I wrote this for the Acurazine, 3rd Gen TL section.
Thought I'd pass this along to my BITOG family as well.
For those of you who wonder how much old fluid remains in your 5AT after each drain and refill, I've set up a formula that will calculate that.
Now, calculating the amount of fluid remaining after a single drain and refill is simple...you simply divide the amount of fluid removed by the total amount of fluid remaining. In the case of the TL, you typically remove 3 quarts per drain and refill out of the total 7.4 quarts.
So, 3/7.4=0.405 (40.5%) Subtracting from 100, this will give me about 0.595, which is about 59.5% of old fluid remaining.
Now if you do multiple drain and refills to remove as much fluid as possible during a short period of time say, by draining and refilling then driving a short distance before repeating the process, determining the percentage of old fluid within this new and old fluid "mix" can be somewhat challenging.
I've found an accurate way of doing this, and that is to:
1) Divide the amount of fluid removed from the system with each drain and refill. In the case of the 3rd Gen TL, a single drain and refill removes 3 quarts out of the total 7.4 quarts in the system. A quick trip to the calculator tells me that a single drain and refill removes 40.5% of the 7.4 quarts.
2) Take 40.5% and subtract if from 100%, this will give you 59.5%; thus, 59.5% of fluid is left in the system.
3) Now take 59.5%, and put it into decimal form, which would be 0.595. If you are planning to do three drain and refills, input 0.595 into your calculator and raise it to the third power. I get a value of 21%, which means that after drain and refilling the transmission three times, and driving a short distance in between each refill, 21% of the fluid in the system is "old" fluid.
Now, if you have a "target" amount of fluid that you want to have remaining in the system, say you want to have 20% old fluid remaining in the system, the following this formula:
3) Take 59.5%, and put it into decimal form, 0.595.
4) Take your "target" amount of old fluid remaining in the system, say 20%, and put it into decimal form, 0.2.
5) Take log 0.2, and press equal, which will equal -0.7.
6) Then, then take log 0.595, which will equal -0.23
7) Divide log 0.2 by log 0.595, which in this case is -0.7/-0.23=3.04. Which means that you'll have to do 3 drain and refills to remove 80% of the fluid.
Michael
Michael
