Maintenance on a Mint Low Mileage 2001 S2000
by Thugzy
02/09/16 11:54 AM
AutoZone Game...cash and gift cards
by eddielasvegas
02/09/16 11:51 AM
Dual platinum and iridium sparkplugs vs. standard
by DrRoughneck
02/09/16 11:31 AM
Kendall Super-Dxa 15W-40 SynBlend
by 2015_PSD
02/09/16 10:05 AM
2015 Ford F-250 6.7L MC Filter (9,800 miles)
by 2015_PSD
02/09/16 10:01 AM
Royal Shrovetide Football
by Whitewolf
02/09/16 10:01 AM
Intro and seeking used oil drums for small shop
by CRXPilot
02/09/16 09:47 AM
5000 mile OCI on dino?
by Whipped500
02/09/16 08:57 AM
API SG,SJ and SL Zddp levels
by FordCapriDriver
02/09/16 08:49 AM
GearWrench 3680D serpentine belt tool - $24
by pjhalifax
02/09/16 08:25 AM
Changed out GM plugs 169,000 miles pics
by WobblyElvis
02/09/16 08:18 AM
Kreen harsh on fuel system components?
by jqgz
02/09/16 07:54 AM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
102 registered (akela, 3800Series, ARCOgraphite, Andy636, AlaskaMike, aircooled, 6 invisible), 1583 Guests and 207 Spiders online.
56865 Members
66 Forums
244445 Topics
Page 1 of 4 1 2 3 4 >
#316060 - 04/22/03 02:27 AM Which brand of oil filter has the best anti-drainback valve?
Mystic Offline
Loc: Colorado
Which brand of oil filter has the best adbv? This is really important to prevent start-up wear.
#316061 - 04/22/03 02:31 AM Re: Which brand of oil filter has the best anti-drainback valve?
digitaldrifter91 Offline
Loc: cali
i think the silicone anti drain back valves are alot better at stopping drain back. those are higherer quality, though i dont know which filter is the BEST.
#316062 - 04/22/03 02:51 AM Re: Which brand of oil filter has the best anti-drainback valve?
Mystic Offline
Loc: Colorado
The reason I ask this question is because I once tried a FRAM on a Toyota I owned and when I changed the oil and filter there was no oil whatsoever in the filter, even though the filter had an anti-drainback. People are told that most wear occurs at start-up, which means you must have a good anti-drainback. But recently in the oil filter tests, Bob has found that flow is really important-a FRAM may be better than a Mobil 1 oil filter when it comes to flow. So an oil filter that has good flow is important. Personally, I would still be nervous about using a FRAM. Maybe a K&N would have good oil flow and a good anti-drainback?
#316063 - 04/22/03 03:09 AM Re: Which brand of oil filter has the best anti-drainback valve?
Loc: cali
one question we all had was that how much restriction flow can an anti drainback have on a filter. the regular fram had alot of flow, u remember that right. but then bob showed the higher quality fram with the silicone anti drainback valve which is stiffer than the normal one and the flow was wayy less. i was thinking that that anti drainback valve does have some resistance.
how is ur filter mounted though? vertical?
what oil filter companies are you concidering?
pure one has the silicone drain back valve (orange) and the person at PureOne told me in a email that a silicone anti drain back valve holds up alot better than a normal rubber. thats why their line of pure one held that valve.
#316064 - 04/22/03 07:11 AM Re: Which brand of oil filter has the best anti-drainback valve?
Rick in PA Offline
Loc: Southeastern, PA
Just a thought, I wonder if the silicone anti-drainback valve is more important in the winter? For some reason, I suspect that the silicone elastomers are less affected by low temperatures than nitrile rubber (or whatever it is that they use).
#316065 - 04/22/03 07:32 AM Re: Which brand of oil filter has the best anti-drainback valve?
2K2AcuraTL Offline
Loc: Ottawa, Ont CANADA
Just an observation on my 3.4lt GM V6. (1998)
Since have switched to K&N from Fram.. [Roll Eyes]
The cold start up valve chatter has almost disapeared, generally using M1 oil. I may try a Wix filter next, But K&N has served me well..
Jean
#316066 - 04/22/03 07:45 AM Re: Which brand of oil filter has the best anti-drainback valve?
Mystic Offline
Loc: Colorado
Someone said in a post a while back that any oil filter is going to lose the oil in it after a car or truck has been sitting for eight hours. I have also heard that some brands of oil filters are better than others at not losing the oil in the oil filter after the engine is shut off. It seems to me that there are several things a oil filter must do. The oil filter must allow good oil flow. The oil filter must filter well. The oil filter must allow oil to flow through it if the oil filter gets plugged. And if an anti-drainback is required on a filter, that adbv must work properly and at the correct pressure. My car is a Saturn SL2 with the oil filter mounted in a horizontal position (it is the pits to reach). It requires an adbv. As far as I have been able to determine, FRAM makes the orginial equipment Saturn oil filter. I have tried several brands of oil filter, trying to find the best one for my car. I tried the Mobil 1 oil filter, but it is expensive and it disturbs me that the Mobil 1 is designed for engine size and not more precisely for the particular type of vehicle it will be on. And then I heard about the filter tests and how the Mobil 1 did not flow so good. My favorite filter had become the Wix but now I hear there may be some questions as to its flow. I have used the Amsoil which is expensive and I have to order it and have it shipped to me. I guess the next oil change I will use a K&N.
#316067 - 04/22/03 08:02 AM Re: Which brand of oil filter has the best anti-drainback valve?
cryptokid Offline
Loc: palm beach
the adbv in my opinion is over rated.
it only holds oil in half the filter (remember there is an inlet and an outlet. you cant plug one hole and leave the other open and expect it to stay 100% full)
thats like putting a cap on a bottle of water to prevent evaporation, and not doing anything about the hole in the bottom of the bottle.
although that analogy is not entirely accurate for this discussion, as the adbv WILL help, but it is still over rated.
#316068 - 04/22/03 08:58 AM Re: Which brand of oil filter has the best anti-drainback valve?
Loc: cali
i agree with you.
#316069 - 04/22/03 09:37 AM Re: Which brand of oil filter has the best anti-drainback valve?
Employee#08 Offline
Loc: Toronto, Ontario
quote:
If it is the 2.2L in the Toyota's then the oil filter sits vertical on the block. I've never had oil in the oil filters when I changed out the oil filter in this application. From OEM, Bosch, and Purolator. What gives?
#316070 - 04/22/03 09:43 AM Re: Which brand of oil filter has the best anti-drainback valve?
cryptokid Offline
Loc: palm beach
another thing i happen to realise is that the adbv also causes a pressure loss.
this is because it relies on pressure to form a seal, pressure that must be broken and constantly held open, although the pressure loss is most likely small, perhaps 1-5psi. just try sucking on the exit hole of a NEW oil filter, you can "feel" the adbv open and shut.
is the oil pressure loss of a couple psi a big deal? nah not at all. however its just one more thing to think about, esp in older worn out engines in which they are in the danger levels of low oil pressure. if you can spare a couple psi, i still think the adbv is a worth while thing to have, but dont prop it up as some almighty engine saver.
probably the best solution is to install a remote oil filter very low (as low as the oil pan or lower) and have it mounted vertical so it is awalys filled with oil. then you do not need an adbv, so pressure loss would be nill.
#316071 - 04/22/03 09:45 AM Re: Which brand of oil filter has the best anti-drainback valve?
cryptokid Offline
Loc: palm beach
i suspect the oil is draining from the center of the filter. it probably still retains oil in the outside portion however. next time you do an oil change and note that there is no oil in the filter, take the old filter and punch a hole in the caseing with a nail. see if oil now leaks out?
#316072 - 04/22/03 05:18 PM Re: Which brand of oil filter has the best anti-drainback valve?
dickwells Offline
Loc: Northern Illinois
The center hole in the filter is where the oil is attempting to enter the filter and "drain back" so it is not a leak point. I have had Pure 1 filters that sat on my drain pan for a week or more and I still had to put a nail in the ADBV hole to push the silicone out of the way and let it drain so, at least for that filter, the valve was working fine. Just saw a strange effect on my 02 4.3 Chevy truck. I was letting the pan drain while I loosened the filter. As the filter broke loose and started to leak, a small gusher of oil also came out of the pan drain hole. The filter must have loosened enough to allow the oil to run across the mounting plate and run through the oil pump. I dunnoe [I dont know]
#316073 - 04/22/03 06:47 PM Re: Which brand of oil filter has the best anti-drainback valve?
cryptokid Offline
Loc: palm beach
what you expierence with your truck may be the result of the location of the filter relative to oil galleys.
example: oil wont flow upwards while the engine is off, so if the filter is below the oil galleys, it most likely wont drain off through the outlet.
not all engines are like this, however, most notable a mazda rotary, which mounts its filter on the top of the engine. almost as high as the carborator.
think of it like this: fill up a pringles can with motor oil. now set the pringles can on its side and not how much oil comes out.
now turn the can upside down, and note the ramining oil that dribbles out.
on a side mounted filter or upside down filter, the oil may take longer than the pringles can to empty, as engines have tighter clearences than a gaping wide hole. but it should still happen, depending on the engines oiling configuration relative to filter hight v.s galley.
i wont dispute that avbd holds oil in the outer portion of the filter. but on my engine the center tube is awalys empty when the filter is removed, and no extra oil gushing happens after a 15 minute drain period.
#316074 - 04/22/03 07:34 PM Re: Which brand of oil filter has the best anti-drainback valve?
ToyotaNSaturn Offline
Loc: Spring Hill, TN
Have you been able to actually reach the oil filter without jacking the car up? I bought a set of ramps from WalMart, but would love to take them back and save the $$ if I only could figure out how to get my hand waaaaayyyy back there. My car is a 96SL2, DOHC with A/C and manual trans. Id imagine the base model SL would be easier without the power steering pump in the way.
