Tacoma Extended OCI
by 13Tacoma
06/29/16 01:07 PM
Gear oil mixed in with Diesel Engine Oil ...
by Miller88
06/29/16 12:07 PM
DELO ELC Antifreeze/Coolant??
by Griz95
06/29/16 12:06 PM
Higher oil pressure. Oil? Filter? Jeep 4.0
by RegDunlop
06/29/16 11:16 AM
NJ's gas tax increase
by Whimsey
06/29/16 11:11 AM
PAO in Mobil 1 0w-40
by loneryder
06/29/16 10:33 AM
2010 Porsche Boxster S, Mobil 1 5w50, 4,700 miles
by Croc
06/29/16 10:18 AM
Amsoil announces 6% price hike
by Kuato
06/29/16 09:28 AM
737 NG
by SEMI_287
06/29/16 09:10 AM
ACDelco vs Valvoline oil filter
by mbar1
06/29/16 08:21 AM
Valvoline Premium Blue RestoreTM
by Rat407
06/29/16 08:16 AM
Dealer says 07 Highlander has strainer. Nope!
by CapitalTruck
06/29/16 08:04 AM
dpaldino, T_Bortz, rebelx, dougsangster, CrazyCalvinW
58314 Registered Users
99 registered (Al, alphadog, 13Tacoma, ARCOgraphite, aquariuscsm, 9 invisible), 1995 Guests and 10 Spiders online.
58314 Members
66 Forums
250982 Topics
#325503 - 04/23/04 08:08 PM Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
Flintstone Offline
Loc: South Florida
Does anyone know of any filters the size of the Motorcraft 1A or 299 that are available with 22 x 1.5 threads? I'm looking for a longer filter to replace a MC FL-820S. Thanks.
#325504 - 04/25/04 08:03 AM Re: Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
MNgopher Offline
Loc: Lakeville, MN
At last check, there are no larger replacement filters for the FL-820s.
If you want a bigger filter, the best bet is to run a remote and set it up to run the FL-1A.
#325505 - 04/25/04 09:22 AM Re: Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
TallPaul Offline
Loc: By Detroit
Check this out. An adapter for M20x1.5 filter mount to make it fit a FL1A filter. Maybe there is a similar adapter available in the 22x1.5.
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=6;t=001434
[ April 26, 2004, 12:27 AM: Message edited by: TallPaul ]
#325506 - 08/25/04 01:46 AM Re: Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
FordManVT Offline
Loc: VT
If his engien bay is anything like mine, there is zero rrom for an adapter.
My solution was a remoe kit, summitt has a permacool kit for $40. It bolts right in, although AN lines are recomended. It uses the FL1A filter.
#325507 - 08/25/04 05:14 AM Re: Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
Bill Kapaun Offline
Loc: Oregon
A Wix 51592 looks to be about the size of the FL-1A.
BP is a bit higher.
Wix 51592
[ August 25, 2004, 08:20 PM: Message edited by: Bill Kapaun ]
#325508 - 08/25/04 05:56 AM Re: Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
T-Keith Offline
Loc: MN
FL820S is already pretty big. I wouldn't spend a lot of money for a filter only an inch longer. Your filter is already bigger then 90% of them.
-T
#325509 - 08/25/04 09:46 AM Re: Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
MNgopher Offline
Loc: Lakeville, MN
What a weird cross reference! The 51592 is a filter for Komatsu and Onan engines, such as those found in mini-excavators, skid steers, and gensets. Whod've thunk... Now try and actually find one!
Next question is will it fit? I know on my F150 the filter is interesting enough to find its way on and off!
#325510 - 08/29/04 07:47 AM Re: Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
MNgopher Offline
Loc: Lakeville, MN
Good luck finding the oversize filter, equivalent of the Wix 51592. Trips to a few sources, including a few parts houses that carry odd stuff ended up being empty handed.
#325511 - 08/29/04 08:03 AM Re: Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
brianl703 Offline
Loc: Manassas, VA
There's a Baldwin equivalent for it. One of the online Baldwin filter suppliers might have it.
Would the 20PSI bypass matter?
#325512 - 09/28/05 11:59 AM Re: Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
ford390gashog Offline
Loc: U.S.***
the 51592 is easy to get all napa stores have them here is the napa part number FIL1592 .
#325513 - 04/03/06 10:23 PM Re: Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
crimsontide Offline
Loc: Charlotte, NC
anyone know the filter ratings of this filter??
#325514 - 04/04/06 06:47 AM Re: Motorcraft FL-FL1A or FL-299 Equivalent with 22 x 1.5 mm Threads
nemir Offline
Loc: Big Spring TX
I took the oil filter stud to a machine shop, instructed the machinest to build a stud of the same dimintions except the outer end be made sae and fit the fl1A filter. It works and at a savings of 1.78, I shall break even in about 7 years.
