My upper sidewall pinehole leak fix
by Pokermatters
07/26/16 07:52 PM
QS filters 'closer' to OEM quality?
by addyguy
07/26/16 07:44 PM
Need tire experts regarding tire wear pattern.
by ST2008
07/26/16 07:18 PM
Best not drying grease
by ST2008
07/26/16 06:56 PM
Honda GCC160 crank question
by FastLane
07/26/16 06:55 PM
by Pokermatters
07/26/16 06:52 PM
Sunl Scooter Troubleshooting
by yeehaw1960
07/26/16 06:47 PM
Ozonated Distilled Water in the Cooling System
by ZeeOSix
07/26/16 06:42 PM
2001 Honda Accord 4 cyl
by gmh101357
07/26/16 06:25 PM
No Oil Additives with MDS System - Ram 2500 6.4L
by Dexters
07/26/16 05:39 PM
Benefit f a throttle body spacer
by otis24
07/26/16 05:31 PM
Ford Focus Strut Replacement
by tig1
07/26/16 04:59 PM
lowsapsdieseloil, kit2523, rfabrocini, Tobin28, r0k
58600 Registered Users
115 registered (182RG, 2015_PSD, ABerns, 4WD, 8o8is, 14 invisible), 1934 Guests and 22 Spiders online.
58600 Members
66 Forums
252285 Topics
#494139 - 02/27/05 03:26 AM Fram vs. Purolator Air Filters
netsfan Offline
Loc: North Jersey
Despite all the negative things people have said about Fram, the air filter for my application (CA8606--2000 Dodge Intrepid 3.2) looked pretty good, so I decided to give it a try.
I went to a store that carries Fram, Purolator, and STP. The STP was out of my size, so I could only compare Fram and Purolator. The Fram has 71 pleats (just like the Mopar OEM) while the Purolator has only 55. Aside from pleat count, the Purolator looked and felt more flimsy. I was quite surprised.
The Fram and the OEM Mopar filter were visually similar (the Fram had slightly larger grate-holes, but the material looked and felt like the same stuff). I wouldn't be surprised if the Mopar filter is Fram product.
#494140 - 02/27/05 08:02 AM Re: Fram vs. Purolator Air Filters
ruking77 Offline
Loc: San Jose area, CA
I would have no qualms in running Fram air filters. I think some side by side UOA's running FRAM's against other have shown Fram air filters to do a repectable job (silicon values in the oil) despite concerns about its construction. While I haven't run Fram air filters in quite a while, I did buy a Fram for a new Honda Civic that will not need it for another 24,000 miles.
#494141 - 03/02/05 05:50 AM Re: Fram vs. Purolator Air Filters
Blokey Offline
Loc: GA, USA
The construction of FRAM oil filters is what many people have an issue with; their air filters appear to be as good as any other name brand paper filter.
#494142 - 03/03/05 07:25 PM Re: Fram vs. Purolator Air Filters
Mike_dup1 Offline
Loc: USA-Michigan
I compared the Fram filter to the AC Delco filter for my 1992 Chevy truck. The Fram was smaller in thickness and appeared to be lower quality when compared to the AC Delco. It did not fit the housing axactly right becuase the OD diameter was smaller
