Pirelli
by borgward
05/29/16 02:10 PM
'88 Cadillac smog (Emission test) fails
by momo
05/29/16 01:59 PM
Towing what to look for?
by Camprunner
05/29/16 01:48 PM
The Critic's Choice 2014 Yaris vs 2015 Accent
by Gasbuggy
05/29/16 12:52 PM
What Fram Ultra For 95 Cadillac Seville?
by crazyoildude
05/29/16 12:46 PM
Import Multi-Vehicle, Valvoline vs. Castrol, VI?
by Samzone
05/29/16 12:36 PM
Fram Ultra Bypass Valve Spring Life
by Digital2k2
05/29/16 11:32 AM
CARQUEST Filters are now made by Purolator (pics)
by sir1900
05/29/16 11:03 AM
Small 4 Cycle Engines, longevity tips
by henni
05/29/16 10:05 AM
Car won't star after new serpentine belt
by AlaninPA
05/29/16 09:06 AM
Was this sold by Costco?
by Vikas
05/29/16 09:03 AM
Gas or lithium-ion powered string trimmer?
by skyactiv
05/29/16 08:41 AM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
64 registered (123Saab, Astro_Guy, bdcardinal, 4wheeldog, Bandito440, 8 invisible), 1660 Guests and 322 Spiders online.
58013 Members
66 Forums
249560 Topics
#547427 - 12/29/03 01:50 AM Does PVC do ok with gasoline?
Anonymous
Unregistered
I'm trying to fix the pickup tube in a gas tank I have for my generator...can anybody tell me if PVC has any problems coming in contact with gasoline?
#547428 - 12/29/03 02:27 AM Re: Does PVC do ok with gasoline?
Rick in PA Offline
Loc: Southeastern, PA
I think it will depend on the formulation of the PVC. Check www.mcmaster.com, type in "PVC tube" and root around for chemical compatibility charts. Most of the listings for typical PVC tube were "not recommended", but I didn't check all the listings. If it were my project, I'd also soak the tubing in gasoline for a day or two and look for swelling or softening.
#547429 - 12/29/03 02:46 AM Re: Does PVC do ok with gasoline?
DEWFPO Offline
Loc: High in the Rockies
I'm fairly sure the white PVC will not hold up to liquid gasoline. It will eventually get 'soft'.
But I may be wrong.
DEWFPO
#547430 - 12/29/03 05:08 AM Re: Does PVC do ok with gasoline?
Anonymous
Unregistered
I'll just put a peice in a jar with some gas for a few days...don't know why I didn't think about that before...
#547431 - 12/29/03 05:42 PM Re: Does PVC do ok with gasoline?
labman Offline
Loc: Nothern USA
Avoid flexible vinyl. It has low molecular weight materials added to it to soften it. Gasoline will leach them out, leaving it hard, and the material in the carburetor. If you can use a stiff tube, go with polyethylene. Unless it gets hot, it resists gasoline very well. If it must be flexible, try a nylon or urethane. The piece of tubing in a jar is a good test, but not always reliable.
#547432 - 12/30/03 08:01 AM Re: Does PVC do ok with gasoline?
porterdog Offline
Loc: Detroit (Rock City)
quote:
And only waiting a day or two for the effects to become apparent isn't enough, IMO; if you're like most people, your generator doesn't get used much but when you need it you need it. And, if you're like me, when you need it is when the gas-soaked PVC pipe won't work anymore [Smile]
$0.02,
Robert
#547433 - 12/30/03 03:01 AM Re: Does PVC do ok with gasoline?
TC Offline
Loc: California
I'm looking at the Chemical Compatability Chart of my Lab Safety Supply catalog. Compatibility is sometimes affected by temperature. For RIGID PVC and gasoline, it states:
At temp 20C (68F): Good (scale of Xlnt/Gd/Fair/Not Recommended)
At temp 50C (122F): NR
For Polycarbonate: Fair/Fair (68F/122F)
For Low Density Polyethylene: Fair/NR
For High Density Polyethylene: Good/Good
For Polypropylene: Good/Fair
For Flexible PVC: Not listed
How about a good 'ol fashioned rubber/nitrile fuel line..?
[ December 30, 2003, 07:03 PM: Message edited by: TC ]
#547434 - 01/01/04 12:46 AM Re: Does PVC do ok with gasoline?
cryptokid Offline
Loc: palm beach
what about tygon tubing?
