F1 - 2016 Monaco Grand Prix
by gofast182
05/25/16 11:39 AM
Mazda 3 drain and fill
by jay929
05/25/16 11:38 AM
Looking at VW TDI
by loneryder
05/25/16 11:13 AM
Valvoline Maxlife ATF & Walmart
by HosteenJorje
05/25/16 11:00 AM
New car polish
by Tempest
05/25/16 10:58 AM
Toyota Red long Life vs Pink Super Long Life?
by Drew99GT
05/25/16 10:50 AM
Extended Warranty Requirement
by TiredTrucker
05/25/16 09:57 AM
RARE HID installation
by Kira
05/25/16 08:51 AM
ATP AT-205 good engine cleaner ?
by kr_bitog
05/25/16 06:16 AM
List of VOA's from Russian Oil Club
by spiderbypass
05/25/16 01:43 AM
Quicksilver Prem Plus
by jmw116
05/25/16 01:39 AM
Creating white letter tires
by turtlevette
05/25/16 12:22 AM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
83 registered (901Memphis, AKA, 1JZ_E46, Andrei, 97f150, 440Magnum, 9 invisible), 1783 Guests and 309 Spiders online.
57973 Members
66 Forums
249383 Topics
#551791 - 05/26/04 09:06 AM Belt dressing vs. Multi Purpose Lubricant (WD-40)
Lumberg Offline
Loc: Washington DC area
When I was a mechanic people would often coem in with a squeaking belt. We'd pop the hood, spray soem WD-40 on there, and send them on their way, happy as a clam. No charge. If it came back we'd do more.
This technique worked surprisingly well. I have since tried belt dressing. WD-40 still works better. Some times it is even a permanent or semi-permanent fix.
#551792 - 05/25/04 10:06 PM Re: Belt dressing vs. Multi Purpose Lubricant (WD-40)
Kestas Offline
Loc: The Motor City
I would worry about the long term effects of WD-40 on the belt life. It may break down the rubber making it soft, gummy, and sticky -- good for quiet running but bad for belt strength.
#551793 - 05/25/04 10:41 PM Re: Belt dressing vs. Multi Purpose Lubricant (WD-40)
T-Keith Offline
Loc: MN
There's a post on belt dressing a while back. Perhaps it wasn't the belt sueaking but a pulley bearing? My StepDad used wd-40 once a week to quiet a squeak bearing on his belt system. I told him to try JB-80 and it worked 10 times longer.
-T
#551794 - 05/25/04 11:18 PM Re: Belt dressing vs. Multi Purpose Lubricant (WD-40)
2K2AcuraTL Offline
Loc: Ottawa, Ont CANADA
I think I would look for a proper belt bressing, as WD-40 contains some fairly strong solvents.
Just my .02c worth.
Jean
#551795 - 05/25/04 11:54 PM Re: Belt dressing vs. Multi Purpose Lubricant (WD-40)
Lumberg Offline
Yes I read all the previous threads on belt dressing.
I think one factor that I omitted was often the squeaking would have come on immediately after a rainstorm.
In this case it is easy to see where WD-40 would be an option.
#551796 - 05/26/04 12:29 AM Re: Belt dressing vs. Multi Purpose Lubricant (WD-40)
1sttruck Offline
Loc: Camas, WA
A team that I was on at work investigated a bunch of different 'rubber' treatments, including belt dressing. The primary effect that we noticed with belt dressing is that swelled the rubber that we were working on, but the swelling decreased in time.
#551797 - 05/26/04 05:17 AM Re: Belt dressing vs. Multi Purpose Lubricant (WD-40)
TC Offline
Loc: California
Dressings are simply temporary solutions to a belt in need of changing, tightening or deglazing. I've used candlewax in the past since this doesn't permeate or otherwise alter the rubber. But, once again, this was just a temporary solution.
#551798 - 07/15/04 01:51 AM Re: Belt dressing vs. Multi Purpose Lubricant (WD-40)
zoomzoom Offline
Loc: Washington, DC
The other day I changed coolant in my 00 mazda 626 but in the process I spilled some on my drive belts and now when I start car in the morning they will make noise until car warms up.
The car has 83K on it and still original belts. Could it be that coolant damaged the belts?
Could I quiet them down just by washing the coolant off with high pressure car wash?
#551799 - 07/15/04 02:47 AM Re: Belt dressing vs. Multi Purpose Lubricant (WD-40)
Russ Offline
Loc: midwest
83K on original belts? How about replacing them (should be about time anyway)?
#551800 - 08/16/04 06:22 PM Re: Belt dressing vs. Multi Purpose Lubricant (WD-40)
mechtech Offline
Loc: Chicago area
I never had a belt dressing in the shop that made a lasting repair. Usually a day or two.
