Yokohama AVID Acend 195/60R15. $190
by Sam_Julier
04/30/16 07:24 AM
Hate those adds that start with, "Lean 1 weird ...
by OneEyeJack
04/30/16 05:11 AM
How Much Olive Oil Do You Use?
by GrtArtiste
04/30/16 03:20 AM
Hyundai filter 26300-35503 10PK for 35.40 FREE S&H
by GumbyJarvis
04/30/16 01:10 AM
Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
77 registered (AandPDan, AirgunSavant, Bandito440, 2002 Maxima SE, andyd, 10 invisible), 1329 Guests and 118 Spiders online.
57748 Members
66 Forums
248235 Topics
#339160 - 06/17/05 05:27 AM Mobil 1 oil filter in Toyota Solara
crimedog Offline
Loc: Kansas
Hi all, great site here. I just purchased a 99 Toyota Solara V-6 with 149,000 miles. The engine is tight as can be, just changed the oil and filter after 3,000 miles. I went with Pennzoil 5w-30 and a Mobil 1 filter. My concern is, with the Mobil filter the oil light stays on noticebly longer when I start the car after it has been sitting for a while. Before it went out almost immediately (dealer installed Fram filter, unfortunately). Now it stays on for probably at least a second if the car sits overnight. I am a little concerned about it but don't know if it is an issue as I know Mobil is considered a good filter.
I researched all the "sludge" issues with this car. Fortunately, I knew the previous owners and how well they took care of things. The car was driven approximately 30 miles round trip to work every day, so it wasn't used on short trips. The oil level after 3000 miles is still on full, and the car never smokes. It appears that everything is in excellent condition and I hope to keep it that way. Should I stay with the Mobil or try a Wix because of the startup issue?
#339161 - 06/17/05 05:59 AM Re: Mobil 1 oil filter in Toyota Solara
Eddie Offline
Loc: Florida, Cape Coral
I'd suggest a PureOne or a Wix. Either one is excellent. I wonder why the Mobil filter is doing that? Never read anyone seeing that. Maybe your using a different oil?
#339162 - 06/17/05 06:53 AM Re: Mobil 1 oil filter in Toyota Solara
crimedog Offline
Loc: Kansas
Nope, it's the same oil, the previous owner told me they have used Penz 5w-30 from day one. I'm not too concerned about it as the light doesn't stay on any more than in my wifes 4Runner, it just was a little obvious that it stays on longer than the Fram filter did.
#339163 - 06/17/05 07:35 AM Re: Mobil 1 oil filter in Toyota Solara
bighead Offline
Loc: NCAA National Football Champs ...
Probably due to the M1 filter being *slighty* more restrictive (read = better filtering). The...."F word"...filter was more than likely MUCH less restrictive. I wouldn't even give it a second thought. M1 filters are probably one of the best available, albeit most expensive... [Cheers!]
#339164 - 06/17/05 05:56 PM Re: Mobil 1 oil filter in Toyota Solara
unDummy Offline
Loc: RI
Are you using the M1-209 or M1-102? Try the one you're not using.
Purolator/Motorcraft/Wix/Champ and their clones like Bosch/K&N/Carquest/Napa are worth a shot.
If most engine wear occurs at start up, then I'd want my "engine light" to shut off as quickly as possible.
I guess those 'super duper boutique filters' filter out all the startup wear they cause by being more restrictive [Big Grin]
#339165 - 06/17/05 08:39 PM Re: Mobil 1 oil filter in Toyota Solara
crimedog Offline
Loc: Kansas
It's the M1-102. I think I'm gonna give the Wix a shot as they are available at a parts store a few miles away. Thanks for the responses!
#339166 - 06/18/05 09:02 AM Re: Mobil 1 oil filter in Toyota Solara
buster Offline
Loc: NJ
I'd use a Purealator Pure One and go with Mobil 1. My brother has a 2001 Solara with the V6. Mobil 1 will help keep the engine clean.
#339167 - 06/18/05 12:10 AM Re: Mobil 1 oil filter in Toyota Solara
tuong Offline
Loc: milpitas
i don tknow how your filter'slocations are position. but i notice that toyota have great positioning on there filter. on My friend's rav4 i dont need to look at the filter to remove it. but if its possible to put a some oil in the filter before u install it, that may help. I know sometimes you cant. for example, my prelude filter is almost horizontal, so if i put oil in there, it would spill when i install it. but if you are already doing this, then I dont know. I wouldnt really worry about it or would i?
