Premium Guard Filters
by CapitalTruck
04/30/16 01:54 PM
Wheel centering ring
by Donald
04/30/16 01:22 PM
tight pocket knife
by spasm3
04/30/16 01:04 PM
Any Jack Russell owners?
by chrisri
04/30/16 12:10 PM
Tire ply description as listed on sidewall
by Cressida
04/30/16 11:43 AM
spec that measures ability of oil to cool an engin
by paulri
04/30/16 11:41 AM
Best USA Produced Olive Oil
by hatt
04/30/16 11:29 AM
How often do you run malware bytes?
by Doog
04/30/16 11:03 AM
F250 Rear Diff Fill Plug Seized
by Mantooth
04/30/16 10:48 AM
What oil should I use for 2000 cavalier that burns
by SeasonalEclipse
04/30/16 10:47 AM
Why is HDEO better for OPE, than regular oil?
by NH73
04/30/16 09:53 AM
CASTROL EDGE 5W-40 FST no ACEA A3/B4 ?
by alcyon
04/30/16 09:53 AM
paydase, Scopx, speedysmitty, hdwizard21, raihan
57751 Registered Users
77 registered (bdcardinal, Astro14, AirgunSavant, Atesz792, Bill_G, 5 invisible), 2056 Guests and 327 Spiders online.
57751 Members
66 Forums
248252 Topics
Page 1 of 2 1 2 >
#582476 - 07/11/06 07:12 PM Recipe for Tire Lubricant?
carock Offline
Loc: California
Cannot find tire lubricant in small quantities for a DIY mechanic. Tire lubricant is a vegetable based soap used to mount tires on the rim. Does anybody know a home brew formula I can use safely?
#582477 - 07/11/06 07:20 PM Re: Recipe for Tire Lubricant?
Hirev Offline
Loc: Oregon
Hot water with a fair amount of dish washing liquid such as Joy.
#582478 - 07/12/06 09:11 AM Re: Recipe for Tire Lubricant?
jsharp Offline
Loc: Outside smalltown, IL
I'll second the dishwashing liquid recommendation. Full strength or diluted with a small amount of water.
#582479 - 07/12/06 09:34 AM Re: Recipe for Tire Lubricant?
ConfederateTyrant Offline
Loc: Morrow, Georgia
In my auto tech class we used the dishwashing liquid and water to lube the tire. It never gave any of the students a problem.
#582480 - 07/11/06 10:27 PM Re: Recipe for Tire Lubricant?
punisher Offline
Loc: snowblind in TX
Safety Seal sells it for about $20/gallon.
#582481 - 07/12/06 02:51 AM Re: Recipe for Tire Lubricant?
UncleS2 Offline
Loc: Far North East Texas
An old tire shop owner I knew long ago used a few squirts of the shop's liquid hand soap stirred up in a couple gallons of water, or when that ran out he'd steal his wife's liquid dishwashing soap. When I asked him about it, his answer was: "This part's easy, don't try to make it hard." [Big Grin]
#582482 - 07/12/06 06:38 AM Re: Recipe for Tire Lubricant?
Brett Miller Offline
Loc: Arizona
Hand cleaner without pumice works well also.
#582483 - 07/12/06 07:23 AM Re: Recipe for Tire Lubricant?
unDummy Offline
Loc: RI
Bubble blowing solution from the kids toy box will work.
#582484 - 07/12/06 03:09 PM Re: Recipe for Tire Lubricant?
mechtech Offline
Loc: Chicago area
Dishwashing soap and water is a time honored substitue, and works very well.
One big problem however is moisture that remains in the tire. Water is the main reason for tire pressure fluctuations. That is why nitrogen is used for premium tire fills. Dry air is just as good, and much cheaper.
Water will also contribute to corrosion. It can't evaporate away - it has no place to go.
#582485 - 07/13/06 02:09 AM Re: Recipe for Tire Lubricant?
IslaVistaMan Offline
Loc: San Diego, CA
NAPA's RuGLYDE works great -- cheap, too.
#582486 - 07/13/06 08:03 AM Re: Recipe for Tire Lubricant?
carock Offline
Loc: California
Okay,I did my own private home test on my motorcycle tires. Palmolive + water was REALLY difficult to get the bead over the rim. Napa supplied tire lube was pretty easy to get the bead over the rim. Dishwater soap may work, but not nearly as well as the Napa supplied stuff.
#582487 - 07/13/06 11:42 AM Re: Recipe for Tire Lubricant?
PandaBear Offline
Loc: Silicon Valley
Can you mount your own tire at home? How do you balance it?
#582488 - 07/13/06 02:32 PM Re: Recipe for Tire Lubricant?
mechtech Offline
Loc: Chicago area
Motorcycle tires are relatively easy to get on and off.
You can balance a motorcycle front tire by raising the wheel off of the ground, and retracting the brake pads. Then add weights to static balance it. Because the tires are so thin compared to a car's, they don't need the side to side dynamic balancing.
#582489 - 08/05/06 11:05 AM Re: Recipe for Tire Lubricant?
jc1990 Offline
Loc: palmer mass
UST STP SON OF A GUN WORKS GREAT MY UNCLE OWNS A COUPLE OF TIRE SHOPS HE, S TRIED EVERYTHING THAT WORKS BEST
#582490 - 08/05/06 11:59 AM Re: Recipe for Tire Lubricant?
55Test Offline
Loc: New Brunswick
My dad uses plain ol' chassis grease.
Page 1 of 2 1 2 >
