Does Anyone Remember...
by pscholte
57 minutes 51 seconds ago
Oil filter for fuel filter?
by leroyd92
59 minutes 38 seconds ago
YouTube search geniuses help me out!
by Vern_in_IL
Today at 10:00 PM
BMW i8 Could Have 750 HP All-Electric After 2020
by HTSS_TR
Today at 09:48 PM
1991 Audi 200 Turbo Automatic Oil Standard?
by Logos
Today at 09:43 PM
Chevron & Sunoco & Speedway $100 Gift card $92
by gojoneeded
Today at 08:41 PM
Santa's Not Going To Be Happy
by Warstud
Today at 08:29 PM
can someone explain the Ecoboost to me?
by columnshift
Today at 07:50 PM
4 dragging weak brakes (after parked for a year)
by columnshift
Today at 07:34 PM
New S&W Shield 9
by funflyer
Today at 06:42 PM
ecoboost 3.5
by boostnation
Today at 06:30 PM
Meijer, Mobil and the joys of Labor Day stackation
by fdcg27
Today at 06:25 PM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
59 registered (ag_ghost, 74Scout, barkingspider, 2015_PSD, ammolab, asiancivicmaniac, 6 invisible), 1175 Guests and 8 Spiders online.
58964 Members
66 Forums
253791 Topics
#577509 - 03/13/06 10:26 PM Best product to clean intake EGR passages
wavinwayne Offline
Loc: North Alabama
Since I have the day off tomorrow, I'm going to disassemble & clean the throttle body/upper intake plenum on my wife's '97 Expedition 4.6L with 120k miles.
The EGR passages on it are carboned up very badly, it has had DTC code P0401 forever, & I want to give the EGR passages a thorough cleaning.
What is the best product on the (retail) market to use for this? I plan to let the part soak in the solution for a few hours minimum. Then I'll take a few bore brushes to the EGR passages to get 'em nice & smooth.
#577510 - 03/13/06 11:46 PM Re: Best product to clean intake EGR passages
robbobster Offline
Loc: Long Beach, CA
A bit off-topic, but can you post-up what you find in your upper plenum? I'm betting that it will have a lot of oil in there, I've seen a few modded plenums that were extremely oily, but haven't seen any stock ones to compare.
BTW - I recently replaced my EGR and DPFE. The EGR was pretty fouled, didn't seem like it was worth cleaning. We used a bore brush to clean the EGR tube.
I bet FP60 would be good to clean the EGR but I don't know if you have any of that laying around.
#577511 - 03/13/06 11:57 PM Re: Best product to clean intake EGR passages
Kestas Offline
Loc: The Motor City
Castrol Super Clean. It's a lye-based cleanser that degreases very well, essentially like Oven-Off, except in spray form. You have to be careful using it on aluminum. It'll oxidize the surface and form white chalky layer if left on too long.
Don't expect to get the parts whistle-clean. I've tried cleaning things like egr passages, and often find you can only begin to clean it using mechanical methods, such as using a metal brush.
#577512 - 03/14/06 12:02 AM Re: Best product to clean intake EGR passages
johnd Offline
Loc: Austin, TX
What is FP60? Will it disolve carbon deposits? My son and I have tried for years to find something to get carbon deposits out of VW heat riser tubes, so far to no avail.
#577513 - 03/14/06 12:38 AM Re: Best product to clean intake EGR passages
wavinwayne Offline
Loc: North Alabama
I'm thinking about soaking the part in Berryman's B12 Chemtool. Any thoughts on how well this would work?
#577514 - 03/14/06 12:49 AM Re: Best product to clean intake EGR passages
moribundman Offline
Ream out the EGR passage with a steel stranded cable (like from a mechanical speedometer) and an electric drill. Then vacuum all the bits and pieces of carbon.
#577515 - 03/14/06 01:39 AM Re: Best product to clean intake EGR passages
robbobster Offline
Loc: Long Beach, CA
quote:
Fuel Power. They are a site sponsor:
http://www.lubecontrol.com/fuel.htm
It's supposed to dissolve carbon deposits.
#577516 - 03/14/06 05:41 AM Re: Best product to clean intake EGR passages
wiswind Offline
Loc: Wisconsin
My guess is that the EGR deposits will be right at the end of each EGR passage (port) where it enters the intake. This is where the EGR gasses and the PCV vapors meet.....and create the black tar. Yes, there will be a black surface coating on down through the EGR passages, but they will not cause any problem.
So, if you clear each EGR port, you will be fine.
Also, double check the EGR pipe, that goes from the exhaust to the EGR valve, for any rust holes, and also double check the connections from the pipe to the DPFE.
You don't want to let fluids and / or crud get on down into the lower manifold.
Some have cleaned EGR ports with just a small screw driver and a vaccum cleaner hose to suck up the crud as they pick it loose.
Fuel system cleaners, in the gasoline, such as FP60 are great products. However, they will not clean (when used in the gas tank) the EGR ports, as this is in the air passage BEFORE the gasoline (containing the cleaner) is introduced.
Also, spray cleaners sprayed into the air intake, will not really help with the EGR ports.
So, tearing in and physically cleaning them is the only real way to get them clean.
The DPFE can also be defective.
#577517 - 03/14/06 08:35 AM Re: Best product to clean intake EGR passages
BlueOvalFitter Offline
Loc: Cajun Country, La.
Deep Creep. [Patriot]
#577518 - 03/14/06 11:34 PM Re: Best product to clean intake EGR passages
robbobster Offline
Loc: Long Beach, CA
True.
But using, say, FP60 to soak or spray onto the components undiluted, I think this would work as well.
#577519 - 03/15/06 04:38 AM Re: Best product to clean intake EGR passages
wavinwayne Offline
Loc: North Alabama
I did the dirty deed today. Check it out here:
Ford 4.6L throttle body cleaned
