I hope someone can explain this fitting to me. This is for a GM 350 4x4 truck. The oil filter doesn't spin on to the block, there is an adapter bolted onto the block which changes the direction of the filter, and provides a mount for the skinnier filter. This is necessary because the 4x4 gear would get in the way of the normal GM small block oil filter.
Another function of this adapter mount filter is that the oil cooler hoses go in and out from this adapter towards the oil cooler.
This is a photo of the end of the new oil cooler hose. It looks like the correct hose, but the one coming off of the adapter has a large nut between the filter/hose mount and the plastic thing at the end of the hose.
I can't picture what tightens the flare end onto the filter/hose mount if the nut is not already pre-installed on the end of the hose. I checked online photos of this part, plus another identical part at the parts store. It appears that the hose is not missing the nut I think it's missing.
I'm just not familiar with this kind of fitting, can anyone tell me how this hose gets secured to the filter/hose mount?
Here's a picture of the hoses going in to the filter/hose mount on the truck....same direction as the hose in the above picture is oriented. The nut on the mount is to the left of the orange plastic thing which is the same piece as the black plastic thing on the new part.
Does anybody know how this fitting works? I don't want to force anything without knowing how it works.
Thanks in advance for your help.
