Beginners guide to external ATF filters?
by buck91
08/29/16 11:27 PM
Good ADBV filter?
by asand1
08/29/16 11:18 PM
my brigs hates synthetic
by meborder
08/29/16 10:39 PM
Butcher factory cooler lines?
by buck91
08/29/16 09:47 PM
Grease for marine davit crane
by davebe
08/29/16 09:10 PM
2016 Traverse, which oil would you use?
by chevman4life
08/29/16 09:08 PM
acclimating to heat - tips, please
by pandus13
08/29/16 08:53 PM
95 Ford Ranger - Runs rough, no power
by dsmith41
08/29/16 08:49 PM
False teeth
by Eddie
08/29/16 08:49 PM
Quaker State engine warranty...thoughts?
by ryan2022
08/29/16 08:46 PM
Hicks Oil
by yankees1
08/29/16 08:32 PM
Looking For A Good Battery For 2011 Santa Fe 3.5V6
by crazyoildude
08/29/16 08:18 PM
davebe, Logos, alphanumeric, koidragon1980, iliveonnitro
58961 Registered Users
49 registered (01rangerxl, akela, 69GTX, albertdi, 4WD, 5 invisible), 1275 Guests and 7 Spiders online.
58961 Members
66 Forums
253753 Topics
#521207 - 01/16/06 11:58 PM ATF-3 in Boss snowplow
yooper.mi Offline
Loc: U.P. of Mi
Have always used ATF in my old Western plows, my BOSS dealer says to use ATF-3 in the new plow.ATF-3 is cheap and avilable everywhere I buy gas which is a big plus. A discussion on PlowSite has ATF with wax in it, clogging screens + valves. I would think an auto trans would not even work if this was true.
Is there any thing in ATF that would hurt a pump or valve body on a snowplow. Thoughts or experences on the subject.
thanks
#521208 - 01/17/06 01:15 AM Re: ATF-3 in Boss snowplow
unDummy Offline
Loc: RI
Aren't you suppose to use 'snow plow oil'?
I wouldn't worry about "ATF wax". Thats just **.
What I would worry about is the performance requirements of the plow hydraulics vs. the capabilities of ATF. ATF is an excellent hydraulic fluid. But, is it in the correct viscosity for your plow system? Does it have the correct seal conditioners? ......
What you need are specs of the required fluid. Search for plow oil or milspec 5606.
And, ignore the Boss dealer. Contact Boss directly for their opinion on the products that they sell.
#521209 - 01/17/06 06:45 PM Re: ATF-3 in Boss snowplow
Dick in Falls Church Offline
Loc: Falls Church VA
If you want better cold performance, use a good synthetic ATF.
#521210 - 01/17/06 07:55 PM Re: ATF-3 in Boss snowplow
Mike_dup1 Offline
Loc: USA-Michigan
I use Amsoil synthetic ATF in my Western plow, on the 2nd winter with it in there.
I don't see any benefit to using an ATF+4 fluid though but the synthetic made a big difference in my plow. I don't hear any groan in cold weather any more.
edit
I just called one of my ROTS, his primary business is a Boss/Western dealer/installer (for years), he says Dexron ATF (GM) and does not recommend the other fluids.
Mike
Locale-Lake Superior
[ January 18, 2006, 12:07 PM: Message edited by: Mike ]
