Loc: Orlando, FL
I had 255/40ZR17 Bridgestone RE 71 tires in the rear on 17x8" wheels, so the car hooked up pretty well, plus I am very near sea level (so my ET & MPH will be better than guys running in higher altitudes) [Smile]
If my car was on a DOT 'cheater' slicks or a super soft SCCA tire....then I would have been in the high 12's.
[Off Topic!] I have a math formula from a Hot Rod magazine that you will be able to get your HP as long as you know your car's Total weight (with driver) & your MPH at the strip.
#619480 - 07/13/05 10:13 AM Re: '94 5.0 Mustang performance mods questions.
jsharp Offline
The newer cars are better than my old one I know, since it's running on 15" wheels. Welcome to 1990. [Frown]
At the time, I ordered it intentionally with 3.08 gears to work with 225/50 X 15 tires for autocrossing. Given it was stock, I couldn't use larger wheels and any shorter gearing and first becomes useless with the short tires.
I've never taken my car to the strip, but I think you ran decent times for a car that's pretty stock. I think Patman used to have a Mustang too. Then all you guys went over to the dark side...
[Big Grin]
I'd be interested in the formulas you have. IM or email me if you think about it...
#619481 - 07/13/05 01:38 PM Re: '94 5.0 Mustang performance mods questions.
mechtech Offline
Loc: Chicago area
I would be REAl careful about using an aftermarket chip with a supercharger that it isn't programmed for. You probably will have way too much advance at boost, and will destroy engine parts.
You don't need good heads with a supercharger [yes, of course there will be some benefit].
A cold air intake [vs. hot underhood air] is very beneficial.
#619482 - 07/13/05 02:51 PM Re: '94 5.0 Mustang performance mods questions.
Patman Offline
Loc: Oakville, Ontario
FWIW, I had an 87 GT with an 8psi Paxton and I ran it for 4 years with no problems. I ran the stock injectors and the stock tune, and had the timing set to 10 degrees, but running a mix of race fuel all the time to keep detonation away.
With a race weight of just over 3000lbs, it's best ET was 12.16 at 112mph, with a 1.59 60ft (on slicks)
The engine was bone stock! I had 3.55 gears, Mac 1 5/8" unequal length shorty headers, hollowed out stock cats, and a 2.5" Mac exhaust with Dynomax mufflers.
It shocked me how well that car ran with no internal work on the engine at all.
#619483 - 07/13/05 04:43 PM Re: '94 5.0 Mustang performance mods questions.
TallPaul Offline
Loc: By Detroit
Thanks for all the input everybody. I think he is more interested in having some fun with it than actual drag racing and so the 3.55 may not be much of a priority. I think most of the advantage of a 3.55 is going to be out of the hole (if you can get traction). He says it can easily break em loose with the 2.73, so I guess the supercharger route would be good fun with the right components (injectors, pump, chip). The supercharger should overcome much of the poor intake and even exhaust. He can always add the intake and exhaust upgrades later. I would guess the 6 pound boost would be a safer bet, but he needs to research brands of supercharger for the best quality.
#619484 - 07/14/05 02:33 PM Re: '94 5.0 Mustang performance mods questions.
Patman Offline
Paul, when I went from 2.73s to 3.55s in my Mustang, the car was still stock, and it was much easier to launch with 3.55s than with 2.73s! I found with 2.73s the car would bog out of the hole, but with 3.55s you could launch just off idle and it wouldn't spin badly at all, even when the track wasn't hooking very well that day. I cut 3 tenths off my 60ft time with that one mod alone. Every 5.0 Mustang should come from the factory with 3.55s, it makes the engine feel 50hp stronger too, since it's way more responsive at all speeds with this ratio. So even if someone isn't into drag racing, this gear swap will give them an excellent bang for the buck.
#619485 - 07/15/05 04:05 AM Re: '94 5.0 Mustang performance mods questions.
Drew99GT Offline
Loc: Colorado Springs
Can't run a powertech chip with a blower on a mustang unless the chip is tuned for the blower. Powerdyne SUCKS!! Go Vortech or ATI. Another option would be Kenne Bell. A stock 5.0 with just a stock blower kit will perform well with an inline pump because the Ford ECUs are so tuner friendly. All the kits come with a fuel management unit, which basically closes of the fuel return line under boost and jacks up fuel pressure. Kind of a band aid but it works pretty good; especially on 5.0s.
Page 1 of 2 1 2 >
