PP Euro 5w40, 2014 VW Jetta 1.8T, 8250 mi.
by ryanm8
34 minutes 47 seconds ago
Don't be blowing yourself up this holiday weekend
by skyactiv
44 minutes 18 seconds ago
Finally
by bigdreama
59 minutes 23 seconds ago
Happy Canada Day !!
by Papa Bear
Today at 06:12 PM
Napa July 2016 Sale - Platinum filters $7.50
by slacktide_bitog
Today at 06:11 PM
Menzerna Became "Jescar?"
by dkryan
Today at 05:32 PM
In the corn belt, non ethanol fuel is everywhere
by another Todd
Today at 05:13 PM
Cummins: Standpipe in fuel filter needed or not?
by Extreme-Duty
Today at 03:36 PM
Napa Canada, Magnatec, Delvac, Napa 15W-40
by Farmer
Today at 02:33 PM
Meijer 4 day sale (4th of july weekend)
by Kwuality
Today at 02:14 PM
Brakes for 2012 Subaru Legacy
by Picky1
Today at 01:56 PM
Microgreen Oil Filter 50% Off Discount Code
by kohnen
Today at 01:51 PM
Jennyp, dcdodge, igolfat8, makomike, Alexas
58338 Registered Users
90 registered (barkingspider, Berny, aprilia1, 01rangerxl, aquariuscsm, akcooper9, 10 invisible), 1791 Guests and 9 Spiders online.
58338 Members
66 Forums
251111 Topics
#584736 - 09/03/06 08:05 PM 2004 Nissan Sentra Transmission Filter
ConfederateTyrant Offline
Loc: Morrow, Georgia
Anyone ever replaced the transmission filter for these automatic transmissions before? This is a picture of it:
I have no problem removing the pan, as this one has a drain plug as well to make drains easier, but does this filter just pop off or is it a bolt on? With all of those hole locations, it would appear to me that there is a set of bolts needed to hold it in place.
There is no mention of replacing this filter in the maintenance section of the owner's manual. It only mentioned to drain/replace the transmission fluid.
#584737 - 09/04/06 03:39 PM Re: 2004 Nissan Sentra Transmission Filter
JTK Offline
Loc: Buffalo, NY
That is an unusual looking trans filter with 11 (I assume) bolt/attachment holes! I never removed the pan from my 1993 or 2001 sentra. Just did periodic drain/fills which was easier than an oil change!
Joel
#584738 - 09/05/06 01:55 AM Re: 2004 Nissan Sentra Transmission Filter
Cutehumor Offline
Loc: USA
don't change the filter! apparently, there is some kind of bolt that is needed for the tranny and it will come out.
per ryansride2017
"I believe this one falls under your category:
I was changing the tranny fluid/filter on my 2003 Sentra. While removing the last bolt holding the filter cartridge onto the valve body, I realize the last bolt is unlike any of the others. In fact a nut came down from the upper end of the valve body (where I couldn't possible get my hand up there to replace it). I had to get it towed to a local tranny shop.
After my car gets to the tranny shop (well-known, national company - but independent) they go bankrupt. I lost the $125 that I spent to get it towed to this business. I had it towed to another tranny place (Aamco), costing me another $100. They state that the bolt was installed incorrectly at the factory. They said the nut should have been on the bottom side of the valve body to allow easy removal of the tranny filter.
They charged me $500 to drop the valve body of the transmission and correctly install the bolt.
Nissan Corporation would not reimburse me for any charges because I didn't tow it to a Nissan dealership (closest is 50 miles away) even though I have the receipt stating it was installed incorrectly. I called the Nissan dealership but they wouldn't be able to look at if for a couple weeks...they were that backed up. I couldn't wait that long. But hey, I got a tranny fluid/filter change for $725! Drank a beer or two that weekend.
Even if my Nissan lasts to 400K miles, I don't know if I will buy another one just because of this experience."
found here
scroll down to find post
#584739 - 09/05/06 05:31 PM Re: 2004 Nissan Sentra Transmission Filter
JTK,
I will leave the filter in there, and just do a few drain-and-fills to do a "flush" and continue to drain and fill at set intervals.
Cutehumor,
I'm glad you showed me that post, I recall finding that post a few months back when my wife bought the car. Would you see any harm with removing the pan and cleaning it off, along with the magnets?
#584740 - 09/05/06 10:50 PM Re: 2004 Nissan Sentra Transmission Filter
deepsquat Offline
Loc: Tacoma ,WA
I really don't think it is necassary to remove the filter...it is just a screen...just stick witrh your plan of many drain and refills...I drain my Altima all the time ...easy...and if you really want to get it filtered ...and a inline filter..or a bypass filter ( I put a bypass filter )
#584741 - 09/07/06 09:28 AM Re: 2004 Nissan Sentra Transmission Filter
unDummy Offline
Loc: RI
Yep, its just a screen. Install a real aftermarket ATF filter. Dropping pan is for inspection purposes and magnet cleaning.
$500 for VB R&R is nuts.
#584742 - 09/19/06 06:20 PM Re: 2004 Nissan Sentra Transmission Filter
Thanks everyone.
I won't touch that screen they have, but I will take the pan off and clean it, as well as the magnets, but I was reading through the manual and it suggests replacing the pan bolts.
Does anyone know how necessary that is? If it is, where can I get the bolts, other than the stealer?
#584743 - 09/19/06 07:12 PM Re: 2004 Nissan Sentra Transmission Filter
unDummy Offline
Loc: RI
Not necessary. But, you'll need to clean or wirebrush the old sealant off and use a thread sealer. Torque wrench is also mandatory!
#584744 - 09/20/06 02:12 AM Re: 2004 Nissan Sentra Transmission Filter
ryansride2017 Offline
Loc: The coal hills of eastern PA
Thanks Cutehumor,
For bringing this topic back up when I finally "talked myself off the ledge" regarding my fiasco. [Bang Head]
According to Nissan, the filter is designed to be maintenance free. Just drain the fluid and refill. But it still FRUSTRATES me that the auto parts stores sell a kit for this car which includes a filter when it shouldn't be changed!!
O.k., now to find my medicine again.
#584745 - 09/20/06 02:55 AM Re: 2004 Nissan Sentra Transmission Filter
benjamming Offline
Loc: northern Alabama
ryansride2017,
Why should a filter not be changed? The manual doesn't say to not change the filter does it? They simply claim that it's not necessary (in their eyes).
#584746 - 09/20/06 03:10 AM Re: 2004 Nissan Sentra Transmission Filter
If you take your sentra to a Nissan dealership for a transmission service, they drop the pan, remove any obvious particles from the underside of the wire mesh filter (without removing it), install a new gasket, re-install the pan and refill with fluid.
Nissan likes using "maintenance free" filters in the transmission and fuel tank. While many people have problems referring to a filter as "maintenance free", I haven't heard of any failures because of it. I have 138K on my Sentra and other than my transmission fiasco, I haven't had any out of the ordinary repair fees.
#584747 - 09/20/06 05:08 AM Re: 2004 Nissan Sentra Transmission Filter
benjamming,
The Nissan service manual states nothing about replacing the filter as maintenance. From what I have read it only includes it with the disassembly of the transmission.
ryansride2017,
Thanks for making that post about your experience.
#584748 - 09/26/06 04:43 AM Re: 2004 Nissan Sentra Transmission Filter [Re: ConfederateTyrant]
unDummy (as well as others),
Which of these would you choose:
Permatex Thread Locker: http://www.accessconnect.com/images2/threadlocker_blue.jpg
or
Permatex Thread Sealer: http://www.accessconnect.com/images/56521.jpg
Also, this is not dependent on this particular model, but would either of these be a good idea for differential cover bolts? Or is it unnecessary to use sealant on the bolts, I haven't in the past and no problems came of it, but just want to check here.
Thanks again.
You can't get bought without thought...
