Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
14 minutes 26 seconds ago
Best Oil Analysis?
by countryboy9799
Today at 07:28 PM
Left my lights on and battery died.
by joegreen
Today at 07:25 PM
Honda CRX '91 transmission fluid
by jhmed80
Today at 07:18 PM
It's winter, let's take out the... Motorcycle???
by OVERKILL
Today at 06:54 PM
Home Testing for Gas in Oil?
by landtoy80
Today at 06:54 PM
Cost to replace windshield.
by Oldmoparguy1
Today at 06:44 PM
Oil Life Monitor vs. Mileage vs. Time
by HOG
Today at 06:24 PM
Carrier A/C moving ALL production to Mexico.
by GiveMeAVowel
Today at 06:23 PM
ZDDP MAXX vs ZDDPlus
by 007
Today at 06:02 PM
Got a new jump starter, for the big boys
by 901Memphis
Today at 05:20 PM
S2000 valvetrain at 184K miles
by robertcope
Today at 04:58 PM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
124 registered (90crvtec, 1989outlaw, 901Memphis, 2cool, 2002 Maxima SE, ammolab, 14 invisible), 1416 Guests and 197 Spiders online.
56901 Members
66 Forums
244620 Topics
#465814 - 08/18/02 07:38 AM Non-Detergent motor oil
satterfi Offline
Loc: CA
My pressure washer pump calls for non-detergent 30w oil. Why do pumps, compressors and gear boxes call for non-detergent oil?
The stuff I bought today is SA rated rated and has no additives. It seems like there should be something better than that.
#465815 - 08/18/02 08:32 AM Re: Non-Detergent motor oil
Bror Jace Offline
Loc: Saratoga, NY
There is. Amalie makes an SB straight-weight series of oils which are non detergent but have a good deal of ZDDP in them.
--- Bror Jace
#465816 - 08/18/02 11:17 PM Re: Non-Detergent motor oil
MolaKule Offline
Loc: Iowegia - USA
This is a repost:
Non-detergent oils (mostly type SA) are used whenever other additives are not need, i.e., when only basic lubrication is needed, or the lubricant would mix with the other fluids in the system and pose toxicity or contamination problems. The SA oils contain only an anti-foaming agent which is silicone-based chemical. The silicone additive is very inert and nontoxic.
If your mechines call for non-detergent oils, do not use an SB oil. An SB oil contain an extra additive in addition to the silicone component, a friction modifier which is usiually ZDDP. ZDDP can be toxic if ingested and at the least, a skin irritant.
#465817 - 08/18/02 11:25 PM Re: Non-Detergent motor oil
MolaKule Offline
Loc: Iowegia - USA
In addition, the other additives, such as detergent/dispersants, and antioxidants, are not needed because the internals do not see hig temps or combustion by-pass gasses.
#465818 - 08/19/02 02:58 AM Re: Non-Detergent motor oil
GeorgeCLS Offline
Loc: Columbus, Ohio
I would highly suggest you get some Mobil DTE Heavy oil or other R&O (Schaeffer's, etc.) oil for your 30W needs. (I think Grainer has Heavy in quarts) The base oils used in a 30W ND engine oil are poor, at best. Using a high quality base stock oil will keep the pump clean, lubricate better and last much longer. Even better would be to get some Mobil SHC 627 or other synthetic neutral oil which would provide a cooler running pump. However, that is only sold in 5 gallon containers and very expensive...
[ August 19, 2002, 05:59 PM: Message edited by: GeorgeCLS ]
#465819 - 08/19/02 08:48 AM Re: Non-Detergent motor oil
satterfi Offline
Loc: CA
George
What's R&O? It sounds like you're saying I should use hydraulic or gear oils. How about vacuum pump oil or air compressor oil (Rarus 827)
I can also use SAE 20 in the pump. I've got Mobil 1 SGL (75w-90)on the shelf. How about that?
Thanks for the advice. I'll use the ND 30 to flush the pump out.
#465820 - 08/19/02 05:16 PM Re: Non-Detergent motor oil
msparks Offline
Loc: Clarksville, Tennessee
quote:
Originally posted by satterfi:
George
R&O - rust-and-oxidation inhibited. A term applied to highly refined industrial lubricating oils formulated for long service in circulating systems, compressors, hydraulic systems, bearing housings, gear cases, etc. The finest R&O oils are often referred to as turbine oils.
They can also be used in Hydraulic and Gear and Bearing applications. These fluids are usually less expensive than AW(Anti-wear) fluids. The Non-detergent(usually meaning ashless) is called for in certain applications where incidental contact with food or skin(eyes) can come into play. Since ZDDP is the most used AW detergent, eye contact can become a major concern.
Amsoil markets a line of R&O oils that are non-detergent,and contain ashless anti-wear additives to provide an additional layer of protection against wear in sever conditions. Since they are mostly used for industrial applications they are only available in 5 gal pails and greater.
[ August 20, 2002, 10:54 AM: Message edited by: msparks ]
#465821 - 08/20/02 02:42 AM Re: Non-Detergent motor oil
satterfi Offline
Loc: CA
I run this thing 1 hr/yr. It takes 200ml. A quart would last 5 years if I change it after every use. A 5 gallon pail would last over 100 yrs, unless I got Alzheimer's. Then it might last 200 years.
#465822 - 08/20/02 07:01 PM Re: Non-Detergent motor oil
widman Offline
Loc: Bolivia
Oils for this equipment is normally sold by ISO viscosity. SAE 30 is ISO 100 (you can see on Bob's chart elsewhere on this site). The oils mentioned are excellent starts, I have several products from Group I, Group II (Chevron GST for outstanding value) and Full Synthetics for higher economy and longer use.
Some compressors, normally screw compressors cannot take high levels of zinc.
Often when "non-detergent oil" is recommended it is to eliminate the absorbtion of moisture, so R&O oils and Hydraulic oils normally have demulsifiers instead of emulsifiers so that moisture will settle out, allowing draining and avoiding contact with internal parts. Engine oils are designed to absorb water and burn it off.
You will more likely find what you need in small quantities at your local compressor or equipment store labeled as compressor oil ISO 100.
