Who watches the oil co's?
by Camprunner
23 minutes 36 seconds ago
Magnetec "Edged" out?
by ARCOgraphite
33 minutes 9 seconds ago
Let's talk RUM
by car51
44 minutes 36 seconds ago
Any .257 Roberts Reloaders On The Site?
by 2015_PSD
Today at 01:18 PM
Making tacos at home
by Reddy45
Today at 12:41 PM
Wiring a new garbage disposal
by Hokiefyd
Today at 11:38 AM
Power Steering Fluid
by DWC28
Today at 10:07 AM
Troy-Built 4.5hp running problem
by Kestas
Today at 09:26 AM
Conventional oil instead of synthetic
by corndogzombie
Today at 08:05 AM
kohler courage 15 issues
by tomm22
Today at 07:58 AM
Small overlap crash test?
by Huie83
Today at 07:39 AM
Top Tier Fuels and Tailpipe deposits
by virginoil
Today at 07:20 AM
Ken_Clifton, HotDog15, curiousaboutoil, 01CAMRY, corndogzombie
58589 Registered Users
91 registered (4WD, Alfred_B, 182RG, AIRJAC3, 87sammy, 2015_PSD, 9 invisible), 2169 Guests and 24 Spiders online.
58589 Members
66 Forums
252234 Topics
#503796 - 12/03/03 04:46 AM Royal Purple Max Gear 75W90 and Red Line MT-90
Grossomotto Offline
Loc: Eldora, Colorado 9000'
Hello,
After reading hundreds of topics on recommended synthetic gear fluids for my 2002 Toyota Tacoma Manual V6 4WD with 12K miles, I've settled on RoyalPurple MaxGear 75W90 and RedLine MT-90 75W90. (Engine is Mobil 1SS 5W30) Tell me what you think and if anyone has any comments on either product below. Thanks.
Redline MT-90 75W90 GL-4 synth gear oil:
Manual Trans
Transfer Case
Royal Purple Max Gear 75W90 GL-5 synth gear oil:
Front Diff
Rear Diff
#503797 - 12/03/03 07:47 AM Re: Royal Purple Max Gear 75W90 and Red Line MT-90
unDummy Offline
Loc: RI
Redline is an excellent manual trans oil. I prefer the MT90 over any other gl4/5 manual transmission oil.
I never did care for RoyalPurple.
Stick with Redline, Amsoil, or use the Mobil1 GL5 for the front/rear gears.
#503798 - 12/03/03 07:39 PM Re: Royal Purple Max Gear 75W90 and Red Line MT-90
pgtr Offline
Loc: tx
Sounds like you've done your homework. When it comes to manual trannies I don't care what 'certain' owners manuals state - there is really no comparison to GL-4.
When it comes to GL-5 applications (differentials...) there's LOTS of synthetic options - I personally have no clue if there truly are any standouts or ones to avoid..... [I dont know]
As for the transfer case - that's a bit of a tough one for me to call. There are no synchro rings typically so there is no reason to use a specialized product such as MT90. Since there are no synchros that is no yellow metal - thus no reason to use a GL-4. Now I'm not 100% sure because I've never personally tore into transfer cases - perhaps someone else can verify? But if so - a GL-5 does offer some added EP protection over a GL-4.
unDummy - when you say you prefer RL over other GL4/5s - as I'm sure you know MT90 is a pure GL-4 only. Have you ever compared RL to any other synthetic (or conventional) pure GL-4s? I realize there are only maybe 2 others out there. I have watched for a long time and looked and gone thru the archives but I'm yet to find even an antecdotal impression on the either of the other two synth GL-4s. It's always been a point of curiosity w/ me. RL enjoys a near perfect monopoly on this segment of lubrication - heck they deserve and don't abuse it in the slightest. That alone scores a few points in my book for the company.
#503799 - 12/04/03 12:36 AM Re: Royal Purple Max Gear 75W90 and Red Line MT-90
unDummy Offline
Loc: RI
I've tried other GL4's(nonsynth), the GL5's(which were compatible to GL4), and some GL5's.
MT90 is by far the best 75/80/90 type of oil out their.
I'm am also planning on ordering some GL4 soy vegetable gear oil for comparison soon.
#503800 - 12/04/03 12:42 AM Re: Royal Purple Max Gear 75W90 and Red Line MT-90
par Offline
Loc: usa
I run a 2001 Toyota Tacoma 4X4 stick shift, and I've tried nearly everything in the transmission. From factory fill, to Amsoil series 2000, to Royal Purple, to Redline MTL, to Redline MT-90.
I finally settled on Amsoil series 2000 and transfered the RP to the differential. I still have jugs of the Redline sitting around in case of an emergency.
OVER ALL: Amsoil was the smoothest shifting. Everything else was just too 'notchy' for my liking.
#503801 - 12/04/03 01:02 PM Re: Royal Purple Max Gear 75W90 and Red Line MT-90
Grossomotto Offline
Well, got most of it done today. The Manual Trans is smooth as butter now with the Red Line MT-90!!
#503802 - 12/04/03 09:25 PM Re: Royal Purple Max Gear 75W90 and Red Line MT-90
Bror Jace Offline
Loc: Saratoga, NY
Grossomotto, why are you splitting up brands? Why not pick one good one and stick with it?
If you like Red Line's MT-90, why not use their GL5 75W90 in the diffs?
Conversely, doesn't Royal Purple make a GL4 gearbox oil? You could use their stuff all the way around if you like that brand.
Just curious. [I dont know]
--- Bror Jace
#503803 - 12/04/03 11:54 PM Re: Royal Purple Max Gear 75W90 and Red Line MT-90
Grossomotto Offline
Bror
Some good questions. I researched this quite extensively on the internet since I haven't used either product before. I read great things about RedLine MT-90 and Toyota Man Trans. Quite right, the stuff is awesome. I also read great things about Royal Purple Max Gear 75W90 in the Diffs. It's got to be better than the facory fill. I got a good deal on a case of the Royal Purple and I'm gonna do my Wife's '02 4Runner, as well.
Actually, the Royal Purple Max Gear is 75W90 GL4 and GL5 rated, so you can use in everyting; man trans, transfer case and f/r diffs! But, the Red Line MT-90 is GL4 specific and works flawlessly with these Toyotas!
#503804 - 12/05/03 12:09 AM Re: Royal Purple Max Gear 75W90 and Red Line MT-90
Grossomotto Offline
Forgot to add
I also use Mobil 1 SS in both trucks. So, I use 3 different oils. I don't like Red Line or Royal Purple for engine oil. For the price, availability and quality ($24 for 5 quart jug at WalMart) you can't go wrong with Mobil 1 SS. Heck, all of these Synthetics are better than the factory fills.
#503805 - 12/05/03 01:20 AM Re: Royal Purple Max Gear 75W90 and Red Line MT-90
MolaKule Offline
Loc: Iowegia - USA
Interesting, since I found just the opposite situation. Amsoil fluids were too notchy and Redline 50/50 mix of MTL and MT90 were the only fluids at the time to cure notchiness and free up shifter in cold weather.
#503806 - 12/05/03 07:17 AM Re: Royal Purple Max Gear 75W90 and Red Line MT-90
Bror Jace Offline
Loc: Saratoga, NY
Like 'Kule, I've had excellent results with the Red Line synchromesh fluids ... and I'm talking over a decade of use.
Spector is/was a big Amsoil fan and even he admitted their gear oils were not as good as Red Line. [I dont know]
I'm skeptical of lubes which claim both GL4 and GL5 status. The additive packages should be significantly different for different applications (gearboxes versus differentials).
Anyway, good luck Grossomotto. I'm sure all the fluids you are considering will work well.
--- Bror Jace
