Observations on Workplace corrosion
by Vdubuk
07/29/16 12:15 PM
Oil filter change NIGHTMARE
by MetalSlug
07/29/16 12:08 PM
First time flushing an 05 Tacoma
by Back40
07/29/16 11:53 AM
600-year-old plumbing works better than modern
by HTSS_TR
07/29/16 11:48 AM
Shopping for brand-new F-150
by jay929
07/29/16 11:35 AM
Audi Broken Oil Control Rings - Why???
by SonofJoe
07/29/16 11:27 AM
Royal Purple VS Moblieone?
by 340six
07/29/16 11:09 AM
Condensing down to 1 vehicle
by krismoriah72
07/29/16 11:04 AM
Ford Focus door strip coming off
by FordBroncoVWJeta
07/29/16 10:41 AM
Windows 10 doesn't work on dial up speed
by Blaze
07/29/16 10:35 AM
Rotella T5 15w40
by JeepWJ19
07/29/16 10:33 AM
Motorkote ??
by Moondawg
07/29/16 08:53 AM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
73 registered (aquariuscsm, 4WD, Back40, aircooled, 69GTX, Andrei, 6 invisible), 1925 Guests and 12 Spiders online.
58632 Members
66 Forums
252401 Topics
#352056 - 05/04/06 08:40 AM Can I reuse an oil filter?
55Test Offline
Loc: New Brunswick
An oil filter that has less than 2000 miles on it? I want to do an oil change on my 93 Vic, and I can't decide between trying some Tech2000 5w20 at $3.08 per qt, or Zellers brand AutoPrix 5w30 at $1.67 per qt. Either way, I'm not going to be left with much change. Even a cheap Honeywell Defense oil filter for my car goes for $5.22, and prices for better filters go up from there. I've currently using a Carquest premium blue filter, and 5 quarts of Maxlife 5w30 plus 2 cups of MMO in the oil (one day I just wanted to try it).
#352057 - 05/04/06 09:13 AM Re: Can I reuse an oil filter?
Auto-Union Offline
Loc: NEPA
Yes.
#352058 - 05/04/06 09:20 AM Re: Can I reuse an oil filter?
blupupher Offline
Loc: Katy, Republic of Texas
No Super Tech filters for that car?
#352059 - 05/04/06 10:09 AM Re: Can I reuse an oil filter?
Steve S Offline
Loc: East of IGO
is there a reason for a 2,000 mile oil change ?
#352060 - 05/04/06 10:37 AM Re: Can I reuse an oil filter?
55Test Offline
Loc: New Brunswick
Not really, although some may say I've poisoned the oil with the MMO I added to it. Oh, I also put a bottle of the CD-2 SLOB in it too.
#352061 - 05/04/06 10:45 AM Re: Can I reuse an oil filter?
Gary Allan Offline
Loc: Pottstown, PA
Sure you can reuse a filter. I put a 9k used filter from Ugly3 on my Caravan. It wasn't even "in the family" and we shared filters. Now in some circles you can't share these types of things. Some just thing (apply appropriate accent) "It just ain't right.". [Big Grin]
Not a problem.
#352062 - 05/04/06 10:56 AM Re: Can I reuse an oil filter?
55Test Offline
Loc: New Brunswick
Cool. I just looked at a little note about the car when I changed the oil last, and I've put a wee bit over 2000 miles on since I changed it. Bah, maybe I won't bother changing it after all. The oil seems to be doing it's job well, although the slightly burned smell makes me wonder if the MMO I put in it did anything harmful. I suppose I'll run this oil and filter another 3500 miles or so and change it out.
#352063 - 05/04/06 11:13 PM Re: Can I reuse an oil filter?
addyguy Offline
Loc: Canada
If you are looking at trying a new, cheap oil, I think you would be better off using the W-M T2000 oil, as it meets the latest SM specs. The AutoPrix oil sold at Zellers, according to the API website, is only SJ rated. It says it is SM rated on the bottle, but the API website says otherwise....that was fairly recently. It probably doesn't matter to you, though, b/c your car is old enought to have used SJ oil for most of its life...but just letting you know.....
FWIW, I'm currently using T2000 5W-30 in my '02 Cavalier, and I'm happy with this oil. The car runs smooth, and the comnsumption is less than with the Pennzoil 5W-30 I had in before.
#352064 - 05/06/06 07:44 AM Re: Can I reuse an oil filter?
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
quote:
Putting both full bottles of CD-2 and MMO will thin the base oil alot. That's why they don't recommend any oil supplements added to high mileage oils either.
I would drain that oil & only use one supplement next time. Remove the filter - tip it over & let it drain -- turn it over a few times more to remove excess -- then reinstall. Make sure the gasket seals on both ends are clean -- then re-oil the filter gasket before re-applying.
