My 2003 Dodge Dakota
by HM12460
Today at 08:37 AM
Check out the head off my extreme oil burner Honda
by Gasbuggy
Today at 01:31 AM
Unused Bosch 3313 cartridge
by Run
Yesterday at 11:14 PM
David Fry in his own words
by Merkava_4
Yesterday at 11:02 PM
Schaeffer 711 10w30 Detroit 60 12.7
by TiredTrucker
Yesterday at 09:17 PM
2012 Mazdaspeed3 transaxle 36k OCI 75W80
by MD1032
Yesterday at 09:13 PM
Ford announces new assembly plant in Mexico.
by mrsilv04
Yesterday at 09:10 PM
Guy with a cart full of Euro 5W40
by ledslinger
Yesterday at 08:51 PM
Ever wonder how the new Camaro is made?
by BobsArmory
Yesterday at 08:43 PM
Credit Card Reader 4 Smart Phone-Small Business
by crazyoildude
Yesterday at 08:16 PM
talent doesn't pay like it used to.
by motor_oil_madman
Yesterday at 07:46 PM
Disappointed with Accord after one Salt Exposure
by JHZR2
Yesterday at 06:58 PM
slewman, lithium1189, Monktana, djh3, Compignite
56850 Registered Users
99 registered (Astro14, 2015_PSD, Astro_Guy, Asterix, 440Magnum, Andrei, 9 invisible), 1586 Guests and 214 Spiders online.
56850 Members
66 Forums
244401 Topics
Page 1 of 2 1 2 >
#3197789 - 11/25/13 02:34 PM what gasket maker sealant to use on this (pic)
1 FMF Offline
Loc: CT
it's the oil sending port on a ls1 engine. it's an aluminum piece, and aluminum engine block. the gasket with the black impregnated o-ring has been seeping. was thinking of not reusing the gasket in the pic and using some kind of gasket maker instead. what would be best? it will see oil temperatures to 250 F and it's right next to the catalytic converter so it may see 300-400 heat from that on the outside.
#3197796 - 11/25/13 02:37 PM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
eljefino Offline
Loc: ME
Permatex orange
#3197826 - 11/25/13 02:58 PM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
1 FMF Offline
Loc: CT
forgot to mention, i have some mr. gasket make your own material. one is thick stuff around 0.080" and dark gray, the kind you would use as a carburetor base gasket. the other is thin tan fiber gasket stuff, 1/64" thick karropak i think. wondering if i should use that, i'm worried that any rtv might not hold under 80 psi of oil pressure.
Edited by 1 FMF (11/25/13 03:01 PM)
#3197838 - 11/25/13 03:06 PM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
eljefino Offline
Loc: ME
Hmm, if some fiber got loose from that make-a-gasket from an imperfect cut would that be floating around in the oil system?
Is the proper gasket unobtainable? Mentioning the 80 psi has me a little squeamish now.
#3197854 - 11/25/13 03:19 PM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
rrguy Offline
Loc: MN
I would remove the old go & match up & spend the 50 cents or so for an oring.
"This post is uselesss without pics"
Royal Purple
Semper Fi
#3197862 - 11/25/13 03:25 PM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
WANG Offline
Loc: North Carolina
I like this stuff.
"Sportbikes have evolved from an axe into a scalpel.
Problem is, the average sportbike buyer is more lumberjack than surgeon." -Richard Pollock
#3197907 - 11/25/13 04:05 PM Re: what gasket maker sealant to use on this (pic) [Re: WANG]
andyd Offline
Loc: Marshfield , MA
Originally Posted By: WANG
I like this stuff.
Me too. I use it with a gasket though. I would spend the money for a new gasket. Goop it on both sides with the Forma- gasket, let the stuff cure for 20 minutes
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3197914 - 11/25/13 04:20 PM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
heynow Offline
Loc: Nevada
Considering that it is holding back full engine oil pressure, I would get a new oem replacement gasket. I also try to avoid using any rtv or sealant where it could potentially plug an oil passage.
1991 Acura NSX
1991 Suzuki Samurai
#3198388 - 11/26/13 05:50 AM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
Smoky14 Online   content
Loc: Nowhere NM
Put a straight edge across the pieces to make sure they are not deformed.
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
#3198456 - 11/26/13 07:31 AM Re: what gasket maker sealant to use on this (pic) [Re: Smoky14]
The_Eric Offline
Loc: Iowa
This^^^^^
And THIS^^^^^
Failing both of those, I'd recommend Permatex Ultra Grey and no gasket. Clean with a residue free cleaner, apply, assemble and let sit overnight. You'll have no leaks.
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
#3198733 - 11/26/13 01:23 PM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
1 FMF Offline
Loc: CT
i got a new gasket from the dealer today, $5.
it's different from the oem one, i assume they redesigned it seeing how the original one was seeping.
the new one is more metallic entirely with a metal sealing ring in
the center. there is no rubber material in it like in the original one pictured in my first post. and this new gasket is pre-bent in the center sort of, so when it's installed and you clamp the parts together it crushes the gasket straight and causes it to seal. I'm pretty sure it's a one time use gasket.
there is no warpage. the aluminum block pictured above is thick, and it is straight. and the mating surface on the block is straight.
and when did aviation #3 come out? what's the difference between #3 and #2 ?
I also have permatex hylomar hpf gasket dressing and flange sealant.
I don't plan on removing this part ever again.
what would be best to use, the hylomar or the aviation #2 ?
here is a pic of the new gasket
Edited by 1 FMF (11/26/13 01:34 PM)
#3199184 - 11/26/13 09:52 PM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
1 FMF Offline
Loc: CT
never mind about the aviation #3 #2, i have an old bottle that doesn't say #3 on it and for some reason thought it said #2.
ended up going with very light coat of permatex aviation on both mating surfaces. if it ever leaks i'll post back.
#3199209 - 11/26/13 10:03 PM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
The_Eric Offline
Loc: Iowa
It won't.
#3200731 - 11/28/13 05:25 PM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
Merkava_4 Offline
Loc: Clovis, CA
For that gasket with the o-ring, I'd either use Permatex Ultra Black, or the Permatex rubber gasket dressing.
#3200763 - 11/28/13 06:08 PM Re: what gasket maker sealant to use on this (pic) [Re: 1 FMF]
01rangerxl Offline
Loc: Birmingham, AL
I use Permatex Gray on both sides of the original gasket when I do these at work on '99-'06 LS engine trucks. I don't know if that's the best way, but it seems to work. They don't leak afterwards. This is a pretty common leak point on LS engines. Luckily it's a very easy fix.
I would imagine Right Stuff would also be good for this. I'm sure the Aviation Form-A-Gasket will work great too. It's not a complex thing to seal off.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 180K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 176K miles
Page 1 of 2 1 2 >
