Peppers: do you grow them?
by car51
07/24/16 07:29 AM
Havoline conventional $2.99 at Rural King
by car51
07/24/16 06:35 AM
killing weeds without poisoning well
by oilboy123
07/24/16 01:27 AM
1999 ford expedition factory mercon v synthetic??
by merconvvv
07/23/16 11:40 PM
Buick 3800 - "Von Voyage" oil change?
by Alex_V
07/23/16 10:41 PM
Low oil level light on, but level not THAT low....
by gregk24
07/23/16 10:26 PM
Is SuperLube syn multi grease universal
by NattyBoh
07/23/16 10:05 PM
How come discount tire doesn't use jack stands?
by motor_oil_madman
07/23/16 09:41 PM
SAFETY ?: ramps in rear and jack stands in front
by SavagePatch
07/23/16 09:03 PM
Pennzoil ultra 5w30 back in stock at Walmart.com
by kohnen
07/23/16 08:37 PM
Homelite weedeater not getting fuel
by Drew99GT
07/23/16 08:26 PM
Stability issue on 2015 F250
by Donald
07/23/16 07:25 PM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
68 registered (Al, 2015_PSD, 182RG, AEHaas, 4WD, AIRJAC3, 7 invisible), 1081 Guests and 12 Spiders online.
58578 Members
66 Forums
252176 Topics
#611836 - 01/17/04 05:46 AM Water pump lube?
Anonymous
Unregistered
I noticed a bottle of this Gunk water pump lube at the store today. Think it does any good? Does it do any bad? The water pump in my cherokee has 200,000 miles on it, and they normally only last around 100k...and I don't want to replace it. [Big Grin]
#611837 - 01/17/04 06:42 AM Re: Water pump lube?
oilrecovery2003 Offline
Loc: Mi
DON'T USE THE GUN STUFF.
#611838 - 01/17/04 07:10 AM Re: Water pump lube?
Loc: Mi
Preston makes a real good conditionar. Has lube for water pump and takes care of whole water pump system. It is in a bigger yellow box, cost about $5.75 a bottle. But I have used in last two vehicles and have NEVER had a water pump or Radiator issue.
#611839 - 01/17/04 07:47 AM Re: Water pump lube?
cryptokid Offline
Loc: palm beach
dont waterpumps use sealed bearings?
#611840 - 01/17/04 08:06 AM Re: Water pump lube?
XS650 Offline
Loc: Northern CA
quote:
It lubes the seal and the vendors pocket book.
#611841 - 01/17/04 09:41 PM Re: Water pump lube?
JohnBrowning Offline
Loc: USA
Water Pumps usualy just use a brass bushing. The water pumps for small blocks use leather as a seal material. When you first put them on they leak until the leather swells. The antifreeze acts as a lubricant for the pump. I can neither say anything good or bad about coolant lube products.
#611842 - 01/17/04 10:21 PM Re: Water pump lube?
XS650 Offline
Loc: Northern CA
quote:
Say what?
#611843 - 01/17/04 11:05 PM Re: Water pump lube?
Anonymous
Unregistered
Whether or not it works...do you guys think it would do anything bad? It's only $1.50...
#611844 - 01/18/04 12:36 AM Re: Water pump lube?
XS650 Offline
Loc: Northern CA
quote:
I have an aversion to putting petroleum oil
http://www.gunk.com/msds/C1012.PDF
in my cooling system.
That said, Gunk (Radiator Specialties) is a pretty good company, so their product shouldn't do any harm and will probably help water pump seal life at some small probably unnoticable sacfifice in cooling from the oil coating the metal in the engine and reducing heat transfer.
If you just want to get rid of $1.50, send it to me and I will guarantee I won't harm your cooling system [Wink]
#611845 - 09/06/04 05:29 AM Re: Water pump lube?
mechtech Offline
Loc: Chicago area
Brass bushings!? Leather seals!? [LOL!]
#611846 - 09/06/04 02:36 PM Re: Water pump lube?
outrun Offline
Loc: Texas & BWI Area
Use the water based Zerex Water Pump Lubricant.
There seems to be some pro-con here against Redline WaterWetter and RP Water Wetter has possibly corrosive additives.
