Cummins: Standpipe in fuel filter needed or not?
by Extreme-Duty
07/01/16 03:36 PM
Napa Canada, Magnatec, Delvac, Napa 15W-40
by Farmer
07/01/16 02:33 PM
Meijer 4 day sale (4th of july weekend)
by Kwuality
07/01/16 02:14 PM
Brakes for 2012 Subaru Legacy
by Picky1
07/01/16 01:56 PM
Microgreen Oil Filter 50% Off Discount Code
by kohnen
07/01/16 01:51 PM
Don't believe the hype of "never change the oil"
by Fsharp
07/01/16 01:30 PM
tzlk to me about aeroflot
by Jetronic
07/01/16 12:21 PM
My extended drain OCI did not go as intended...
by firemachine69
07/01/16 11:10 AM
Honesty
by stockrex
07/01/16 11:04 AM
Valvoline's New "Cobalt" Grease availability
by EdandSherry
07/01/16 10:47 AM
Mobil Delvac 1 5w40: where to buy?
by car51
07/01/16 10:38 AM
Honda EM7000is stored too long with fuel
by henni
07/01/16 10:04 AM
Jennyp, dcdodge, igolfat8, makomike, Alexas
58338 Registered Users
91 registered (Bgallagher, Alex_V, 2015_PSD, andyd, Bebop367, 11 invisible), 1944 Guests and 11 Spiders online.
58338 Members
66 Forums
251106 Topics
#512655 - 02/09/05 04:16 AM PT Cruiser Manual Trans Fluid Change? Manual Says Not Needed.
3000GT VR-4 Offline
Loc: Henderson, Nevada
I looked at the maintenance schedule for my wife's PT Cruiser and it states that the fluid in the manual transmission is good for the life of the vehicle and does not need to be changed. They don't list a recommended spec for the fluid or say how much would be needed. Has anyone ever changed theirs? If so, what did you use? [I dont know] Thanks.
#512656 - 02/09/05 06:04 AM Re: PT Cruiser Manual Trans Fluid Change? Manual Says Not Needed.
TC Offline
Loc: California
From the site below...
"#816. We recently received a question regarding the maintenance schedule and fluid requirement for the U.S. manual T-350 transmission. It seemed like a pretty straightforward question, however while checking the 2001 -2003 service and owners manuals' we discovered a good deal of contradictory information. My thanks to Chuck Schneider for bringing this issue to our attention. I recently contacted DC for clarification and they replied:
Thank you for your email to DaimlerChrysler regarding the Chrysler PT Cruiser. The transmission fluid and maintenance schedules are the same for all model years of the PT Cruiser. For the manual transmission, severe usage requires transmission service every 48,000 miles - please refer to Maintenance Schedule B in the owner's manuals. The recommended manual transmission fluid is Mopar Manual (Type MS-9417) Transaxle Fluid."
http://www.ptdoityourself.net/tl/tl_33.html#816
Although not called for in the manual, personally I'd use Chrysler's "severe usage" spec as a good rule of thumb, and change it out each 50K miles regardless of service intensity. Check the transaxle housing -- evidently it may indicate the proper lube. Any name brand which meets that spec (and is of the proper weight) will do.
Quotes from other webites:
-Capacity is apparently 2.1-2.8 qts.
-The 2004 manual tranny apparently uses ATF+4 instead..??
-Mopar recommends using their Type MS-9417, but does mention gear lubricant meeting API GL-5 and SAE 75w-90.
-There's a sticker under the transaxle housing (near the drain plug) that indicates Mopar Manual Transaxle Lubricant Type MS 9417 be used.
http://ptenthusiasts.org/forum/showthread.php?t=13883
#512657 - 02/09/05 09:35 PM Re: PT Cruiser Manual Trans Fluid Change? Manual Says Not Needed.
3000GT VR-4 Offline
Thanks, TC! [Big Grin]
