2002 GMC Yukon Climate Control Problems
by Kgrant
13 minutes 10 seconds ago
Vacuum leak after 3800 intake manifold gasket job
by CaliCarLover
Today at 12:17 AM
Pops-a-vent fuel can vent
by 901Memphis
Yesterday at 11:08 PM
GM Oil Life Update
by CapitalTruck
Yesterday at 10:48 PM
Toyota 2.4L & AWD Ok?
by Nick1994
Yesterday at 10:40 PM
0W20 in the US but 5W30 outside US for Mazda
by perryg114
Yesterday at 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
Yesterday at 08:48 PM
why would someone want to pay with a phone?
by turtlevette
Yesterday at 08:16 PM
The connection was reset problem
by Triple_Se7en
Yesterday at 08:14 PM
BIG PROBLEM!
by Avery4
Yesterday at 08:03 PM
11,000 miles on a BMW
by BigJohn
Yesterday at 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
Yesterday at 07:20 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
42 registered (AutoCoil, asand1, bbhero, akela, AJP, 4 invisible), 611 Guests and 204 Spiders online.
56834 Members
66 Forums
244295 Topics
#488887 - 05/28/06 07:46 PM Kawasaki 25HP FH721V breakin
ssmokn Offline
Loc: USA
I've got a zero turn mower with a Kawasaki 25HP FH721V vertical shaft 4 cycle air cooled engine.
Kawi basically recommends 30 weight or 10W30. The mechanics tell me that they motors do best on 30 weight. So far I've only got 8 hours on the unit but I have changed the oil 3 times with 30HD (Havoline).
Two questions:
1) How many hours should I put on this motor before switching to synthetic
2) Which one of the following would you use. I have a pretty good supply of all of them
- Delvac/T-SUV 5W40
- Castrol GC 0W30
- Mobil 1 10W30 (older Super Syn formula)
or should I just stick with
- Havoline 30HD or Trop Artic 10W30
Decisions, decision! I'm not trying to extend my OCI (at 2 quarts with the filter the money isn't an issue) but rather make sure the motor is well protected.
#488888 - 05/29/06 09:44 AM Re: Kawasaki 25HP FH721V breakin
like a rock Offline
Loc: Petersburg, West Virginia
Look at your owners manual which should tell you when synthetic will work. On my new kohler it states at 25 hours you can use it.
#488889 - 05/30/06 11:17 AM Re: Kawasaki 25HP FH721V breakin
Locomotive Offline
Loc: Kansas City
run the oil for 40 hours then change the oil and filter. Then its ready for syn. My ztr has a 23 kawi (420 hours) but it doesnt seem to fond of maxlife syn so far. So i might go back to 30 wt rotella or try some m1 0/30 that i have in my stash. I dont know what oil filter you are using but an ac1233 will work just fine. Use that # and cross ref it to other brands so you dont have to buy from the stealer. A clean air filter is key to small engine longevity. If you mow commercially or in dusty dry areas then consider a donaldson 3 stage air fiter system. It bolts right on and is standard equipment on exmark mowers. That will keep abrasives from entering your engine that the stock filter and wrap will not. Regardless of what dino oil you use, change it every 40 hours. Once a year remove the engine cover and remove any chaff as this retains heat. My last bit of advice is before you shut down the engine after a good run always let the engine run at say 1/3 throttle for 5 minutes so it can cool off.
#488890 - 05/31/06 05:46 AM Re: Kawasaki 25HP FH721V breakin
ssmokn Offline
Loc: USA
The mower is a Hustler Super Mini Z. It comes stock with the Donaldson canister.
I have 1/2 dozen OEM oil filters but I also have some SuperTech ST4967.
I always run at about 1/3 throttle before shutting down. I don't mow commercially (just my own) but thanks for the advice.
