Wix coolant filter change and cut open
by A310
05/31/16 03:45 AM
O2 Sensor Voltage
by Falcon_LS
05/31/16 01:36 AM
Electrical shock at the grocery store
by Merkava_4
05/30/16 11:42 PM
Another should I change my oil thread
by dan_erickson
05/30/16 10:53 PM
new HDM part number for lacrosse headlamp recall
by lucerne06
05/30/16 08:48 PM
snapper blade control is stiff
by edwardh1
05/30/16 08:44 PM
is my extension cord bad?
by motor_oil_madman
05/30/16 08:33 PM
Done with Sandisk USB Sticks
by JHZR2
05/30/16 08:20 PM
Pineapple Margaritas
by sleddriver
05/30/16 08:12 PM
Replacing Drywall In The Bathroom (Insulation)
by Warstud
05/30/16 07:56 PM
351W build with a flat tappet
by ssregal39
05/30/16 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
05/30/16 07:12 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
31 registered (bourne, chrisri, ActionJoe, BigD1, czbrian, car51, 6 invisible), 514 Guests and 316 Spiders online.
58031 Members
66 Forums
249618 Topics
#469962 - 04/06/05 07:34 PM What oil to use in a Honda ATV?
drive it forever Offline
Loc: Grove City, OH
My brother has a honda atv sportrax 250 ex. I might be buying it off of him, he wants a 4x4 atv. Its air cooled, has the typical shared engine/tranny oil set up and has an auto clutch. He uses 10w40 castrol gtx in it. He is the type that wont read anything, just blurts out, I was told not to use synthetic, it will mess the clutch up. With no owners manual around to prove anything to him, does anyone know the oil honda specs for them?
#469963 - 04/06/05 11:12 PM Re: What oil to use in a Honda ATV?
04SpecV Offline
Loc: Pa
They probably spec a Honda 10W30.
Anything that isn't energy conserving should work as long as you change it fairly often. Synthetic oil isn't what makes the clutches slip thats just a rumor someone came up with.
I use Mobil1 Redcap 15W50 in my Raptor. When I had the Yamaha 10W30 in it, it was really hard to shift the gears if you got the engine hot at low speeds.
Since the Redcap 15W50 is no longer avail, I will probably try Rotella 5W40 next.
