Here is my Pennzoil Ultra UOA. PU 5w30 with an OEM Subaru filter. Easy on the car while daily driving, roughly 70% highway and 30% city driving. Four autocross events on the oil (~25 runs). At ~3,500 mi I realized that I had burned some oil and topped off with about 0.6 qts. When I changed the oil, I had burned another 0.3-0.4 qts. It didn't seem to burn much, if any, on the other oils. Currently trying out Mobil 1 ESP 5w30 this time around.
Code:
Oil---------------------- Factory Fill ------ Edge OE 5w30---Pennzoil Platinum 5w30--- Pennzoil Ultra 5w30--- Universal Averages
Miles In Use 3,002 4,048 3,351 4,547
Miles on Unit 3,002 7,050 10,401 14,948
Date Changed 2/1/13 5/10/13 8/05/13 11/11/13
Make up Oil Added--------- 0 Qts. ------------ 0 Qts. ------- 0 Qts. ------------------ 0.6 Qts.
Aluminum------------------ 7 ----------------- 9 ------------ 6 ----------------------- 5 --------------------- 4
Chromium 1 1 1 1 1
Iron 34 16 14 11 9
Copper 27 9 7 5 9
Lead---------------------- 0 ----------------- 0 ------------ 0 ----------------------- 0 --------------------- 3
Tin 4 3 2 0 1
Molybdenum 1079 435 118 70 72
Nickel 0 0 0 0 0
Manganese 2 1 1 0 1
Silver-------------------- 2 ----------------- 1 ------------ 0 ----------------------- 1 --------------------- 0
Titanium 0 1 0 2 0
Potassium 2 2 2 1 2
Boron 198 26 6 60 46
Silicon 89 19 10 5 11
Sodium-------------------- 8 ----------------- 6 ------------ 1 ----------------------- 2 --------------------- 28
Calcium 2105 1777 2388 2422 2006
Magnesium 12 6 12 15 369
Phosphorous 892 680 725 798 810
Zinc---------------------- 1082 -------------- 802 ---------- 831 --------------------- 842 ------------------- 960
Barium 2 1 0 0 0
SUS Viscosity @ 210F------ 52.4 -------------- 66.1 --------- 58.9 -------------------- 57.3 ------------------ 56-63
cSt Viscosity @ 100C 7.99 11.91 9.91 9.44 9.1-11.3
Flashpoint in F 405 435 405 425 >365
Fuel
Antifreeze %-------------- 0.0 --------------- 0.0 ---------- 0.0 --------------------- 0.0 ------------------- 0.0
Water %. 0.0 0.0 0.0 0.0
Insolubles % 0.2 0.3 0.1 0.3
TBN N/A 2.8 N/A 5.2
Code:
Chromium 1 1 1 1 1
Iron 34 16 14 11 9
Copper 27 9 7 5 9
Tin 4 3 2 0 1
Nickel 0 0 0 0 0
Manganese 2 1 1 0 1
Titanium 0 1 0 2 0
Potassium 2 2 2 1 2
Barium 2 1 0 0 0
Fuel
TBN N/A 2.8 N/A 5.2
