Trans/Hydraulic Fluid for Old Tractor?
by 333jeffery
02/12/16 04:27 PM
Does air go stale?
by mjoekingz28
02/12/16 04:13 PM
RAILROAD GUYS: What is this sound and one other Q
by SumpChump
02/12/16 03:59 PM
Got a free 5gal bucket of Mobil SHC 627
by MinamiKotaro
02/12/16 02:59 PM
Hard starting LCT snow engine..
by JTK
02/12/16 02:34 PM
low-temperature oil gelling reversible?
by DrRoughneck
02/12/16 12:51 PM
I HAD to do it!
by Kuato
02/12/16 12:24 PM
Why Erin Esurance vanished from TV
by Benzadmiral
02/12/16 11:39 AM
Engine Light Advice
by coopns
02/12/16 11:14 AM
Caution UOA - PP 10W30 6881m on 2001 Jeep 4.0
by Donald
02/12/16 11:09 AM
What happened to the thin oil movement?
by camrydriver111
02/12/16 10:57 AM
Mastercraft Strategy tires (I'm cheap)
by Bgallagher
02/12/16 10:41 AM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
100 registered (333jeffery, 2010Civic, 18LateModelFan, 97K15004WD, 901Memphis, 19kj57, 10 invisible), 1718 Guests and 193 Spiders online.
56901 Members
66 Forums
244606 Topics
#485414 - 03/20/05 05:31 PM JOHN DEERE OIL FILTER CROSS REFERENCE
MADMIKE Offline
Loc: RHODE ISLAND
DOES ANYONE HAVE ANY CROSS-REFERENCE INFORMATION FOR A JOHN DEERE OIL FILTER AM125424C? THEY APPEAR TO BE MADE BY CHAMPION LABS AND HOME DEPOT GOUGES, I MEAN CHARGES $10 FOR THEM--I'M TRYING TO FIND OUT IF I CAN PURCHASE A REPLACEMENT FILTER A LOT CHEAPER UNDER OTHER BRAND NAMES SO I NEED CROSS-REFERENCE INFORMATION. (SUPERTECH,STP,VALUECRAFT, FRAM, PUROLATOR, ETC)
#485415 - 03/20/05 06:25 PM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
doitmyself Offline
Loc: MI
Madmike'
My NAPA (WIX) catalog lists an AM125424 (no "C") cross referencing to a NAPA filter 1056. 1056 crosses over to a Purolator L35310.
If these are not common car filters, they may not be stocked at many places. A NAPA gold will run about $5 to $6.
As always, I tell everyone to confirm these numbers for yourself. Cross referencing sometimes yields mistakes.
#485416 - 03/20/05 06:25 PM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
97 GTP Offline
Loc: LI, NY
Here's a list I originally found on here, I made a few revisions to.
code:
"Briggs type"
3/4" X 16 threads 8-11 PSI Bypass
Gasket 2.734"OD 2.430"ID 0.226" thick
Length" Wix Puroltr Hastings Fram Kohler B&S Baldwin JD TEC MotorCraft AC
2.3" 57035 NA LF503 PH8170? 2805001 492932 B7165 ? 36563 NA PF1279?
2.7" 51056 L35310 LF302 PH8172 1205001 492932 B1410 AM125424 36262 NA PF2210
3.4" 51348 L10241 LF157 PH7575 5205002 491056 BT223 AM101207 ? FL793 PF53
4.8" 51516 L20195 LF134 PH3600 NA NA B243 ? ? FL400A PFL400A
quote:
#485417 - 03/21/05 08:09 AM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
MADMIKE Offline
Loc: RHODE ISLAND
THANKS GUYS!
#485418 - 03/21/05 04:51 AM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
Brett Miller Offline
Loc: Arizona
I use a Delco PF53 on mine.
#485419 - 03/21/05 07:31 PM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
97 GTP Offline
Loc: LI, NY
I just bought a ST3614 (492932 Briggs) filter for my Craftsman. It's easier to remember to that a filter from a 95 Neon will cross to the tractor, the only difference is the length.
i found the info here and gardenweb.
#485420 - 03/22/05 08:01 AM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
FowVay Offline
Loc: Southeastern USA
My JD LX178 uses the same filter as a 1991 Geo Prizm. It crosses over to a Fram PH4386 or a ACDelco PF1234.
My engine is a Kawasaki 2-cylinder waterpumper and I don't believe it uses the same filters as the Home Depot products.
#485421 - 03/22/05 04:11 AM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
Stooge Offline
Loc: Ellicott City, MD
The Motorcraft FL 400S will fit!! Longer than the 3614 and with a "real" bypass valve up front. Funny thing, the same filters fit my Toyota Tundra's V8 - so I only have to purchase one filter size for the truck and tractor [Smile] !!
#485422 - 03/23/05 05:25 AM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
Razl Offline
Loc: CT
quote:
Hey, me too. This is the same size as my Saab so it's a coincidental convenience [Big Grin]
The bypass relief is higher than the JD filter but I haven't experienced any problems or oil pressure changes.
#485423 - 04/04/05 08:46 PM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
MADMIKE Offline
Loc: RHODE ISLAND
Are these direct cross-references from a catalog or are you guessing based on filter dimensions? I'm just wondering why the ST 3614 does not come up as a cross reference in any of the catalogs or the Motorcraft---is there any danger in using these instead of the direct cross referenced filters from the chart above which I have confirmed? Thanks!
#485424 - 05/04/05 07:21 PM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
97 GTP Offline
Loc: LI, NY
Some of the cross references take a little more work. The 3614 cross to a fram based on gasket, can size and bypass. Some of the above cross references can't be found on automotive shelfs which negates the purpose.
I just look up a 95 Dodge Neon, that's my cross and easy to remember.
#485425 - 05/09/05 06:01 AM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
segfault Offline
Loc: KY
I am late to the party, judging from the date of the original post, but you might try a John Deere tractor dealership for the filters. My experience is that the Deere mowers themselves are expensive, but service and especially parts are cheap.
#485426 - 05/09/05 06:20 AM Re: JOHN DEERE OIL FILTER CROSS REFERENCE
Bror Jace Offline
Loc: Saratoga, NY
"My experience is that the Deere mowers themselves are expensive, but service and especially parts are cheap."
I guess that varies from dealer to dealer. The dealer close to me is quite expensive. [Frown]
What would you consider 'cheap' for a John Deere brand oil filter? I can't imagine it would be around $2-4.
--- Bror Jace
