I just pulled down several SAE reports on air cleaners after reading this forum and learning how important clean air is to engine wear. In the past, my focus had been on oil filters and little regard for air filters. The below facts shocked my base line thinking about air cleaners and my service intervals.
SAE reports key findings:
1) Air cleaners initial efficiency vs final are quite large and depending on initial efficiency could affect engine wear significantly.
2) It is a known fact, from several SAE reports, that engine wear is greater at the initial (5-15%) life of a air cleaner vs the final efficiency.
3) Most high quality air cleaners under normal conditions can go from 30k+ miles to 80K+ miles.
4) Most end users over service their air cleaners and never get the full efficiency and therefore have greater engine wear in the process. Not to mention higher operating cost.
So, after reading this, I wondered were I had gotten the idea that I should change an air cleaner around 7K-8k miles. Since I don't go the max on the oil change, changing the air cleaner more aggressively just seemed to be a 'smart ' thing. I never gave it a thought until now.
Interesting, one of the SAE reports was by Purolator/ArvinMeritor that even tested a filer to 20K+ miles and stated that the service life was within 20-25%. So the filter could go easily to 80-100K miles. But if you look at the Purolator marketing web site they state- 'Purolator recommends replacing your air filer with a new Purolator air filer every 7,500 miles, unless otherwise specified by the manufacturer.'
So now I know why. It does not change the fact that I was over servicing my air cleaner with no benefit and actually increasing my engine wear.
