What the heck is this?
by Jake777
40 minutes 46 seconds ago
New Dilbert & Far Side desk calenders
by Eddie
47 minutes 40 seconds ago
Pronto vs Napa Proselect
by mazdamonky
Today at 10:35 AM
Oreilly: QS-Advance & Microguard Special
by Greg L
Today at 10:25 AM
Oil filter, to change or not?
by otis24
Today at 10:08 AM
Changing Oil By Time Instead Of Mileage ??
by billt460
Today at 10:07 AM
OLM goes down with car sitting up?
by mobilaltima
Today at 10:03 AM
VOA on two cST@40 automatic tranmission oils
by quick_16
Today at 09:59 AM
toyota brand filters
by wjli
Today at 09:56 AM
Windows Users and Dual Boot
by javacontour
Today at 09:47 AM
Cutter for 5" and up filters
by car51
Today at 09:38 AM
Baldor Grinders: Red vs. Blue
by cdm1993
Today at 09:30 AM
phem0r, 19kj57, coke, curious2, robco
56879 Registered Users
101 registered (97K15004WD, Astro14, 2015_PSD, 55Test, Astro_Guy, 6 invisible), 1609 Guests and 113 Spiders online.
56879 Members
66 Forums
244500 Topics
#3141710 - 10/01/13 04:33 PM One spark plug carbon fouled??
callbay Offline
Loc: Ozark Mountains
20 HP Kohler V twin. Engine was missing so I put in new plugs. The exact Champions the manual called for. One of the old ones was carbon fouled. The other one normal. It ran well with the new plugs for a few minutes but then fouled the plug again and started to miss again.
The welder/generator has about 1,200 hours on it.
Any ideas?? Thanks!
#3141741 - 10/01/13 05:09 PM Re: One spark plug carbon fouled?? [Re: callbay]
nitehawk55 Offline
Loc: Ontario , Canada
It's running rich for some reason . Is the air filter OK ? , if it is I would suspect an issue with the carb which is likely if it's been sitting for a time unused . It may also be possible the coil to that plug is weak and misfiring .
I have the same engine in my New Holland/Toro lawn tractor and it's been fine with plugs .
05 Ford Five Hundred AWD 3.0 DOHC V6 CVT tranny
#3141749 - 10/01/13 05:17 PM Re: One spark plug carbon fouled?? [Re: callbay]
callbay Offline
It has a brand new air filter and prefilter.
#3141879 - 10/01/13 07:36 PM Re: One spark plug carbon fouled?? [Re: callbay]
Zaedock Offline
Loc: Massachusetts
Kohler V twin - check the head gasket on that cylinder.
2012 F150 Ex-cab 5.0L/2004 Malibu Maxx LT
1992 YJ "The Heep"/1994 Olds Cutlass Ciera 3.1/auto
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#3141885 - 10/01/13 07:40 PM Re: One spark plug carbon fouled?? [Re: callbay]
bubbatime Offline
Loc: South Florida
Worn rings on one cylinder?
10 Acura TSX 2.4L Quaker State syn 5W20 Fram Ultra
09 Chrysler Town & Country 4.0L Chevron Supreme 10W30
06 GMC Sierra 4.8L QSGB 5W30 Delco PF46
#3141895 - 10/01/13 07:50 PM Re: One spark plug carbon fouled?? [Re: callbay]
NHGUY Offline
Loc: USA
I prefer Autolite or NGK plugs.Although the "easy start" Champions arent bad.
#3141988 - 10/01/13 09:14 PM Re: One spark plug carbon fouled?? [Re: callbay]
jhellwig Online   content
Loc: Ottumwa, Iowa
If it fouled one while running you have an issue. Was the plug that fouled while running wet with fuel or oil?
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2013 Chevy Traverse lt 3.6l direct injection
1983 Chevy K5 350
#3142515 - 10/02/13 12:43 PM Re: One spark plug carbon fouled?? [Re: callbay]
callbay Offline
The spark plug that was fouled was dry.
#3142877 - 10/02/13 06:42 PM Re: One spark plug carbon fouled?? [Re: callbay]
Loc: Ottumwa, Iowa
I would look at a coil issue or plug wire then.
1983 Chevy K5 350
#3143087 - 10/02/13 08:27 PM Re: One spark plug carbon fouled?? [Re: callbay]
JR Offline
Loc: Michigan born but my heart bel...
If one was clean on fould it is ignition. problem . air and fuel are good since. one plug is clean. check spark. i know the inline style ignition. tester increase the ignition. out put at the plug. i think the coil for that cylinder is weak not dead weak. if it was dead it would miss on the fresh plug. it is weak causing incomplete. combustion. hint the fould plug. that or
ken.
