That's unfortunate...or maybe bypass filtration?
by linksep
20 minutes 16 seconds ago
Over Oiling
by mjoekingz28
Today at 12:59 AM
Sweden Trials Electric Higway for Trucks
by Y_K
Today at 12:07 AM
17 yo deutsch filter?
by robo339
Yesterday at 11:07 PM
Ford Focus wrecked
by tig1
Yesterday at 10:13 PM
Valvoline Maxlife vs Supertech Synthetic vs QSED
by mazdamonky
Yesterday at 09:56 PM
Lexus seats in a Camry
by Nick1994
Yesterday at 09:52 PM
shop rechecking work after front end parts replace
by motor_oil_madman
Yesterday at 09:50 PM
M1-EP vs vanilla M1
by Atomic
Yesterday at 09:29 PM
Supertech Synthetic and Citgo
by RRLJR
Yesterday at 09:28 PM
Gun Belt Wanted
by FirstNissan
Yesterday at 08:24 PM
car wash soap for pressure washer
by Donald
Yesterday at 08:16 PM
Josh_Westwood, Brogan, Superlatives, Ruturaj, derfderfgoose
58280 Registered Users
23 registered (Brad_C, Axe Man, Farmer, dino33, 2 invisible), 802 Guests and 10 Spiders online.
58280 Members
66 Forums
250856 Topics
#512922 - 02/19/05 07:23 AM 2002 Toyota Tacoma Automatic Transmission fluid choice
mrdctaylor Offline
Loc: McGregor TX
I am getting ready to do a drain/refill of the automatic transmission in my 2002 Toyota Tacoma double cab. I had been under the impression (for some reason) that it required a Toyota-specific tranny fluid. However, I just got out the owner's manual and it specs "Automatic transmission fluid D-II or DEXRON III (DEXRON II)".
So my question is this: Is it worthwhile to go with Mobil 1 synthetic? Or is it ok to just use a name brand tranny fluid? I use Mobil 1 oil in the engine.
I need something I can buy locally, because I plan to do this tommorow.
Any advice is greatly appreciated.
David Taylor
[ February 19, 2005, 11:37 PM: Message edited by: mrdctaylor ]
#512923 - 02/19/05 09:42 AM Re: 2002 Toyota Tacoma Automatic Transmission fluid choice
Bagger_Matt Offline
Loc: Virginia
The manual stats to use dexron in 4 cylinder models and toyota fluid in V6 models.
#512924 - 02/19/05 09:56 AM Re: 2002 Toyota Tacoma Automatic Transmission fluid choice
deepsquat Offline
Loc: Tacoma ,WA
according to mobile website it is compatible with dextronIII http://www.prod.mobil1.com/index.jsp
#512925 - 02/19/05 10:09 AM Re: 2002 Toyota Tacoma Automatic Transmission fluid choice
mrdctaylor Offline
Loc: McGregor TX
Superglide,
My manual for my 2002 Tacoma PreRunner Double Cab does not differentiate between engines when specifying automatic transmission fluid. Do you have a 2002 Tacoma whose manual states differently?
#512926 - 02/19/05 10:55 AM Re: 2002 Toyota Tacoma Automatic Transmission fluid choice
Bagger_Matt Offline
Loc: Virginia
I have an 04 D-cab Tacoma with a V6 3.4l and auto trans. My manual says dex.3 for 4cyl. and toyota trans fluid for V6.
#512927 - 02/19/05 11:00 AM Re: 2002 Toyota Tacoma Automatic Transmission fluid choice
Bagger_Matt Offline
Loc: Virginia
mrdctaylor ,
Do you run M1 5w30 or 10w30 in your truck? I can't decide which to use?
#512928 - 02/19/05 11:14 AM Re: 2002 Toyota Tacoma Automatic Transmission fluid choice
OldCars Offline
Loc: Schenectady, NY
Been using, on my '96 4Runner 3.4L, various standard Dexron III compatible oils. However, since I've been changing my own oil, switched over to Mobil Syn.
#512929 - 02/19/05 05:29 PM Re: 2002 Toyota Tacoma Automatic Transmission fluid choice
Alan Offline
Loc: MD
I belive Toyota didn't go special type fluid until 03 as I got an 02 Sienna that specifies Dex III.
I have used just used drains and refills of Supertech Dex III ATF and it's performed wonderful.No shudder just nice crisp shifts.
It's so easy and cheap to change that I do it pretty often.
#512930 - 02/19/05 05:48 PM Re: 2002 Toyota Tacoma Automatic Transmission fluid choice
mrdctaylor Offline
Loc: McGregor TX
Superglide,
Thanks for the info. Yes, I believe they changed in 2003 from what I've read. All tacoma trannies took Dexron in 2002 and before.
I live in Texas and use Mobil 1 5W30. I know I could use 10W30 without any issue, but from what I've read 5W30 appears to hold up just as well and adds a little better flow when it is cold. So why not go 5W30?
I change my oil every 6 months (max allowed under warranty) which comes to about 4500-6000 miles for me depending on how much driving I am doing. I've been doing that since it was brand new and have 31K miles on it now. Once I'm out of my 60K mile powertrain warranty, I'll probably extend the drains a little further.
#512931 - 02/19/05 05:53 PM Re: 2002 Toyota Tacoma Automatic Transmission fluid choice
Amkeer Offline
Loc: Florida
I guess I need to pull out my manual since a drain and refill is in order for the Taco. I will be using factory or Castrol ATF if factory is not required. I sure hope I can use the Dexron cause I don't want to be bound to the IV fluids. Hmmmmmmm....
Daily Drives:
-2003 Toyota Tacoma PreRunner,2.7 liter, 4 cylinder, Mobil1 5w30 ODO 13600
-1995 Toyota 4-Runner,3.0 liter,6 cylinder, Mobil1 10w30 ODO 94100
http://community.webshots.com/user/amkeer
#512932 - 02/20/05 12:26 AM Re: 2002 Toyota Tacoma Automatic Transmission fluid choice
JohnBrowning Offline
Loc: USA
My mothers Tundra 03 calls for DEX and we have had great results with Mobil-1 ATF! For what it is worth!
