My $250 Saturn climbed Mt Washington
by eljefino
07/24/16 03:07 PM
Coolant change issue
by renegade_987
07/24/16 03:05 PM
Shell X100 30/40?
by FordCapriDriver
07/24/16 02:59 PM
Do you reuse ring gear bolts?
by buck91
07/24/16 02:54 PM
Wonder if anyone with NASCAR has noticed...
by mrsilv04
07/24/16 02:42 PM
Brake Pad Anti Rattle Clips
by Miller88
07/24/16 02:02 PM
Video: Napa Proselect 21334 cut open
by cronk
07/24/16 01:12 PM
what viscosity on a new build? 351W/408 street
by tomcat27
07/24/16 12:14 PM
What is this plant?
by skyactiv
07/24/16 11:16 AM
Recycling
by mjoekingz28
07/24/16 10:30 AM
Craftsman Action Bypass Lopper ~$11.70
by Sayjac
07/24/16 09:51 AM
2017 Fusion Hybrid
by AirgunSavant
07/24/16 09:50 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
80 registered (Abdulla, 09_GXP, bdcardinal, AandPDan, bbhero, barkingspider, 8 invisible), 2005 Guests and 9 Spiders online.
58578 Members
66 Forums
252193 Topics
#486481 - 07/03/05 01:49 AM B&S dipstick vs fill capacity
OiledMustangGT Offline
Loc: Louisiana
OK, i have a pretty new 6.5hp b&S engine. i drain the oil out of the bottom fill plug for a good 10 minutes. it has drained pretty good.
the dipstick says 20oz. so i add 18oz, let it sit and check the level (it is above full) i drain out about 2 oz, for 16oz of fill total. it now reads just above full.
Question is? which would you trust? the dipstick or the stated capacity? 4oz short is almost 20% of the fill capacity on this thing
#486482 - 07/03/05 05:30 AM Re: B&S dipstick vs fill capacity
TallPaul Offline
Loc: By Detroit
Is the dipstick supposed to be read with the cap screwed all the way in (most I assume are like this), or just sittin on the top of the opening (my Honda 5 hp engine says this)?
#486483 - 07/03/05 07:09 AM Re: B&S dipstick vs fill capacity
Loc: Louisiana
i am taking the reading with the cap/dipstick all the way in
i did not see anything that said specifically either way
ill double check the manual
#486484 - 07/03/05 08:37 AM Re: B&S dipstick vs fill capacity
tom slick Offline
Loc: Central Coast, Calif.
on quite a few "small engines" you are not supposed to screw the dipstick in when checking the oil, just dip to the top of the threads and check it.
#486485 - 07/03/05 11:19 PM Re: B&S dipstick vs fill capacity
jsharp Offline
Loc: Outside smalltown, IL
Briggs didn't change the height of the lower casting when they went to the dipstick and plastic fill tube. They just quit cutting threads in the casting for the old pipe plug. Correct oil level is to the top of the lower casting fill hole.
You can tell where that is by holding the dipstick beside the plastic filler tube and see how it lines up with the top of the engine casting.
I think you'll find it should be screwed all the way in...
#486486 - 07/03/05 11:29 PM Re: B&S dipstick vs fill capacity
Larry the Cable Guy Offline
Loc: Big Bear Lake, CA
My Honda mower is with the dip stick NOT screwed in.
#486487 - 07/04/05 12:26 AM Re: B&S dipstick vs fill capacity
Loc: Louisiana
well it is a plastic cap/dipstick thing that "screws" in with half a twist of the cap
i checked the manual and it said check with the dipstick all the way in, (did not say screwed in tho)
i will check to see how the dipstick lines up on the side
#486488 - 07/04/05 07:03 AM Re: B&S dipstick vs fill capacity
Blue99 Offline
Loc: Wisconsin
Briggs is not clear, even at The Briggs Website on the issue of inserting or screwing the dipstick down to the home position.
I've always pushed the dipstick down as far as it goes & checked the level at that point! [Smile]
#486489 - 07/08/05 11:01 AM Re: B&S dipstick vs fill capacity
DaveJ Offline
Loc: Auburn WA
I do think its just seated but not screwed in. You may need to run it and then top it off. My old 10 year old Quamtem B&S would read full till I ran it and then was down about 2.5 OZ. DaveJ
