Battery or starter
by Dallas69
08/27/16 07:56 AM
Napa Syn 15w50 to replace BradPenn 20w50 in 454bbc
by FlyNavyP3
08/27/16 07:51 AM
Real Main Seal Leak ? ? ?
by larryinnewyork
08/27/16 07:35 AM
Gov't wants to lower speed limits for trucks
by JetStar
08/27/16 07:11 AM
GM 55560202 longlife cut open - 10782km
by turboseize
08/27/16 04:54 AM
Coolant Question.
by Farmer
08/27/16 04:20 AM
Stocking up for the Eco
by buck91
08/27/16 12:25 AM
Mobil 1 10w40 HM
by SubyRoo
08/27/16 12:16 AM
What type of glue for door panels?
by Nick1994
08/27/16 12:07 AM
Painting rear of chrome bumpers
by buck91
08/26/16 11:09 PM
Walmart Rifle Clearance
by hatt
08/26/16 10:44 PM
Vehicles That Must Idle For Long Periods Of Time
by BlueOvalFitter
08/26/16 10:30 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
77 registered (AirgunSavant, 4WD, A310, 97f150, 3800Series, 2009Edge, 4 invisible), 1293 Guests and 37 Spiders online.
58935 Members
66 Forums
253614 Topics
#488148 - 04/05/06 06:24 AM stihl bg55 blower problem
nomochevys Offline
Loc: Ky
I need help. My stihl bg55 started acting up and would not run right. When you gave it full throttle it bogged out and died. I replaced the fuel line and was told that it was a common problem. I cant get the fuel bulb to pump up like it should but anyway It will still run. Same result. Give it full throttle and it dies. Fuel filter is clean as a pin. I have a fuel starvation problem that I cant solve. Any suggestions?
#488149 - 04/07/06 04:59 AM Re: stihl bg55 blower problem
Tim_Z Offline
Loc: KC, Mo
I would look for a split in the plastic line or bulb. Sounds like there is a leak in the vacuum not letting fuel to be drawn into the carb. That or the check valve that the priming system would have to have is not working correctly. Sorry i cannot be specific but I don't have a service manual for my BG55.
Tim
#488150 - 04/07/06 08:43 AM Re: stihl bg55 blower problem
krodad Offline
Loc: Boone, IA
Had the same problem with my stihl blower...after only one season the fuel line had gone bad...somehow they used line that was not compatible with gasoline. Guess I should have used water.
Took it back to the dealer, and they replaced real fast and without question. They had told me about the known issue with the fuel line, and Stihl put out the equivalent of a technical service bulletin (should have been a recall) to fix this as it could be a dangerous fire situation. Mine was bad enough it leaked, and ran like a turd, as well as hard to start. I'd take it to your dealer and have them look at it and replace the fuel line for free.
#488151 - 04/07/06 09:16 AM Re: stihl bg55 blower problem
80caprice Offline
Loc: N.C.
Have you taken a look at the spark arrestor? Could be clogged.
