Butane for Portasol SuperPro 125 Soldering Iron
by The Critic
05/26/13 04:04 AM
Irregular transmission leak? -- Toyota RAV4
by 535678
05/25/13 11:27 PM
First Auto Tranny - Need ATF Recommendation
by wemis
05/25/13 11:27 PM
Humming pipes/fixtures
by JHZR2
05/25/13 11:04 PM
NBA Final
by HTSS_TR
05/25/13 10:12 PM
Power Steering or Amsoil ATF in 10' Camry P/S?
by rcbc96
05/25/13 09:47 PM
Finally, a synthetic blend that meets ACEA A5
by tommygunn
05/25/13 09:45 PM
Following the OLM
by DevilsRule
05/25/13 09:23 PM
Seattle Blooms
by andrewg
05/25/13 09:22 PM
Are gas pump auto-shutoff mechanisms consistent?
by Pajamarama
05/25/13 09:17 PM
Random post-quick rinse pic of Gretchen...
by 97tbird
05/25/13 09:15 PM
Cost to add on to an existing deck?
by dishdude
05/25/13 08:38 PM
GreatWhite, Bulletproof, Pete4638, jzzj2v, RushW
45569 Registered Users
26 registered (DuckRyder, bilibako2, CapriRacer, DevilsRule, alan003, Bruce T, 1 invisible), 409 Guests and 219 Spiders online.
45569 Members
64 Forums
193965 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#3734 - 07/28/02 07:51 PM Is this a good way to rate oil?
The_Oz Offline
Loc: Quebec, Canada
Hey Guys,
Found some interesting reading outside these boards. What is the viability of GM 4718 and CH-4 approved oils on Gasoline engines? Yes, meeting API SL specs is very easy and it is not really a good way of judging oil.
Just curious because there is very few oils that I see that actually mention these test approvals.
Regards,
Oz
#3735 - 07/31/02 07:43 PM Re: Is this a good way to rate oil?
Dick in Falls Church Offline
Loc: Falls Church VA
CH-4 is a diesel spec--not really pertinent to use in gas engines.
The GM 4718 spec, best I recall, came out when GM started putting Mobil 1 into Corvettes--and, best I know, requires a synthetic to meet it.
#3736 - 07/31/02 08:45 PM Re: Is this a good way to rate oil?
The_Oz Offline
Loc: Quebec, Canada
Yes, I know CH-4 is primarily used in the Diesel group. However, since most Diesel oils that I've seen are Sx licensed (Mobil Delvac 1, AMSOIL 3000, Shell Rotella, Petro Canada Duron, etc.), I'd figure the Cx standards are far more rigorous since most Sx oils are only rated up to CF in the commercial ratings dept. And CH-4 rated oils typically have SJ or SH ratings. This is what I need confirmation on...I guess [I dont know]
Regards,
Oz
#3737 - 08/01/02 09:24 AM Re: Is this a good way to rate oil?
jjbula Offline
Loc: Montgomery, AL
European ACEA A-3 standard seems to be slightly better than SL.
The A3 spec I like is the HTHS >3.5.
The jury is still out on the necessity of this parameter,
but it indicates better hydrodynamic lubrication at high temp.
Xw30 oils have trouble meeting A3 Xw40 oils only meet it if they are 0w40 or 5w40 (fuel economy part of A3).
see link
http://www.bobistheoilguy.com/states%20of%20lubrication.html
If hydrodynamic lube is overcome then barrier or boundary layer lube is used.
For that I would look for an oil with good levels of ZDDP and Moly.
Mobil 1 is using less ZDDP but promises good protection with Super Syn
You probably know that, but that is what I've been searching for in wear protection.
[ August 01, 2002, 12:30 PM: Message edited by: jjbula ]
#3738 - 08/01/02 09:53 AM Re: Is this a good way to rate oil?
jjbula Offline
Loc: Montgomery, AL
Do you know how GM 4718 might be superior to SL?
#3739 - 07/31/02 10:47 PM Re: Is this a good way to rate oil?
The_Oz Offline
Loc: Quebec, Canada
Actually jjbula, I have no clue as to what this certification is all about [Confused] All I know about GM4718 is that it was to meet certain specifications for Corvette engines. Exactly what specs, I don't know either.
Want to explain this to me?
Thanks,
Oz
