Low cost sedan looks better than expensive one
by HTSS_TR
08/23/16 08:22 PM
Toyota red in motorcycles/snowmobi
les
by Altydoc
08/23/16 07:42 PM
Looking at some old posts
by Oldmoparguy1
08/23/16 07:35 PM
Towing a heavy trailer
by Donald
08/23/16 07:31 PM
Envelope Budget System
by GMFan
08/23/16 06:37 PM
Saving OPE after a flood?
by Geauxtiger
08/23/16 06:18 PM
Late 80s/early 90s oil tech
by Pepsibottle1
08/23/16 06:08 PM
Best MT Fluid?
by mattri
08/23/16 05:48 PM
Harvest King full synthetic $11.99 5 qt dexos
by paulswagelock
08/23/16 05:41 PM
AC Delco vs Moog
by 007
08/23/16 05:34 PM
1998 Volvo C70
by ET16
08/23/16 04:57 PM
Makita Air Compressor Help
by GGorman04
08/23/16 04:25 PM
TonyG9050, krishna, Chuck1970, skylerG, LeeG
58890 Registered Users
98 registered (69GTX, 2002 Maxima SE, 2010Civic, 09_GXP, 04SE, 2KBMW, 8 invisible), 1725 Guests and 8 Spiders online.
58890 Members
66 Forums
253472 Topics
#483548 - 05/02/04 06:17 PM 10 HP Briggs & Stratton - Mobil 1 or GC?
C4Dave Offline
Loc: Tennessee
I did a search, and didn't see an answer to this. I just bought a 10 hp B&S riding mower. The manual says to change the oil after 5 hours of break in. Would I be better served with Mobil 1 10w30 or 0w30 German Castrol? The Mobil 1 has moly and boron, but the Castrol is slightly thicker and may not break down as much. But then again, maybe the thinner Mobil 1 would be better for cooling?
As an aside, the break in oil sure smells bad. Sulfur?
#483549 - 05/02/04 06:48 PM Re: 10 HP Briggs & Stratton - Mobil 1 or GC?
Stooge Offline
Loc: Ellicott City, MD
Either is great, but I would stick with the 10W30 as it is specified in your owner's manual over the 0W30.
#483550 - 05/02/04 08:51 PM Re: 10 HP Briggs & Stratton - Mobil 1 or GC?
D C Anderson Offline
Loc: TN
I have used Mobil 1 15W50 in my B&S 14 HP lawn mower since I bought it new 12 years ago. I have changed the oil twice in 12 years. I used a white paper towel to check the oil level with and monitored the color. The oil has stayed clear for 6 years and the pucker factor kicked in and I changed the oil. The oil still looks new. I mow an 1 acre lot as often as needed. Mobil 1 good stuff.
#483551 - 05/02/04 08:53 PM Re: 10 HP Briggs & Stratton - Mobil 1 or GC?
Bror Jace Offline
Loc: Saratoga, NY
As I've said in the other threads about B&S, I don't take their recommendations as gospel. Still, I don't think you can go wrong with any decent 30 weight oil.
So, your question is: "Which one of the two?"
Well C4Dave, you've got a handle on the strengths and weaknesses of the two oils. If this were 3+ years ago, I wouldn't even consider Mobil 1 (SJ formulations).
I guess I'd prefer the GC ... but both are probably overkill.
My Honda 214 mower uses to smoke on start-up with Mobil 1. But I switched to Schaeffer 15W40 and it stopped doing that ... even after sitting all winter.
--- Bror Jace
#483552 - 05/03/04 09:36 AM Re: 10 HP Briggs & Stratton - Mobil 1 or GC?
Blue99 Offline
Loc: Wisconsin
The UOA results for both M1 10W-30 and GC 0W-30 indicate that both oils tend to shear very little & hold their viscosity. The numbers typically posted for M1 10W-30 are in the low 60ís, GC 0W-30 are the low to mid 60ís. Expect similar results from either one.
In these air cooled small engine applications, Iím a fan of the idea that 30 weight syn oils give up heat quicker than the heavier viscosities or dino oils & result in slightly cooler engine temps.
#483553 - 05/03/04 12:02 AM Re: 10 HP Briggs & Stratton - Mobil 1 or GC?
mrdctaylor Offline
Loc: McGregor TX
I bought a 10HP B&S riding mower last year and put Mobil 1 10W30 in it after the initial 5 hour break in. Its great stuff. The mower starts up quickly and runs great. No, this isn't a long-term test. I've only had it a year, but everything seems great with M1.
