wheel bearing grease
by meborder
07/30/16 06:59 AM
My car audio build thread
by dan_erickson
07/30/16 06:08 AM
Pegasus PS737 Cut Open. Unknown Mileage / Oil
by Farmer
07/30/16 05:45 AM
Napa Gold 1372, 4.5 Months, 8500KM.
by Farmer
07/30/16 05:38 AM
lubriplate 1200-2
by buffalobob
07/30/16 02:49 AM
How do you politely say no to people?
by motor_oil_madman
07/30/16 12:39 AM
To change or not?
by ram_man
07/29/16 11:55 PM
Nozzle Flow Versus Pressure/Viscosity
by Shannow
07/29/16 11:20 PM
Camaro "How its Made" TV show Observations
by SumpChump
07/29/16 11:08 PM
Wondering if sitting with few quick starts degrad
by corndogzombie
07/29/16 10:51 PM
whole hog cook w/ pics
by 04SE
07/29/16 10:12 PM
redo a/c in 1994 dakota 2wd
by bmwjohn
07/29/16 09:37 PM
jractk, LatitudeDancer, AKN, NickGB, Marcusd1979
58645 Registered Users
63 registered (alarmguy, 97f150, AnthemBassMan, AirgunSavant, Astro_Guy, 04SE, 3 invisible), 1510 Guests and 9 Spiders online.
58645 Members
66 Forums
252433 Topics
Page 1 of 2 1 2 >
#345122 - 11/06/05 02:12 AM Why is Motorcraft filter better than Purolator Prem Plus???
dwcopple Offline
Loc: Michigan
if it is made by Purolator...what is different about it and why do they cost more???
#345123 - 11/06/05 02:42 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
Big O Dave Offline
Loc: The New State of Central Calif...
To begin, here is a photo of a Purolator Premium Plus L30001. Notice that it has a dome-end bypass valve.
Here is a photo of a Motorcraft FL-1A. It has a threaded-end bypass valve.
The advantage of a threaded-end bypass is that the oil doesn't have to wash over the dirt-laden element before entering the valve unfiltered... which is why Ford specifies a threaded-end bypass valve for its oil filters.
The Motorcraft also has larger baseplate openings, and appears to be optimized for flow over the already good-flowing Purolator. Some allege that the Motorcraft has the same filter element as the Purolator PureOne, but I haven't seen any proof of that.
Notice that they both have the telltale Purolator string around the filter element.
I'm sure others will fill in more details!
[Smile]
#345124 - 11/06/05 03:04 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
T-Keith Offline
Loc: MN
Silicone ADBV, usually threaded end bypass if applicable. If you have a Ford, they are actually easier to find.
-T
#345125 - 11/06/05 07:10 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
labman Offline
Loc: Nothern USA
So, has anybody put a tape measure to the media in each? Give me the Motorcraft cross from an ST 3950 or L 10193, and I will run one on my truck and report back. I am less happy with the ST 3950 since they went to a dome end clicker.
#345126 - 11/06/05 07:24 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
Big O Dave Offline
[Big Grin]
#345127 - 11/06/05 08:01 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
brianl703 Offline
Loc: Manassas, VA
The FL-1A does not have a silicone ADBV.
#345128 - 11/06/05 07:40 PM Re: Why is Motorcraft filter better than Purolator Prem Plus???
dwcopple Offline
Loc: Michigan
lots of MC filters don't have a silicone ADBV
#345129 - 11/07/05 08:46 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
Brian Quote:
Huh!
Every one I saw with the threaded-end ADBV does have the silicone.
#345130 - 11/07/05 08:58 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
wavinwayne Offline
Loc: North Alabama
Triple_Se7en,
The MC FL-1A filters around here all have the black (nitrile?) ADBV. The FL820S has the orange silicone ADBV.
#345131 - 11/06/05 09:02 PM Re: Why is Motorcraft filter better than Purolator Prem Plus???
97tbird Offline
Loc: Fayetteville, NC
s for silicon ( i use the FL 820 "S") [Smile]
no s, no silicon. that's what I was told.
#345132 - 11/07/05 02:05 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
jsharp Offline
Loc: Outside smalltown, IL
I've never seen an FL1A with a silicone ADBV. The Motorcraft media is different than a standard Purolator. It's built to a Ford spec.
#345133 - 11/07/05 05:52 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
brianl703 Offline
Loc: Manassas, VA
There are Ford filters that do not have "S" in the part number that DO have a silicone ADBV.
The reason is, I believe, because those filters that do have an S in the part number (FL-400S and FL-820S are all that I know about) were once available without a silicone ADBV, and the S was added to identify the new, improved model. (I believe the silicone ADBV was added to the FL-820S in 1995 or 1996, and that filter dates back to 1991 when it was introduced along with the 4.6L V8 that it fits).
Apparently, those that have a silicone ADBV and do not have an S in the part number were never made without one. I believe, if you check, you will find that the FL-200 and the FL-2005 have a silicone ADBV, and they were introduced in 1995 and 1998 respectively.
#345134 - 11/07/05 06:35 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
wavinwayne Offline
Loc: North Alabama
Is it safe to say that ALL of the black-colored ADBV's in MC filters are nitrile, & ALL the orange-colored ADBV's in MC filters are silicone?
#345135 - 11/07/05 07:12 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
sdude2k2000 Offline
Loc: Southern Oregon, USA
Are the filtration medias the same though?
#345136 - 11/07/05 08:17 AM Re: Why is Motorcraft filter better than Purolator Prem Plus???
TallPaul Offline
Loc: By Detroit
I don't really know or care whether the Purolator or Motorcraft is better. I think they are both good. In fact I rather like the Fleetguard for its freer flow, but it does not have the threaded end bypass.
When I buy Purolator I get Premium Plus, not the more restrictive Pure One. The only thing I really care about is that the bypass is on the threaded end of the filter. I can get the extra long version of the FL1A (FL299) in Purolator and it has the threaded end bypass (L40017).
Page 1 of 2 1 2 >
