Magnatec 5w30 - Push Mower
by SavagePatch
05/06/16 11:31 AM
RAM 1500 EcoDiesel filter
by pb379
05/06/16 09:14 AM
Motul 8100 X-Cess 5W/40 11,568Miles BMW335i
by strongmad
05/06/16 08:52 AM
Lawn Tractor Utility Upgrade
by bigdreama
05/06/16 08:50 AM
Help with iphone on the home network
by buck91
05/06/16 06:45 AM
2003 lesabre battery change back seat type
by snake123
05/06/16 05:43 AM
Penrite 0w-16
by toyota62
05/06/16 03:31 AM
Land Cruiser stuck in mud, rescued by hemi Jeep
by Shannow
05/06/16 02:53 AM
GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
87 registered (agpatel, 15SilvyEcotec, AirgunSavant, Alfred_B, Al, 901Memphis, 7 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248543 Topics
Page 1 of 2 1 2 >
#612400 - 05/09/04 06:44 AM How cold can 70/30 coolant mix get?
Anonymous
Unregistered
After some recommendations in another thread to help my pinging problem, I think I'm going to mix some 70/30 water/antifreez for my Cherokee. I might use some water wetter too. It won't be freezing again here until October, but I'm likely to forget that I have this mix in there when the time comes. What would the freezing point be of 70/30 mix?
#612401 - 05/09/04 06:51 AM Re: How cold can 70/30 coolant mix get?
Jelly Offline
Loc: College Dorm...
quote:
Well, a mix of 40% antifreeze and 60% water provides freeze-up protection down to -10F and boil over protection up to 259F.
I don't understand though...how much of a difference is it really gonna make?
I mean, say you're starting with a clean cooling system, is there really gonna be a big difference between using a top-quality 50/50 mix vs. a 70/30 mix?
Why not just run distilled water and WaterWetter for the "hot" months?
What's the O.E. thermostat setting and what do you have in there now?
Is there a lower temp stat available?
[ May 09, 2004, 10:26 PM: Message edited by: Jelly ]
#612402 - 05/09/04 06:59 AM Re: How cold can 70/30 coolant mix get?
tom slick Offline
Loc: Central Coast, Calif.
i believe that your thermostat will make up for the higher cooling efficency. for example if your truck normally runs at 190* then it will probably continue to run at 190* until it is under a greater load, then it may take a bit more time before it gets hotter. i don't think it will help your pinging, but it's cheap and worth a try.
[ May 09, 2004, 10:10 PM: Message edited by: tom slick ]
#612403 - 05/09/04 07:00 AM Re: How cold can 70/30 coolant mix get?
seotaji Offline
Loc: USA
Hopefully it'll make a couple of degrees difference.
How many people here run only distilled water and water wetter? I'd like to know if it protects at all?
#612404 - 05/09/04 07:31 AM Re: How cold can 70/30 coolant mix get?
Anonymous
Unregistered
My thermostat is 195 degree, but it allways runs at about 210, so any upgrades to the cooling system will actually make it run cooler. Even in the middle of winter 20 degree temps are extremely rare around here, teens only every couple of years, and below that once a century. I'm thinking about running this mix year round...
#612405 - 05/09/04 09:46 AM Re: How cold can 70/30 coolant mix get?
tom slick Offline
it will be interesting to see what happens, i have thought of using the 70/30 mix also since my weather is extremely moderate (boring). is your temp sensor at the thermostat housing?
#612406 - 05/09/04 09:56 AM Re: How cold can 70/30 coolant mix get?
Anonymous
Unregistered
quote:
I believe it is in the back of the head.
#612407 - 05/09/04 07:14 PM Re: How cold can 70/30 coolant mix get?
John K Offline
Loc: Loveland, Ohio
I am not familiar with WaterWetter, but think you would lose some boilover protection with just it and water... also distilled water with WW may be more corrosive. Don't understand how 70/30 mix is supposed to help cool, I would expect it to be worse, though protect to lower temp and higher boiling point. 100% antifreeze will freeze at a higher temp, like 20F I think. Memory fails me.
#612408 - 05/09/04 08:29 PM Re: How cold can 70/30 coolant mix get?
Jelly Offline
quote:
http://redlineoil.com/whitePaper/17.pdf
#612409 - 05/10/04 12:10 AM Re: How cold can 70/30 coolant mix get?
Anonymous
Unregistered
With more water it will cool better. Antifreeze is actually bad for cooling - the best would be straight water. Boiling isn't an issue even with straight water, the system is under pressure and if the engine is 212 degrees or hotter you've got a problem anyway...
#612410 - 05/22/04 01:30 AM Re: How cold can 70/30 coolant mix get?
widman Offline
Loc: Bolivia
there is a chart here:
http://www.widman.biz/Seleccion/Refrigeracion/refrigeracion.html
But I don't believe that is the way to go, nor would I ever recommend straight water because of the corrosion and caviation. If you want better cooling, change out your old fluid, use a good cleaner and rinse, and put in one of the new formulations like Delo Extended Life or Dex-Cool that only acts as a corrosion inhibitor/insulator in areas with cathodic reactions (you will see some pictures of this on the page mentions, even though text is spanish) . You get 8% better heat transfer with these fluids.
#612411 - 05/22/04 06:27 PM Re: How cold can 70/30 coolant mix get?
garyvegas Offline
Loc: Las Vegas
widman, I believe redline water wetter protects against corrosion and caviation. Someone correct me if I'm wrong.
#612412 - 05/22/04 07:20 PM Re: How cold can 70/30 coolant mix get?
Bill Morris Offline
Loc: NY
I tried using 20% coolant, 12oz Redline Waterwetter and 8oz RMI25. All work well for about 5k miles and radiator seem to cool off faster than normal. Then there was coolant leak from the gasket, I don't know if was from the Redline WW or what casue the gasket to leak. When I went back to 50/50, the leak stop but have no idea why it leaked or why it stopped leaking.
#612413 - 05/22/04 07:24 PM Re: How cold can 70/30 coolant mix get?
Bill Morris Offline
Loc: NY
Also it did stop the pinging which is why I tried it. I've heard others say Redline WW causes gasket leaks but can't say for sure it does.
#612414 - 06/28/04 02:18 AM Re: How cold can 70/30 coolant mix get?
Dominic Offline
Loc: Gilbertsville, PA
I run 70/30 in the summer months, and 50/50 in the winter months. Ive I loved up north though I'd run 50/50 year round.
I just do it because I'm in FL and I like my car to run 160F on the highway :-D (Yes I changed the thermo).
Page 1 of 2 1 2 >
