45515 Members
64 Forums
193805 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#3396 - 07/24/02 11:17 PM
Valvoline SynPower?
Loc: Canada
Hi guys, I just finished rebuilding my Honda motor and I'm the process of finding a good synthetic motor oil once I break the motor in. Basically, my motor is a high RPM screamer, so I'm looking for a synthetic oil that will do well at high RPM's (9000+RPM) with a lot of spirited driving. After doing some reading and researching on this board, it seems to me that none of the on-shelf synethic motor oils are any good. I'm located in Canada, so I can't get my hands on oils like Shaefer. which you guys highly recommend. I know you guys also recommend Valvoline MaxLife, but since my motor is basically brand new, I don't know if that is a good idea, fearing that the oil will toast my new valve seals, o-rings and gaskets. I remembered someone in here recommending Valvoline SynPower. Are they any good at all, comparing to all the other on-shelf synthetic oils? Oils like Redline or Amsoil cost way too much for me, so there's no way I can afford those. So I'm looking for the best on-shelf synthetic oil at a price of the normal retail price for my high RPM screamer. Also, what range (5W-30, 10W-30, 10W40, 5W-50, etc.) will be good for my motor? Thanks in advnace!
#3397 - 07/24/02 11:52 PM
Re: Valvoline SynPower?
Loc: Cincinnati, OH
quote: it seems to me that none of the on-shelf synethic motor oils are any good.
Not true. There are good OTC oils available, you just need to be aware of what you are buying. The only true "synthetic" currently available OTC is Mobil 1. It's till a Group IV PAO base. All others "synthetics" available OTC (Penzoil, Valvoline) use a Group III base are not 100% synthetic per se. Does not mean they are bad oils, just not a true synthetic.
#3398 - 07/24/02 11:57 PM
Loc: Midwest
#3399 - 07/25/02 12:38 AM
Loc: Oakville, Ontario
Didn't someone mention the other day that Havoline and Chevron Synthetic is still a PAO/ester base and not a group 3? If so, we can get Havoline Synthetic oil up here in Toronto, it's sold at Walmart.
As far as Schaeffers goes, I just ordered a case of Schaeffers from Burkely in Saskatchewan. It cost just over $60 CDN for a case of 12, plus $30 shipping. I think it's well worth it.
#3400 - 07/25/02 12:56 AM
Loc: Cordelia, CA
I may not be reading Chevron right, but I don't think either are PAO.
And is Havoline Synth a blend ?!?!
---------------------------------- Chevron Supreme Synthetic COMPONENTS AMOUNT LIMIT/QTY AGENCY/TYPE
SYNTHETIC HYDROCARBON BASE OIL Chemical Name: 1-DECENE, HOMOPOLYMER, HYDROGENATED CAS68037014 > 55.00% NONE NA
OR
ISOSYN BASE OILS 5 mg/m3 (mist) ACGIH TWA 10 mg/m3 (mist) ACGIH STEL 5 mg/m3 (mist) OSHA PEL
DECANOIC ACID, ESTER Chemical Name: DECANOIC ACID, ESTER WITH 2ETHYL2(HYDROXYMETHYL)1,3 PROPANE CAS11138606 < 15.00% NONE NA
ADDITIVES INCLUDING THE FOLLOWING < 30.00%
ZINC ALKYL DITHIOPHOSPHATE Chemical Name: PHOSPHORODITHIOIC ACID,O,O-DI-C1-14-ALKYL ESTERS, ZINC SALT CAS68649423 < 2.00% NONE NA
COMPOSITION/INFORMATION ON INGREDIENTS ______________________________________________________________________
100.0 % TEXACO Havoline Synthetic Motor Oil
CONTAINING
HYDROTREATED DIST., HVY PARA Chemical Name: DISTILLATES, HYDROTREATED HEAVY PARAFFINIC CAS64742547 > 80.00% 5 mg/m3 (mist) ACGIH TWA 10 mg/m3 (mist) ACGIH STEL 5 mg/m3 (mist) OSHA PEL
AND
SOLVENT DEWAXED DIST., HVY PAR Chemical Name: DISTILLATES, SOLVENT DEWAXED HEAVY PARAFFINIC CAS64742650 5 mg/m3 (mist) ACGIH TWA 10 mg/m3 (mist) ACGIH STEL 5 mg/m3 (mist) OSHA PEL
ADDITIVES INCLUDING THE FOLLOWING < 20.00%
ZINC ALKYL DITHIOPHOSPHATE Chemical Name: PHOSPHORODITHIOIC ACID,O,O-DI-C1-14-ALKYL ESTERS, ZINC SALT CAS68649423 < 5.00% NONE NA
COMPOSITION COMMENT: All the components of this material are on the Toxic Substances Control Act Chemical Substances Inventory.
This product fits the ACGIH definition for mineral oil mist. The ACGIH TLV is 5 mg/m3, the OSHA PEL is 5 mg/m3.
100.0 % CHEVRON Supreme Synthetic Blend Motor Oil
CONTAINING
AND
This product fits the ACGIH definition for mineral oil mist. The ACGIH TLV is 5 mg/m3, the OSHA PEL is 5 mg/m3. ------------------------------------- Chevron Supreme Motor Oil COMPOSITION/INFORMATION ON INGREDIENTS ______________________________________________________________________
100.0 % CHEVRON Supreme Motor Oil
CONTAINING
LUBRICATING BASE OIL SEVERELY REFINED PETROLEUM DISTILLATE > 75.00% 5 mg/m3 (mist) ACGIH TWA 10 mg/m3 (mist) ACGIH STEL 5 mg/m3 (mist) OSHA PEL
The BASE OIL may be a mixture of any of the following: CAS 64741884, CAS 64741895, CAS 64741964, CAS 64741975, CAS 64742014, CAS 64742525, CAS 64742536, CAS 64742547, CAS 64742627, CAS 64742650, or CAS 72623837.
ADDITIVES INCLUDING THE FOLLOWING < 25.00%
ZINC ALKYL DITHIOPHOSPHATE Chemical Name: PHOSPHORODITHIOIC ACID,O,O-DI-C1-14-ALKYL ESTERS, ZINC SALT CAS68649423 < 1.50% NONE NA
This product fits the ACGIH definition for mineral oil mist. The ACGIH TLV is 5 mg/m3, the OSHA PEL is 5 mg/m3. [ July 25, 2002, 03:58 PM: Message edited by: VaderSS ]
#3401 - 07/25/02 01:10 AM
Loc: Alabama
I believe the Valvoline SynPower is one of the best synthetic (ahem*) motor oils one can buy OTC. Simply speaking from experience I have not had a problem running any of Valvoline's products, and they seem to keep engine internals very clean - no varnishing. For that matter I've had nothing but great experiences running the DuraBlend they make - but I've never ran any oil tests on the stuff just yet (didn't know they existed back then). Also, until I see some proof from further oil analysis that its good, I am staying away from the new SuperSyn Mobil-1. This is a purely subjective statement I know, but if I were to choose from all the OTC oils right now sitting on a shelf at Wal-Mart -- my confidence would go with Valvoline. The only other 2 oils I for sure know are just as good and could possibly be better are not OTC, and those are Schaeffer's and Redline, with Schaeffer's being a far cry better bang for the buck. If you decide to choose Valvoline - and you're worried its not doing what it should - there is no reason not to have it analysed. Its the only surefire way of knowing whether what you chose is doing what it should for your engine. Goodluck and let us know what you decide on ![[Smile]](images/icons/smile.gif)
#3402 - 07/25/02 07:29 AM
Loc: michigan
this is part of a post i made in an earlier thread.
i broke in my new car on durablend, but switched to mobil1 as i've run it for years in other cars. i will probably revert to pennzoil (after johnny gave me some info).
previous post=>
durablend:
Ingredient(s) CAS Number % (by weight) -------------------------------------------- ------------- ------------- HEAVY PARAFFINIC PETROLEUM DISTILLATES 64742-54-7 54.0- 64.0 SOLVENT-DEWAXED HEAVY PARAFFINIC PETROLEUM D 64742-65-0 10.0- 20.0 ZINC COMPOUNDS 68649-42-3 1.0- 1.0
synpower:
Ingredient(s) CAS Number % (by weight) -------------------------------------------- ------------- ------------- PETROLEUM HYDROCARBON 64742-54-7 52.0- 62.0 ZINC COMPOUNDS 0.7- 1.4
the base oil is essentially the same, at half price. you might get more or less zinc with the "synth."
#3403 - 07/26/02 09:35 AM
Loc: Saratoga, NY
I used this stuff for about a year and overall, I was disappointed in it. First of all, Valvoline will tell you that it's PAO ... which is a lie. It's Group III. I heard this numerous times from others and spoke to one of their chemists myself once. Add to that the fact that Valvoline says their Max-Life is a Group III oil when it is actually a Group II. I no longer think highly of them, their word or their reputation. Next, when in my crankcase, Synpower oil is the ONLY oil that showed any consumption. I don't know what the problem was but the car soon began consuming about 1/3 to 1/2 of a quart in 4,000 miles. ![[I dont know]](graemlins/dunno.gif) I used Mobil 1 prior to that and it did not consume any oil between 6,000 mile drain intervals. It took 6 months with Red Line to get my Honda's consumption back to zero after I switched away from Valvoline Synpower. ![[Smile]](images/icons/smile.gif)
#3404 - 07/25/02 11:20 PM
Loc: Midwest
SYNTHETIC HYDROCARBON BASE OIL Chemical Name: 1-DECENE, HOMOPOLYMER, HYDROGENATED CAS68037014 > 55.00% NONE NA ######### A 1-decence PAO - Good Choice among PAO's#####################
ISOSYN BASE OILS 5 mg/m3 (mist) ACGIH TWA 10 mg/m3 (mist) ACGIH STEL 5 mg/m3 (mist) OSHA PEL ############ Definately Chevron's Group III###########
DECANOIC ACID, ESTER Chemical Name: DECANOIC ACID, ESTER WITH 2ETHYL2(HYDROXYMETHYL)1,3 PROPANE ###############An Excellent Ester############## CAS11138606 < 15.00% NONE NA
ADDITIVES INCLUDING THE FOLLOWING < 30.00% ***********This oil is PAO/Ester/Group III BLEND base Oil.*******************
CONTAINING
AND
*************This is a blend of Group II+ and Group III Base OIL****Definately not Synthetic**********************
CONTAINING
AND
*****An equal mix of Group II+ and Group III BAse OIls********* Not a synthetic ______________________________________________________________________
CONTAINING
*****************A group II to Group II+ base oils*****Not Synthetic***********************
The Chevron Supreme Synthetic (A BLEND) is most likely the best of the bunch.
#3405 - 07/26/02 10:45 PM
Loc: Atlanta
this is sad to say this about myself but....if y'all want me to, I can post the specs of almost every synthetic and group II oil (the major ones that is) that I have compiled. I've got a ton of them if y'all are interested to do a comparison of them. Oh, and I've also got the MSDS for Texaco's synthetic oils that are made by Equilon, LLC. Equilon were(for those that dont know), owned by Texaco & Shell oil co.'s and is now fully owned by Shell oil. My point is this. This CAS#'s listed for Texaco's syn. oils are not the same as the one(s) made by Equilon. For instance, here is Equilon's Texaco branded 5w-40 syn. oil. (Oh, and whats funnier is that its not even listed on the Chevron-Texaco site that they even carry it!: ![[Roll Eyes]](images/icons/rolleyes.gif) Anyways, heres the info: MATERIAL SAFETY DATA SHEET MSDS Number: 02102ET - 0 24 Hour Emergency Assistance: CHEMTEL (877) 276-7283 General Assistance Number: (877) 276-7285 -------------------------------------------------------------------------------- SECTION 1 PRODUCT IDENTIFICATION -------------------------------------------------------------------------------- MATERIAL IDENTITY: HAVOLINE® Synthetic Motor Oil 5W-30 PRODUCT CODES: 02102 COMPANY ADDRESS: Equilon Enterprises, LLC, P. O. Box 4453, Houston, TX. 77210-4453 -------------------------------------------------------------------------------- SECTION 2 PRODUCT/INGREDIENTS -------------------------------------------------------------------------------- CAS# CONCENTRATION INGREDIENTS Mixture 100 %weight Synthetic Motor Oil 68037-01-4 70 - 79.99 %weight Synthetic aliphatic hydrocarbon Proprietary 5 - 9.99 %weight Alkyl carboxylic acid ester 64742-65-0 1 - 4.99 %weight Hydrotreated dewaxed heavy paraffinic distillate 64742-54-7 3 - 8.99 %weight Hydrotreated heavy paraffinic distillate 84605-20-9 1 - 4.99 %weight Polyethylene amine Flash Point [Method]: 450 ºF -470 ºF/232.22 ºC -243.33 ºC [ Cleveland Open Cup] ------------------------------------------------------ MATERIAL SAFETY DATA SHEET MSDS Number: 02100ET - 1 24 Hour Emergency Assistance: CHEMTEL (877) 276-7283 General Assistance Number: (877) 276-7285 -------------------------------------------------------------------------------- SECTION 1 PRODUCT IDENTIFICATION -------------------------------------------------------------------------------- MATERIAL IDENTITY: Havoline® Synthetic Motor Oil 5W-40 PRODUCT CODES: 02100 COMPANY ADDRESS: Equilon Enterprises, LLC, P. O. Box 4453, Houston, TX. 77210-4453 -------------------------------------------------------------------------------- SECTION 2 PRODUCT/INGREDIENTS -------------------------------------------------------------------------------- CAS# CONCENTRATION INGREDIENTS Mixture 100 %weight Synthetic Motor Oil 68037-01-4 60 - 74.99 %weight Synthetic aliphatic hydrocarbon Proprietary 5 - 9.99 %weight Alkyl carboxylic acid ester 64742-65-0 3 - 8.99 %weight Hydrotreated dewaxed heavy paraffinic distillate 64742-54-7 3 - 8.99 %weight Hydrotreated heavy paraffinic distillate 84605-20-9 1 - 2.99 %weight Polyethylene amine Flash Point [Method]: 430 ºF -450 ºF/221.11 ºC -232.22 ºC [ Cleveland Open Cup]
#3406 - 07/27/02 12:40 AM
Loc: Atlanta
my advice is to either use BMW's Synthetic oil (5w-30) as its made by Castrol, but uses a composition completely different than that of Syntec. Our Syntec does not meet the ACEA A3 standard (do a search about it), whereas the BMW syn. oil does. This translates to great protection from your engine that you will NOT get, IMHO, from any OTC oils in the same viscosity. To get close, I'd try the new Mobil 1 0w-40.
Next, Im going to try AGIP syn. 5w-40 for summer and 5w-30 for winter. Great syn. oil thats, from what Im told by an AGIP contact, a full PAO syn. Also of interest is that, the VI's are low (relatively, that is) and AGIP say's its because they use almost no VI improvers in their syn. oil and their group II+ oils as well.
#3408 - 07/27/02 02:44 AM
Loc: Bolivia
Information on the ChevronTexaco site is in a state of change. This week dozens of sheets were changed. Some products are in msds but not specs, some the other way. My guess is that it will take them months to sort it all out and post it in all the places.
#3409 - 07/28/02 11:38 PM
Yeah, doesn't that show that Hav. synth. is a true PAO synthetic???
