Mobil 1 0W40 for 3.5L Ecoboost
by mc130fox
06/19/13 01:33 PM
Future hacking/virus issues with newer cars??
by BobsArmory
06/19/13 01:07 PM
GM makes big move up in J.D. Power quality survey
by dishdude
06/19/13 01:05 PM
Ford Going Retro with MyFord Touch
by doitmyself
06/19/13 12:39 PM
Switched from 0w-20 to 0w-30 - No change in MPG
by blackman777
06/19/13 12:17 PM
EZ Pass Question
by supton
06/19/13 12:09 PM
4L60E operating temperature
by Falcon_LS
06/19/13 12:08 PM
quality on Nipparts oil filters
by shDK
06/19/13 12:05 PM
05 4L80E and other Chevy 3500 Advice
by Eric Smith
06/19/13 11:44 AM
Toyota 22RE oil consumption issues. What to try?
by huntsonora
06/19/13 09:52 AM
redline 0w-30 or 5w -30
by matrass
06/19/13 09:32 AM
Just say No to Additives
by blackman777
06/19/13 08:52 AM
Snowball, jin1234, BigDuke6, gl10, ufomorme
45904 Registered Users
137 registered (2009Edge, abycat, 99Saturn, 05LGTLtd, 901Memphis, 123Saab, 10 invisible), 1641 Guests and 247 Spiders online.
45904 Members
64 Forums
195352 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#498219 - 09/19/02 01:25 AM Dextron III
westex39 Offline
Loc: LUBBOCK, TX
Is Dextron IIIE transmission fluid part synthetic?
#498220 - 09/19/02 02:06 AM Re: Dextron III
MolaKule Online   content
Loc: Midwest
For most OTC Dexron III transmission fluids, they have conventional bases or blends of
conventional and synthetic bases. Some are even Group III bases now.
Dexron III is a great improvement over the older Dexron ATF spec as it has a wider temp range, better oxidative stability, and higher viscosity indices, such as 180-200. It is also a 0W20 spec.
#498221 - 09/19/02 05:20 PM Re: Dextron III
jjbula Offline
Loc: Montgomery, AL
MolaKule,
You are wise on ATF. I've seen Dexron III that was not synthetic blend.
Do you know why Mercon V is always a synthetic blend? I suspect it is for the flow properties at -40c, but am not sure.
Why is it better at preventing shudder?
#498222 - 09/19/02 08:14 PM Re: Dextron III
Loc: Midwest
Golly JJ, don't know for sure but full synths resist oxidation much better and Ford has one heck of a qualification test. Could be the synth's are only one that qualifies.
Many of the late spec'd ATF's also have certain additives for the internals that work with particular trnasmission.
