2002 GMC Yukon Climate Control Problems
by Kgrant
02/06/16 01:11 AM
Vacuum leak after 3800 intake manifold gasket job
by CaliCarLover
02/06/16 12:17 AM
Pops-a-vent fuel can vent
by 901Memphis
02/05/16 11:08 PM
GM Oil Life Update
by CapitalTruck
02/05/16 10:48 PM
Toyota 2.4L & AWD Ok?
by Nick1994
02/05/16 10:40 PM
0W20 in the US but 5W30 outside US for Mazda
by perryg114
02/05/16 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
02/05/16 08:48 PM
why would someone want to pay with a phone?
by turtlevette
02/05/16 08:16 PM
The connection was reset problem
by Triple_Se7en
02/05/16 08:14 PM
BIG PROBLEM!
by Avery4
02/05/16 08:03 PM
11,000 miles on a BMW
by BigJohn
02/05/16 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
02/05/16 07:20 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
42 registered (AutoCoil, asand1, bbhero, akela, AJP, 4 invisible), 613 Guests and 204 Spiders online.
56834 Members
66 Forums
244295 Topics
#506903 - 05/20/04 09:28 AM Manual Transmission Oil for '94 Toyota Tercel?
FL-400S Offline
Loc: Southeast
My '94 tercel has 76,600 miles and never had a manual trans oil change. Its going to get its first and only trans oil change this summer. Its probably got dino now, but Ill spring for synthetic since Im only going to do this once and drive this puppy into the ground. I just dont drive enough to get it up to 200K in the next 10 years. Ive heard that its unnecessary (not possible) to drop the pan and there is no filter in a manual. So what weight and type of trans oil should I get? I want something I can get at Autozone or Walmart.
Thanks!
#506904 - 05/19/04 11:50 PM Re: Manual Transmission Oil for '94 Toyota Tercel?
HOndaGuy Offline
Loc: Michigan
Whats the manual call for, 10w30 or 10w40? And does it require a gl4 or 5 spec?
#506905 - 05/19/04 11:54 PM Re: Manual Transmission Oil for '94 Toyota Tercel?
FL-400S Offline
Loc: Southeast
I'll have to check that when I get home today.
#506906 - 05/20/04 06:54 AM Re: Manual Transmission Oil for '94 Toyota Tercel?
JohnBrowning Offline
Loc: USA
Well, I am going to guess that Toyota want you to use either a GL4 or GL5 70W90 Gearlube. If it has to be available at Autozone or Walmart I would say M1 or Costal Synthetic.
As far as non-synthetics go I have used Castrol,Havoline,Valvoline,Walmart Brand, Bulk pail from Sam's club and never felt a difference in shift quality or performance in the rear end on Toyota trucks!
Seeing how you have no intensions of changeing it ever again I would definately spring for the synthetic gear lube!
#506907 - 05/20/04 07:14 PM Re: Manual Transmission Oil for '94 Toyota Tercel?
FL-400S Offline
Loc: Southeast
Well I looked over the owners manual last night and it only talked about ATF and clutch fluid, which I presume is more like brake fluid. On the tercel forum a guy suggested Red Line MT-90.
#506908 - 05/27/04 03:55 AM Re: Manual Transmission Oil for '94 Toyota Tercel?
FL-400S Offline
Loc: Southeast
quote:
Originally posted by JohnBrowning:
Well, I am going to guess that Toyota want you to use either a GL4 or GL5 75W90 Gearlube. If it has to be available at Autozone or Walmart I would say M1 or Costal Synthetic.
I found it in the manual finally. Its specs exactly what you said, 2.4 quarts of 75W90, GL4 or GL5. I think I will get dino and run that for a few thousand miles then dump it and put the final fill of Mobil 1. I have a few ounces of Auto-Rx that I didnt need to pour in the 3 quart engine. I wonder if it will do any good in the tranny? It still shifts like new after 76K miles...
