OK, before I lube it ...
by BrocLuno
4 minutes 46 seconds ago
Toyota Japan Fluid SDS
by SXE10
Yesterday at 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
Yesterday at 11:25 PM
Considering a differential swap
by buck91
Yesterday at 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
Yesterday at 09:51 PM
Car Acronyms
by Marco620
Yesterday at 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
Yesterday at 09:41 PM
Carpet cleaning methods.
by Run
Yesterday at 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
Emtrac Plus Battery
by Tapan
Yesterday at 09:25 PM
Did you know of Mr. Urban?
by CourierDriver
Yesterday at 09:19 PM
Ever Been a Successful Front Suspension Rebuild ?
by CrackyWainwright
Yesterday at 09:06 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
33 registered (CR94, bdcardinal, anonobomber, bvance554, BrocLuno, ag_ghost, 4 invisible), 977 Guests and 9 Spiders online.
58295 Members
66 Forums
250914 Topics
Page 1 of 2 1 2 >
#3112375 - 09/02/13 06:37 AM Oil Additives for Valve Seals
Tack Offline
Loc: Nova Scotia Canada
This is my first post, i have a 1984 suzuki sj410 1L F10A engine, i had to replace the engine, i found one from a 1984 Suzuki with only 33,532 Km on it, i ck it out removed the base and valve cover and it was clean clean, it is now in and works great EXCEPT it smokes a lot when i first start it up the rest of the day it is ok, so valve seals, my question is is there any oil additive that i could put in to help the valve seals?? or soften them up.
Any help would be appreciated..
#3112379 - 09/02/13 06:56 AM Re: Oil Additives for Valve Seals [Re: Tack]
demarpaint Offline
Loc: NY
You could try a High Mileage Oil before you start trying any additives. Honestly depending on just how hard the seals are they might need to be replaced, especially in an engine that old.
God Bless Our Troops
#3112388 - 09/02/13 07:14 AM Re: Oil Additives for Valve Seals [Re: Tack]
Falcon_LS Offline
Loc: Kuwait
Liqui Moly Motor Oil Saver is an ester based product I've used in the past for valve seals. Give it about 700-800 miles to work.
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: GC 0W40/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: GC 0W40/M1206
#3112457 - 09/02/13 08:48 AM Re: Oil Additives for Valve Seals [Re: Tack]
Quest Offline
Loc: beaver land EH?
LOL! instead of playing with magical elixir, why don't you cut to the chase and get those valve stem seals replaced?
Those are typically 2-valves per cylinder engines with SOHC. replacing the valve stem seals should take you( your indy mech) less than 2 hrs tops to replace all 8 of them.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3112502 - 09/02/13 09:46 AM Re: Oil Additives for Valve Seals [Re: Quest]
Clevy Offline
Loc: Saskatoon canada
Falcon is right. Motor oil saver is some pretty great stuff. I'd try that first and try to delay the inevitable until I had the money to fix it.
However once you add motor oil saver it might no longer need fixing.
Q.
Did you even read the question. He didn't ask for someone to tell him to fix the valve seals,he asked if there was an additive that might help.
Apparently you don't have an answer yet felt the need to add anyways. Interesting trait.
2006 Charger RT
Miles x 2 per oil filter
#3112526 - 09/02/13 10:15 AM Re: Oil Additives for Valve Seals [Re: Tack]
OVERKILL Offline
Loc: Ontario, Canada
Valve stem seals for this engine are $1.95:
http://www.22re.com/main/suzuki/sj410.asp
You need eight of them.
This is what your head should look like:
You are going to spend more on additives than you are to fix the problem properly IMHO, it just makes sense to fix it right the first time.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3112529 - 09/02/13 10:19 AM Re: Oil Additives for Valve Seals [Re: Falcon_LS]
demarpaint Offline
Loc: NY
It completely slipped my mind. If the HM oil I suggested didn't work it might be worth a try, although I'd probably swap out the seals if the HM oil doesn't work.
#3112539 - 09/02/13 10:26 AM Re: Oil Additives for Valve Seals [Re: Tack]
Brent_G Offline
Loc: Aberdeen SD
No mechanic in a bottle is going to fix a mechanical issue. You can try the above and they may slow burning a bit or they might not. If the smoke in the morning bothers you, just fix the cause and put seals in.
Just my .02
05 Grand Prix GTP
01 Ford F150
06 Yamaha R1
69 Roadrunner 528 Hemi
68 Dart GTS 512
71 Superbee's 440 and 383
87 Camaro 540 BBC
#3112561 - 09/02/13 10:56 AM Re: Oil Additives for Valve Seals [Re: Tack]
Tack Offline
Thanks for all your replies, that is a pic of the head alright, so i guess the best thing to do is replace them, i already have a set of seals they came in the gasket set, so as they say bite the bullet and do it, the engine works so good, smooth and quiet, so now i will get rid of the start up smoke.....
#3112570 - 09/02/13 11:01 AM Re: Oil Additives for Valve Seals [Re: Tack]
OVERKILL Offline
Makes it a no brainer, particularly given how easy that engine is to work on thumbsup
Best of luck and let us know the outcome of your endeavour please! If you don't mind, you could take some pics of the process and post them up for us. We always like some good engine pr0n, LOL!! grin
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3112577 - 09/02/13 11:10 AM Re: Oil Additives for Valve Seals [Re: OVERKILL]
demarpaint Offline
Loc: NY
+1 Smart move!
#3112585 - 09/02/13 11:17 AM Re: Oil Additives for Valve Seals [Re: Clevy]
Quest Offline
I've done quite a few Suzukis in my days and I will only give my best/honest advice given the circumstances (in this case: a low mileage engine that otherwise still functions perfectly and all it ever needs is just valve stem seal replacements).
I don't post hollow, unsubstantiated information on BITOG, for I "walk-da-walk and talk-da-talk" and I only provide info that I have experience with and to those readers who value the most.
Q.
#3112607 - 09/02/13 11:43 AM Re: Oil Additives for Valve Seals [Re: Quest]
Brent_G Offline
Loc: Aberdeen SD
Agreed. It would be different if this was a ford modular, or some other engine that would be a royal pita to swap seals. But with how simple this should be its pointless to have him try a bunch of things that may work for a bit, or not work at all and spend money that he could put towards fixing it right.
Q.
05 Grand Prix GTP
01 Ford F150
06 Yamaha R1
68 Dart GTS 512
87 Camaro 540 BBC
#3112622 - 09/02/13 12:18 PM Re: Oil Additives for Valve Seals [Re: Quest]
dave5358 Offline
Loc: North Bend
LOL! instead of playing with magical elixir, why don't you cut to the chase and get those valve stem seals replaced? Those are typically 2-valves per cylinder engines with SOHC. replacing the valve stem seals should take you( your indy mech) less than 2 hrs tops to replace all 8 of them.
This is exactly right. If you're getting an oil smoke puff on morning start up, but the engine is otherwise running well, the valve stem seals are bad. MoS2 won't cure this. MMO won't cure this. The only fix is to replace the valve stm seals.
Depending on the exact details of your engine, this may be more or less difficult. Basically, you have to compress the valve spring, remove the spring keeper, remove the spring and related parts, remove the old seal and replace it, and then reassemble the spring and keeper.
Oh yes, you don't want the un-sprung/un-kept valve to drop down into the cylinder while you're doing all this - bummer if that happens. At least one way to prevent this is to pressurize the cylinder with an air compressor. Of course, you could just remove the cylinder head and do the job on the bench - much easier - but then you're looking at several additional steps, more parts, etc.
Find a mechanic or shop that works on Suzuki engines of your model and vintage. Ask the mechanic how they normally do this job. Every engine has its tricks and most mechanics will be glad to help you out if you're trying to do this yourself.
2006 Forester XT
2008 Corolla LE
#3112639 - 09/02/13 12:30 PM Re: Oil Additives for Valve Seals [Re: Tack]
Quest Offline
Also: if you are to do it yourself (assuming that you are cable): the top 10 philips screws that secure the rocker shafts require an impact screwdriver with proper screw bit(tight fit). one or 2 light but firm whacks with a 16oz hammer is all that it takes to unscrew them (don't wack too much for you may either strip those rather soft screws or so).
When putting those screws back: I used low strength treadlocker in the past, and just hand-tight them with screwdriver until I cannot turn no more.
They will hold their position so long as you do it the proper way.
*remember: these screws are mighty-soft so be careful (I managed to strip a few of these during my days).
As for pressurising the cylinders to hold the valves in place (during spring removal and such), you must first lower each and every piston heads to bottom (after you removed those rockers and rocker shafts), give each valve a light but firm wack with a 16oz hammer to break loose those retainers before you proceed to the rest of the procedures RE: compressing each valve springs, remove them, pry off the old valve stem seals, slip in the new ones, reverse the steps, etc.
good luck.
Q.
Page 1 of 2 1 2 >
