1999 ford expedition factory mercon v synthetic??
by merconvvv
07/23/16 11:40 PM
Buick 3800 - "Von Voyage" oil change?
by Alex_V
07/23/16 10:41 PM
Low oil level light on, but level not THAT low....
by gregk24
07/23/16 10:26 PM
Is SuperLube syn multi grease universal
by NattyBoh
07/23/16 10:05 PM
How come discount tire doesn't use jack stands?
by motor_oil_madman
07/23/16 09:41 PM
SAFETY ?: ramps in rear and jack stands in front
by SavagePatch
07/23/16 09:03 PM
Pennzoil ultra 5w30 back in stock at Walmart.com
by kohnen
07/23/16 08:37 PM
Homelite weedeater not getting fuel
by Drew99GT
07/23/16 08:26 PM
Stability issue on 2015 F250
by Donald
07/23/16 07:25 PM
2016 Tacoma 3.5L V6 4x4
by NavyVet88
07/23/16 07:10 PM
Question on 05 Nissan tranny w/120k
by NattyBoh
07/23/16 06:58 PM
Denso FTF oil filters
by mclasser
07/23/16 06:50 PM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
56 registered (ag_ghost, 4WD, 69GTX, 41 Plymouth, aquariuscsm, 6 invisible), 1260 Guests and 15 Spiders online.
58578 Members
66 Forums
252173 Topics
Page 1 of 2 1 2 >
#3195186 - 11/22/13 07:53 PM Diesel Exhaust fluid
Dually Offline
Loc: Long Island/New York
Down the road I'm looking into a BMW 328D or a Audi Q5 TDI.My question is can the diesel exhaust fluid be toped off every two months or when ever I want to or do I have to wait until a certain amount is used?Thanks Joe
2006 Jeep/Grand Cherokee Overland/Hemi-5.7 lite/6K OCI/Gold Plug oil drain plug/Castrol 5W-20
#3195195 - 11/22/13 08:03 PM Re: Diesel Exhaust fluid [Re: Dually]
NHGUY Offline
Loc: USA
Topping off should be no problem.Its when it gets low and the light comes on...dont ignore it.The engine will cease to operate to keep the EPA Feds happy.
#3195207 - 11/22/13 08:17 PM Re: Diesel Exhaust fluid [Re: Dually]
Fleetmon Offline
Loc: Pa
you can top off anytime you want. I'm not sure about the 328d but the X5d has two tanks.....each (11k mile.....I change mine at 5k) oil change gets about 2 gallons of DEF.
"In order to become the Master, a person must act as a servant."
NRA Endowment Member
#3195211 - 11/22/13 08:22 PM Re: Diesel Exhaust fluid [Re: Dually]
Spazdog Offline
Loc: Arlington
I read somewhere that BMW gives you like 1000 miles of warnings when the DEF gets low.
Some of the Fords coming in have had a warning that they will be limited to 50 mph if the DEF is not refilled within XXX miles. I think the BMWs just prevent you from starting.
2013 Chevrolet Cruze Eco - dealer Dexos
2014 Chrysler 200S - Whatever the dealer put in it.
1987 Honda CN250 Helix - Penn Platinum Euro5W40
#3195222 - 11/22/13 08:39 PM Re: Diesel Exhaust fluid [Re: Dually]
bigjl Offline
Loc: London, England
What is this DEF fluid?
Is it Eloys of AdBlue (urea)
The AdBlue systems are currently being introduced by the likes of BMW and Merc on high end diesels, though as Euro 5 is the current reg snd these meet Euro 6 it is still an option.
Eloys fluid on UK models fitted with that system usually require a top up every 75k miles. Apparently a small amount is injected into the tank every time you put fuel in so if you tend to put in a couple of gallons at a time rather than top off it csn need done early.
As far as the AdBlue systems i believe they have an extra filler cap beside the diesel one and you fill up as and when.
A lot of the High End London Chauffeur companies are buying vehicles with this system, likely for marketing reasons than any genuine enviromental concerns
14 Kia Picanto 1.0 City 10k miles. Kia 5w30
07 Citroen Berlingo Multispace 1.4i 39k 10w40 Maxlife
#3195250 - 11/22/13 09:15 PM Re: Diesel Exhaust fluid [Re: Dually]
Eddie Offline
Loc: Florida, Cape Coral
What is the cost per gallon of this fluid?
CX5 Touring 2.5L :-)
#3195296 - 11/22/13 10:30 PM Re: Diesel Exhaust fluid [Re: Dually]
earlyre Offline
Loc: Lima, Ohio, USA
I have noticed some of the truckstops now have DEF available @ the pumps.(seperate nozzles)
Mine:
09 Mercury Sable : 6qts QSAD 5w20,WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts QSAD 5w30,WIX 51394
#3195305 - 11/22/13 10:47 PM Re: Diesel Exhaust fluid [Re: bigjl]
Spazdog Offline
Loc: Arlington
DEF is Diesel Exhaust Fluid.
I think AdBlue is a brand name but it's the same stuff
#3195312 - 11/22/13 10:59 PM Re: Diesel Exhaust fluid [Re: Dually]
Miller88 Offline
Loc: Onondaga County
Ever get behind one of these? Burns your nostrils like acetone!
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3195338 - 11/22/13 11:48 PM Re: Diesel Exhaust fluid [Re: Dually]
mattwithcats Offline
Loc: Virginia
Urea breaks down into ammonia,
which then breaks down Nitrogen Oxides (N2).
http://en.wikipedia.org/wiki/Diesel_exhaust_fluid
Ammonia gas is somewhat toxic, so
you can't put this in your car,
you have to make it by urea breakdown with heat...
Edited by mattwithcats (11/22/13 11:56 PM)
2009 Smart Pure
Pennzoil Platinum Euro 5W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#3195367 - 11/23/13 03:57 AM Re: Diesel Exhaust fluid [Re: Dually]
Boomer Offline
Loc: Pennsylvania
I think I paid $12 for several gallons at the VW dealer but you can get DEF at WalMart and other stores for less.
2003 Saturn L 300 128,200 miles
2013 VW Passat TDI SE, 33,300 miles
2014 VW Jetta TDI SportWagen 18,055 miles
#3195379 - 11/23/13 05:48 AM Re: Diesel Exhaust fluid [Re: Dually]
Fleetmon Offline
Loc: Pa
I think it's like $22 a gallon (sold in 1/2 gal easy-fill containers for $11 or 2-1/2 gal containers for $??) at my local BMW dealer but most of that is probably due to the special fill nozzle required to fill the tanks...I cut the bottom out of one and use it as a "funnel". Ad Blue or other DEF is around $2.50 per gallon.
Usage for vehicles comes out around 3% of diesel burned or so.
FWIW, I've occasionally noticed a very slight ammonia-like odor when I first back out of the garage and walk behind my X but I have NEVER smelled ammonia-like odors behind other vehicles on the road nor any of the HD equipment we have at work and that includes street sweepers, buses, fire equipment and LD/HD trucks.
#3195497 - 11/23/13 08:58 AM Re: Diesel Exhaust fluid [Re: Dually]
TiredTrucker Online   content
Loc: Central Iowa
Current price for DEF at my local truck stop is $2.87 a gallon. Wally World probably can compete favorably with that in those 2.5 gallon containers they have on the shelf. I have never know that the exhaust from one of these burns like acetone.... that is unless the Diesel particulate filter (separate issue) is going thru a regen cycle. Now that is really nasty if you are behind a diesel going thru that cycle.
In order to know what is bad, you have to know what is good. The question them becomes, what is the source of knowing what is good?
#3195868 - 11/23/13 04:35 PM Re: Diesel Exhaust fluid [Re: Dually]
bdcardinal Offline
Loc: Santa Barbara, CA
Ford wants $6.15 for the one gallon bottle of DEF, and $13.54 for the 2.5 gallon jug of DEF. They also have a specific funnel that prevents spilling that is $5.93. The nozzle used to come with the fluid free, but now they charge the dealers for them.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#3195883 - 11/23/13 05:09 PM Re: Diesel Exhaust fluid [Re: earlyre]
Ramblejam Offline
Loc: Kentucky
Most do, for example: http://www.pilotflyingj.com/pump-def?per_page=0
Page 1 of 2 1 2 >
