My $250 Saturn climbed Mt Washington
by eljefino
07/24/16 03:07 PM
Coolant change issue
by renegade_987
07/24/16 03:05 PM
Shell X100 30/40?
by FordCapriDriver
07/24/16 02:59 PM
Do you reuse ring gear bolts?
by buck91
07/24/16 02:54 PM
Wonder if anyone with NASCAR has noticed...
by mrsilv04
07/24/16 02:42 PM
Brake Pad Anti Rattle Clips
by Miller88
07/24/16 02:02 PM
Video: Napa Proselect 21334 cut open
by cronk
07/24/16 01:12 PM
what viscosity on a new build? 351W/408 street
by tomcat27
07/24/16 12:14 PM
What is this plant?
by skyactiv
07/24/16 11:16 AM
Recycling
by mjoekingz28
07/24/16 10:30 AM
Craftsman Action Bypass Lopper ~$11.70
by Sayjac
07/24/16 09:51 AM
2017 Fusion Hybrid
by AirgunSavant
07/24/16 09:50 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
80 registered (Abdulla, 09_GXP, bdcardinal, AandPDan, bbhero, barkingspider, 8 invisible), 2005 Guests and 9 Spiders online.
58578 Members
66 Forums
252193 Topics
Page 1 of 2 1 2 >
#476990 - 12/01/04 11:58 AM GM EOS additive
rugerman1 Offline
Loc: .
GM Engine Oil Supplement ,Item #:1052367
ANA Labs
code:
iron         5
chrome 1
lead 1
copper 0
tin 0
alum 1
nickel 1
silver 0
silicon 10
boron 2
sodium 978
mag 877
calcium 2583
barium 7
phos 6144
zinc 6290
moly 2
titanium 0
vanadium 1
potassium 4
fuel 0.00
[email protected]C 36.3 cSt
water 0.05
solids 0.00
glycol pos(?)
[ December 02, 2004, 03:25 PM: Message edited by: rugerman1 ]
#476991 - 12/01/04 03:34 PM Re: GM EOS additive
427Z06 Offline
Loc: Austin, TX
Wow! That some serious quantities of additives there.
Look at that sodium level! This VOA is priceless to anyone trying this stuff and doing a UOA. Otherwise they'd think someone was pouring road salt into their engine. [Big Grin]
How much is this stuff nowadays?
#476992 - 12/01/04 04:58 PM Re: GM EOS additive
427Z06 Offline
Loc: Austin, TX
#476993 - 12/01/04 05:40 PM Re: GM EOS additive
Shadohh Offline
Loc: Pottstown, PA
would like to have seem some moly.
#476994 - 12/01/04 05:45 PM Re: GM EOS additive
novadude Offline
Loc: Shippensburg, PA
With all that zinc, it is no wonder this additive is recommended when breaking in a flat tappet cam!
#476995 - 12/01/04 06:19 PM Re: GM EOS additive
ebaker Offline
Loc: TX
1 ounce/quart would add 190 ppm zinc. Is there any reason not to add a small amount of this at each oil change?
#476996 - 12/01/04 06:28 PM Re: GM EOS additive
boxcartommie22 Offline
Loc: moutain country
valvoline's synpower oil additive has all that plus has good amt. of moly and boron
#476997 - 12/01/04 07:27 PM Re: GM EOS additive
Shadohh Offline
Loc: Pottstown, PA
quote:
Yep and Anitmony [Smile]
#476998 - 12/02/04 08:34 AM Re: GM EOS additive
T-Keith Offline
Loc: MN
quote:
I guess we know some of the addatives, but what about the base stock? A cheap or too thick base stock may not be desirable if your adding it to a good GrouP II, III, or IV oil. Does it have any VIIs?
#476999 - 12/01/04 11:24 PM Re: GM EOS additive
rugerman1 Offline
Loc: .
Added moly to the initial report,2ppm.I called ANA today and asked them to re-run the sample.They did and got a similar number.
#477000 - 03/16/05 09:28 PM Re: GM EOS additive
fuel tanker man Offline
Loc: wytheville, va
What's all the sodium in this stuff supposed to be for?
Anybody know? [Confused]
#477001 - 03/16/05 09:39 PM Re: GM EOS additive
rugerman1 Offline
Loc: .
#477002 - 03/16/05 09:47 PM Re: GM EOS additive
TallPaul Offline
Loc: By Detroit
The link provided by 427Z06 shows the product as labeled an "Assembly Lube." I would be concerned about using this stuff for regular oil additive unless the company says you can.
#477003 - 03/17/05 05:17 AM Re: GM EOS additive
Loc: wytheville, va
Paul, that may be true--your caution flag is noted... [Smile]
I don't know how reliable the infomation is, and I can't recall now where I found it, but I read that GM changed the nomenclature of the product because it now contains too much ZDDP to meet the newer standards. So they can't recommend it for "general use" now.
E.O.S. stands for Engine Oil Supplement, and then they add the words "Assembly Lubricant" to that...
This product seems to contain the largest concentration of ZDDP of any I've looked at. Makes Valvoline SynPower look tame. [Smile]
I haven't made any firm decision to pour an ounce or two into my motorcycle oil just yet...
Dan
#477004 - 03/17/05 05:21 AM Re: GM EOS additive
Loc: wytheville, va
By the way... this GM EOS stuff isn't hard to find. Two different GM dealers (Chevy and Pontiac) in my little town both had it. Full retail, [Frown] though, at $8.55 for a 16 ounce bottle.
Still, if one ounce per quart would boost ZDDP by 170 to 200 ppm it wouldn't be a bad deal--provided it didn't make my UOA's look like I'd been running Redline or something such... [Razz] [Big Grin]
Dan
Page 1 of 2 1 2 >
