Scratched wheel
by gabriel9766
06/30/16 05:52 PM
Gear oil added to motor oil in engine
by TiredTrucker
06/30/16 05:52 PM
Purolator 10111 Cut Open- Red Can- NEW
by FordBroncoVWJeta
06/30/16 05:51 PM
A Tesla Model S on auto-pilot was in a fatal crash
by JimPghPA
06/30/16 05:49 PM
Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (5316Mi)
by DuckRyder
06/30/16 05:00 PM
By law, do owners have to comply with recall ?
by HTSS_TR
06/30/16 04:54 PM
Stuck ring?
by TurboFiat124
06/30/16 04:16 PM
Protectant 303 vs. Wax on fiberglass surfaces
by mbacfp
06/30/16 03:17 PM
Jeep brakes
by buck91
06/30/16 03:10 PM
Any thoughts on the Hersheys attempted buyout?
by Vern_in_IL
06/30/16 02:55 PM
2009 Miata Race Car, M1 5w20
by 09_GXP
06/30/16 02:48 PM
FRAM TG3600 Cut Open
by HX520W
06/30/16 02:30 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
80 registered (911Don, 09_GXP, 2004tdigls, 901Memphis, AandPDan, AirgunSavant, 6 invisible), 1839 Guests and 9 Spiders online.
58322 Members
66 Forums
251052 Topics
Page 1 of 2 1 2 >
#556455 - 10/15/04 11:32 PM What to Use to Clean IAC Valve?
Jelly Offline
Loc: College Dorm...
Carb Cleaner?
#556456 - 10/16/04 12:00 AM Re: What to Use to Clean IAC Valve?
Whimsey Offline
Loc: The Garden State
You might want to use throttle body cleaner. It will be most likely less caustic on the plastic and metal parts versus carb cleaner which can "melt" plastic and strip coatings off metal.
Whimsey
#556457 - 10/16/04 12:17 AM Re: What to Use to Clean IAC Valve?
motorguy222 Offline
Loc: Ky
WD-40 or something similar may be of help also.
I took one of those valves to my local NAPA once,wanting a new one,the guy behind the counter didnt know what it was.They also didnt have the part.
This was on a car that had been out long enough for parts to be available.I ended up going to a junkyard,I think it was $10,the valve worked great.Never had to replace it again.
Maybe the junkyard would be an option instead of trying to clean it.
[ October 16, 2004, 03:23 PM: Message edited by: motorguy222 ]
#556458 - 10/16/04 12:30 AM Re: What to Use to Clean IAC Valve?
Jelly Offline
Had an issue where the car was idling way too high. I pulled the IAC valve out and it was heaviliy covered in carbon (well, I believe it was carbon buildup)...wiped off the buildup at the time, but didn't give it a good cleaning.
The idling is much improved/lower, but next weekend I'd like to thoroughly clean it off.
#556459 - 10/16/04 12:54 AM Re: What to Use to Clean IAC Valve?
motorguy222 Offline
Loc: Ky
Jelly,there is also a certain way those things are supposed to be put back in.They have to be adjusted before re-installing or you could damage the IAC Valve motor.
Is this out of your truck?
Do you have a manual?
I have a manual with some info about the IACV but it doesnt specify your vehicle.
#556460 - 10/16/04 02:00 AM Re: What to Use to Clean IAC Valve?
Jelly Offline
quote:
Yeah, you just have to make sure to retract it before reinstallation.
If I'm remembering right, I believe the reason I didn't use any cleaner last time was because the IAC valve is an electrical component, and dousing it in a cleaner might not be the best thing to do...
#556461 - 10/16/04 09:49 AM Re: What to Use to Clean IAC Valve?
seotaji Offline
Loc: USA
use electrical contact cleaner?
#556462 - 10/16/04 12:11 PM Re: What to Use to Clean IAC Valve?
BlazerLT Offline
Loc: Canada
quote:
Originally posted by Jelly:
Carb Cleaner?
Just did my on a chev.
Throttle body cleaner and an old toothbrush worked wonders to get all the carbon off.
Rinse with the TB cleaner after the scrub and reinstall.
#556463 - 10/16/04 05:01 PM Re: What to Use to Clean IAC Valve?
Pablo Offline
Loc: Duvall WA - Pacific NW USA
Jelly - What kind of carbon stuff is in your IAC? Crusty? Oily?
I have used PB Blaster with good sucess on IAC's.
#556464 - 10/16/04 11:04 PM Re: What to Use to Clean IAC Valve?
Jelly Offline
Flaky/Crusty, not oily.
#556465 - 10/17/04 02:08 AM Re: What to Use to Clean IAC Valve?
BlueOvalFitter Offline
Loc: Cajun Country, La.
Amzoil Power Foam is the best cleaner,but Deep Creep and CRC throttle body cleaner are good choices too.BTW,while you're in there clean your throttle body too. [Patriot]
#556466 - 10/17/04 02:36 AM Re: What to Use to Clean IAC Valve?
Pablo Offline
Power foam will work and be safer for your plugs....I was gonna say PB Blaster does pretty good BUT don't get gobs of it in your engine, it'll foul your plugs.
#556467 - 10/17/04 03:14 AM Re: What to Use to Clean IAC Valve?
Jelly Offline
So can I use throttle body cleaner...
[ October 17, 2004, 06:50 PM: Message edited by: Jelly ]
#556468 - 10/19/04 01:48 AM Re: What to Use to Clean IAC Valve?
Yep,ide recommend that over carb cleaner any day!
#556469 - 10/20/04 05:49 AM Re: What to Use to Clean IAC Valve?
oilpan49 Offline
Loc: Ohio
Hey,
Now that I think about it, my truck when you fire it up, it'll run at about 800 something RPM but if you leave it after a couple minutes of just sitting there idling, the RPM's will creep up to 1000.
I tried looking in my service manual for it, but the closest thing it explains is the IAC selenoid. Does anyone have a proper procedure for this step?? If I'm robbing this thread, I do apologize,,,,,,AR
Page 1 of 2 1 2 >
