I got 'spoofed' !
by Geauxtiger
05/02/16 07:57 PM
2013 Camry DIY Brake Fluid Replacement Experience
by windeye
05/02/16 07:26 PM
Pics Husky 525LS ran on XP oil
by Buzzsaw
05/02/16 07:09 PM
Brake Pad and Rotor opinions
by oilstudent24
05/02/16 07:02 PM
Desmo Variable Valve Timing Video
by LoneRanger
05/02/16 06:29 PM
Avalanche
by 94 saturn sl1 2000 saturn sc2
05/02/16 06:15 PM
Bardahl
by jk_636
05/02/16 05:54 PM
'96 Chrysler Sebring with 2.4
by outoforder
05/02/16 05:23 PM
Accident, no citation, insurance?
by Throt
05/02/16 04:58 PM
Got a Speeding Ticket today
by larryinnewyork
05/02/16 04:39 PM
Anyone remember "in living color" ?
by car51
05/02/16 04:14 PM
schedule / oil recom. for 2015 Honda Accord V6
by Viche
05/02/16 03:38 PM
stydel311, jackadf, rlb4, apenland01, 2ManyMiles
57767 Registered Users
116 registered (awoess, abycat, 06AllAmerican, asand1, 3800Series, Abakev, 10 invisible), 1889 Guests and 314 Spiders online.
57767 Members
66 Forums
248380 Topics
Page 1 of 2 1 2 >
#3137109 - 09/26/13 09:15 PM How do you disconnect GM fuel injector connector?
Merkava_4 Offline
Loc: Clovis, CA
2000 Buick LeSabre 3800 V6
I'm thinking I might need to move the engine harness a little bit to clear the rear valve cover. I'm thinking about disconnecting the 3 fuel injector connectors on the rear of the engine. How do you disconnect the electrical connector from the fuel injector?
#3137118 - 09/26/13 09:25 PM Re: How do you disconnect GM fuel injector connector? [Re: Merkava_4]
1 FMF Offline
Loc: CT
there's a retainer clip around the round cylinder part of the fuel rail that holds the rail on to the injector. not the plastic looking wire retainer in the foreground holding the electrical oonnector. the retainer round the rail will push inward toward the intake and release the rail from the injector. that's how i did it pulling them on my 2006 8.1L. my electrical connectors were different looking than yours. when you undo the rail retainers, the rail will take considerable force to pull up off the injector, the o-ring will be dried out and holding the rail on. once you get the rail off, it'll be easier to figure out the electrical connector. you'll need a good flat blade screw driver to push the rail retainers off, they are tight.
#3137130 - 09/26/13 09:37 PM Re: How do you disconnect GM fuel injector connector? [Re: 1 FMF]
Merkava_4 Offline
Loc: Clovis, CA
Thank you sir, but I don't want to pull the injectors at this time. I just wan't to
disconnect the electrical connector from the fuel injector - how do I do this?
#3137134 - 09/26/13 09:39 PM Re: How do you disconnect GM fuel injector connector? [Re: Merkava_4]
Chris142 Offline
Loc: apple valley, ca
Push or pull that metal clip out.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3137149 - 09/26/13 10:01 PM Re: How do you disconnect GM fuel injector connector? [Re: Merkava_4]
Trav Offline
Loc: MA, Mittelfranken.de
Use a small flat blade screwdriver to pop the metal clip on the sides of the connector, it will pop out on one side then move to the other.
Install the metal clip on the connector first then just push it on till it clicks to reinstall.
No need to fiddle trying to install the clips with the connector on the injector, that would be a nightmare.
#3137162 - 09/26/13 10:22 PM Re: How do you disconnect GM fuel injector connector? [Re: Merkava_4]
paulo57509 Offline
Loc: Tracy, CA
Grab the injector and squeeze the metal clip and the injector together and pull the connector off the injector.
Do not pry off the metal clip from the connector. It is not necessary to do so. Re-connect by snapping the connector back onto the injector.
1987 Chevrolet Camaro IROC-Z 5.0L
1987 Acura Legend L Coupe 2.7L (5-Speed)
1992 Lumina Euro Coupe 3.1L
1998 Lexus LS400
2003 GMC Safari
#3137163 - 09/26/13 10:22 PM Re: How do you disconnect GM fuel injector connector? [Re: Merkava_4]
cmorr Offline
Loc: Exeter Twp, PA
No screwdrivers, just press in the front of that bale, it will flex and allow you to pull off
2008 Focus Mobil 1 5W20 Napa Platinum
2006 Caravan Defy 5W20 Napa Gold
2003 PT Cruiser PYB 5W30 Pureone
#3137164 - 09/26/13 10:23 PM Re: How do you disconnect GM fuel injector connector? [Re: Trav]
The_Eric Offline
Loc: Iowa
Easier yet, just squeeze it. I use my thumb on the curved wire section and my index finger on the back of the plastic connecter. Squeeze and pull. To reinstall, just push back on until you hear a click.
Edit: I need to learn how to type faster. cmorr and paulo beat me to it.
Edited by The_Eric (09/26/13 10:25 PM)
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
#3137190 - 09/26/13 11:13 PM Re: How do you disconnect GM fuel injector connector? [Re: cmorr]
Trav Offline
Yep your right. I was thinking of the square ones i just did on a Euro car. My bad.
#3137217 - 09/27/13 12:51 AM Re: How do you disconnect GM fuel injector connector? [Re: Trav]
Merkava_4 Offline
Loc: Clovis, CA
I got it off! smile2 All I had to do is push the wire clip in at the same time as I'm pulling upwards. I found it easier to do it with two hands - one to push in the wire clip in and the other to pull the connector straight up. I also found out that in order to get the connector back on, it's best to push the wire clip in first before pushing the connector on. Thanks fellas. smile2
#3137261 - 09/27/13 05:19 AM Re: How do you disconnect GM fuel injector connector? [Re: Merkava_4]
Falken Offline
Loc: Montreal, QC, Canada
Use needlenose pliers to pull the belly of that U Clip straight out like the pin on a grenade.
It has flared feet on the two legs of the U so it doesn't fall out from engine vibration.
Falken - Draftsperson
2010 Honda Fit DX-A in Black
Current Fill: Formula 1 Synthetic 5W20 SN, Wix 57356 Oil Filter, ATF DW-1
#3137308 - 09/27/13 06:54 AM Re: How do you disconnect GM fuel injector connector? [Re: Trav]
The_Eric Offline
Loc: Iowa
Those are annoying. The first time I did one, I was thinking that there was going to be some ingenious German thinking designed into it. Boy was I wrong... Trying to get some of those clips off can be fun in tight quarters.
#3137496 - 09/27/13 10:05 AM Re: How do you disconnect GM fuel injector connector? [Re: Falken]
cmorr Offline
Loc: Exeter Twp, PA
Nope, that's a quick way to mangle them, press/squeeze the bale with a thumb and pull up on the connector (OP confirmed removal this way prior to your post)
I posted a photo off the connector, imagine the damage puling that metal clip with pliers would do (in the prior photo you can see how it's curved up in the back to keep it from being removed)
Am waiting for the day someone really fubars their car here based on "advice" given by someone
#3137735 - 09/27/13 02:24 PM Re: How do you disconnect GM fuel injector connector? [Re: cmorr]
paulo57509 Offline
Loc: Tracy, CA
You don't have to wait days. I bet it happened a few minutes ago. grin2
1998 Lexus LS400
2003 GMC Safari
#3137972 - 09/27/13 06:12 PM Re: How do you disconnect GM fuel injector connector? [Re: Merkava_4]
Falken Offline
[censored] that is how I recall doing it in the past but it was at school.
Hope it didn't crack the housing.
Maybe I got it confused with disconnecting the clutch line from the slave cylinder. It is a similar looking retaining clip.
I think I am going to lay off giving advice for a while I feel really out of it lately.
Edited by Falken (09/27/13 06:14 PM)
Page 1 of 2 1 2 >
