Tundra steering wheel
by RN89
16 minutes 46 seconds ago
98-02 Corolla and Oil Consumption
by mmorri16
17 minutes 28 seconds ago
How does fuel dilution affect HTHS viscosity?
by HKPolice
29 minutes 54 seconds ago
Volkswagen bets big on EV(Electric Vehicle)
by HTSS_TR
37 minutes 7 seconds ago
Did I goof?
by mv6845
54 minutes 13 seconds ago
Opinions on Indestro tools?
by Vern_in_IL
Today at 07:25 PM
Nice bear sighting
by car51
Today at 07:05 PM
Non-directional performance winter tires 205/65-15
by slacktide_bitog
Today at 06:14 PM
Is there a market for a used tool box? w/Pics
by Jimmy9190
Today at 05:18 PM
Review of Sangrean Weather Radio CL-100
by chiefsfan1
Today at 05:18 PM
Round holes AND louvers! Oh the humanity!
by Nick1994
Today at 04:20 PM
Should I change the oil when changing spark plugs?
by THafeez
Today at 04:08 PM
sledhead1, AtillatheHunk, Goofball1205, Djlmedic, BigHoss256
58926 Registered Users
121 registered (2010Civic, 2015_PSD, 01rangerxl, 2002 Maxima SE, 2009Edge, Alex_V, 15 invisible), 1539 Guests and 6 Spiders online.
58926 Members
66 Forums
253559 Topics
Page 1 of 3 1 2 3 >
#529324 - 04/09/05 09:49 AM Mil spec H5606?
jeremiah2360 Offline
Loc: Massachusetts
SeaStar hydraulic fluid is very expensive. Their web site says only to use H5606 Mil spec fluid. Are there any fluids that meet that spec readily available(and cheaper)?
#529325 - 04/19/05 04:38 AM Re: Mil spec H5606?
Loc: Massachusetts
Noticed this list of acceptable fluids on their "fill and purge" instructions;
Texaco HO15
Shell Aero 4
Esso Univis N15
Chevron Aviation Fluid A
Mobil Aero HFA
For convenience I ended up using two of their $15.00 a quart fluid to purge my hydraulic steering [Mad]
#529326 - 04/25/05 09:52 AM Re: Mil spec H5606?
MolaKule Offline
Loc: Iowegia - USA
What is your application, vehicle, machine, etc?
We're not into crystal ball gazering!
#529327 - 04/25/05 03:57 AM Re: Mil spec H5606?
Loc: Massachusetts
Sorry MolaKule(et al), it`s for the hydraulic steering in my 20` boat. More detail in the following link(it`s a single station):
http://www.seastarsteering.com/PDFs/200017-B.pdf
#529328 - 04/25/05 08:41 AM Re: Mil spec H5606?
MolaKule Offline
Loc: Iowegia - USA
I believe this is similar to Skydrol, a phosphate ester fluid for aircraft hydraulic systems.
The only reason I think they are requiring this is for fire safety, since Skydrol is less flammable.
Will do some more checking.
It isn't going to be cheap, which is why you paid $15 per quart.
#529329 - 04/26/05 09:24 AM Re: Mil spec H5606?
DH Offline
Loc: NJ
H5606 is mineral oil based.
H83232 is PAO based.
PEs don't have a number.
#529330 - 04/26/05 08:26 PM Re: Mil spec H5606?
MolaKule Offline
Loc: Iowegia - USA
MIL-PRF-5606, formerly known as MIL-H-5606, MIL-O-5606, and a couple of other numbers, is a mineral based hydraulic fluid.
#529331 - 04/27/05 01:44 AM Re: Mil spec H5606?
Loc: Massachusetts
MolaKule could I use Amsoil universal ATF. It`s an outboard motor so any leak won`t end up on any hot exhaust manifolds or anything. Appreciate your looking into this, thank you [HAIL 2 U!]
#529332 - 04/28/05 03:21 AM Re: Mil spec H5606?
MolaKule Offline
Loc: Iowegia - USA
What's the viscosity of this fluid. Thicker or thinner than ATF?
I don't have the specs that tell what vis the H5606 might be.
#529333 - 04/28/05 04:05 AM Re: Mil spec H5606?
Loc: Massachusetts
I`d assume it`s viscosity would be about the same as Mobil's acceptable substitute which is as follows:
Kinematic Viscosity, cSt
@ 205C -
@ 100C 5.1
@ 40C 13.9
@ -40C 460 (500 max)
@ -54C 1950
@130F 10.7 (10.0 min)
Viscosity Index 370
#529334 - 04/28/05 05:43 AM Re: Mil spec H5606?
Loc: Massachusetts
I found Amsoil`s Shock Therapy Suspension Fluid to be closer than the universal trans fluid in regard to viscosity. The Shock Therapy has seal conditioners and I think an anti-foam add(one test measures percent foam). Would it be better than the trans fluid? [I dont know]
Shock Therapy:
Kinematic Viscosity @ 100C, cSt (ASTM D-445) 4.38
Kinematic Viscosity @ 40C, cSt (ASTM D-445) 15.68
Viscosity Index (ASTM D-2270) 210
Pour Point, C (ASTM D-92) -54
Flash Point, C [F] 175 [347]
Fire Point, C [F] 192 [378]
Four Ball Wear Test (ASTM D-4172: 40kg, 75C, 1200 rpm, 1 hr) Scar Diameter, mm 0.40
Foam, ml (ASTM D-892) Sequence I, II, III 65/0, 60/0, 65/0
Blender Test (25C, low speed, 1 min.) 2.5 mins to settle, 8% foam
#529335 - 04/28/05 05:48 AM Re: Mil spec H5606?
Loc: Massachusetts
OOPS, the above Shock Therapy specs listed are for #5 light. The only other is #10 medium. The medium is closer to the trans fluid specs. Didn`t notice there were two kinds [Roll Eyes]
#529336 - 05/06/05 09:34 AM Re: Mil spec H5606?
Lance Offline
Loc: Austin, TX
If you choose Skydrol, read the MSDS. Also, protect your skin and eyes. It burns like fire on tougher skin, (hands),so use your imagination to guess what it will feel like on more tender, sensitive areas. Wash up good before you "answer the call". We use it in our regional jets' central hydraulic systems. The same jet still uses 5606 in the landing gear struts, though.
#529337 - 05/22/05 10:33 PM Re: Mil spec H5606?
widman Offline
Loc: Bolivia
Often the 5606 spec is used for reasons of convenience.
a 5606 fluid is about 15 cSt at 40
IV around 150
and high insulation value (I think around 35)
It's used in a lot of bucket trucks, but they then allow a diffence for tropical areas, where we they will take a good multigrade hidraulic with the high dielectric strengh. We've used Chevron's Rykon Premium 32 in tropical climates.
#529338 - 05/22/05 11:12 PM Re: Mil spec H5606?
XS650 Offline
Loc: Northern CA
MIL_PRF_5606H info directly from the spec. No need to SPECulate [Big Grin]
MIL-PRF-5606H
Viscosity in centistokes at -54C (max) 2500
Viscosity in centistokes at -40C (max) 600
Viscosity in centistokes at 40C (min) 13.2
Viscosity in centistokes at 100C (min) 4.90
I have the entire spec in .pdf. It's only about 550k in size. If someone wants to host it online for the benefit of the group, I will email it to them.
I someone wants to set up a space to host lube related MIL specs for the use of BITOGgers, I believe I can get any of them in .pdf.
Page 1 of 3 1 2 3 >
