CJ-4 Synthetic Oil for Kawasaki FX engine?
by lawnguy
02/11/16 06:54 PM
Body was there for months......
by OVERKILL
02/11/16 06:23 PM
Promotive by Purolator ph241/pl10241 13 months/10k
by Xrs2zz
02/11/16 06:01 PM
Who had a small GM diesel?
by OVERKILL
02/11/16 05:40 PM
Rotella 5W40 in a Tecumseh
by TriMoto
02/11/16 05:36 PM
GM 6L45R Auto Tranny - Change Fluid @ 190k?
by zeddy
02/11/16 05:18 PM
the "search" feature is terrible
by nicrfe1370
02/11/16 04:38 PM
API SN / ILSAC GF-5. Taking a shellacking
by wemay
02/11/16 04:37 PM
Got the air compressor - now what else do I need ?
by Cressida
02/11/16 04:19 PM
Cold today bad battery
by bprat318
02/11/16 04:05 PM
Blending 15w-40 + trying to get it to ~10w-30 ?
by Cressida
02/11/16 03:57 PM
I'll never remove my trailer hitch again
by grampi
02/11/16 03:40 PM
SkipKaye, MikeHancho, tempnexus, cobra1616z, meyer
56896 Registered Users
106 registered (2KBMW, 97f150, 901Memphis, 6X13, 90crvtec, alcyon, 11 invisible), 1614 Guests and 201 Spiders online.
56896 Members
66 Forums
244566 Topics
Page 1 of 2 1 2 >
#584512 - 08/25/06 07:46 PM Transmission Fill on 2001 grand am?
Flixxo Offline
Loc: Maryland
All,
I can not for the life of me find the fill bolt on a 2001 grand am auto transmission. If anyone could help me out I would appreciate it. I plan on dropping the pan but don't want to be stuck and not know where to fill it up. Also, as a bonus, does anyone know where the drain plug is on the radiator? I'm a honda guy and not used to these pontiacs!
#584513 - 08/25/06 07:55 PM Re: Transmission Fill on 2001 grand am?
Drew99GT Offline
Loc: Colorado Springs
I don't believe there is a dipstick if this is on the 3.4. There is a fill plug on top of the trans near under the throttle body. It's red. So you will have to measure EXACTLY how much fluid you drained and install that much in new fluid.
#584514 - 08/27/06 09:38 AM Re: Transmission Fill on 2001 grand am?
mechtech Offline
Loc: Chicago area
There is no dipstick.
Read the convoluted logic in the owner's manual.
Something about - If the trans fluid is low, bring it to the dealer to be serviced.
But how do you know?
#584515 - 08/26/06 11:21 PM Re: Transmission Fill on 2001 grand am?
Flixxo Offline
Loc: Maryland
thanks for the help, I did look near the TB and found the fill plug. for the life of me I do not get why there is no dipstick. Even if I put in the same amount as I take out, who's to say it wasn't low in the first place!!
#584516 - 08/27/06 01:44 AM Re: Transmission Fill on 2001 grand am?
babyjay8495 Offline
Loc: cincy
Its what GM likes to call a lifetime fluid. They think that they tranny should never be serviced (another brilliant idea by the General). I did a fluid change on my girlfriends malibu, but went the easy way. I just disconnected the trans line going into the radiator (top one if i recall) and pumped the old stuff out into a milk jug. Put exactly what i got out back in and not a problem yet.
#584517 - 08/27/06 04:05 AM Re: Transmission Fill on 2001 grand am?
The Critic Offline
Loc: Walnut Creek, CA
This thread should answer your questions. Your car has the 4T40 or 4T45E transmission:
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=16;t=002212#000009
There's also a "vent cap" at the top of the unit, underneath the brake reservoir. That's another way of filling the unit.
#584518 - 08/27/06 05:12 PM Re: Transmission Fill on 2001 grand am?
Flixxo Offline
Loc: Maryland
thanks all, babyjay, how much fluid did you get out with this method? did you do this with the engine running?
#584519 - 08/27/06 06:09 PM Re: Transmission Fill on 2001 grand am?
johnd Offline
Loc: Austin, TX
While we are on the subject of transmissions, I had an employee that was a former mechanic who showed me a great trick for taking off transmission pans. Use a trash can lid to catch the pan in, it's big enough to get the whole thing, fluid and all. Make a small hole in the lid first to drain the fluid out of into your recycle container. I tried it and it cut way down on the mess.
#584520 - 08/28/06 01:49 AM Re: Transmission Fill on 2001 grand am?
babyjay8495 Offline
Loc: cincy
I got out 7 quarts. I disconnected the line, started the car and had a friend watch the fluid come out in the jug. I stopped right when the fluid started slowing down, right about 7 quarts. I might of been able to get out a bit more, but good enough for me. Filled it back up and went on my way. I used the Super Tech brand, can't beat the price. I'm sure others will argue to go with something more pricey, but i couldn't justify going with anything else, and it works great by the way.
#584521 - 08/28/06 08:20 PM Re: Transmission Fill on 2001 grand am?
Clyde65 Offline
Loc: San Antonio,TX
The radiator drain plug is on the far bottom right of the radiator. If you're sitting in the driver's seat, then it's on the far bottom left. There should be a hole cut into the bottom of the bumper to access the drain plug with a socket.
#584522 - 08/29/06 01:24 PM Re: Transmission Fill on 2001 grand am?
cousincletus Offline
Loc: Richmond, VA
7.4 quarts when you change the fluid & filter.
#584523 - 08/29/06 05:27 PM Re: Transmission Fill on 2001 grand am?
Market525 Offline
Loc: Southern Maine
As a do-it-yourselfer, I must say -- what an idiotic design! The trend certainly seems to be away from trans dipsticks, though.
#584524 - 08/29/06 07:13 PM Re: Transmission Fill on 2001 grand am?
brianl703 Offline
Loc: Manassas, VA
What's idiotic about it? You can't possibly overfill it.
#584525 - 08/30/06 12:02 AM Re: Transmission Fill on 2001 grand am?
JakeR22 Offline
Loc: il
quote:
I would assume what Market is trying to say is, if you can't read a dipstick, maybe one shouldn't even be working on a car, [Smile] .
I agree. It's not what I would want as a do-it-yourselfer.
#584526 - 08/30/06 01:04 AM Re: Transmission Fill on 2001 grand am?
Matt_S Offline
Loc: Metro Detroit
There's an oil level control plug on the torque converter side of this transmission just above the pan. The fluid level should be even with the bottom of the threads. There's no point in guessing how much fluid to add. Use that plug to check.
Page 1 of 2 1 2 >
