Does BG 44K work?
by j_mac
07/25/16 04:56 PM
First CEL on the SRT-8
by OVERKILL
07/25/16 04:00 PM
How wide are the error bars on Seq IIIG tests?
by bulwnkl
07/25/16 03:15 PM
Who watches the oil co's?
by Camprunner
07/25/16 02:44 PM
Magnetec "Edged" out?
by ARCOgraphite
07/25/16 02:34 PM
Let's talk RUM
by car51
07/25/16 02:23 PM
Any .257 Roberts Reloaders On The Site?
by 2015_PSD
07/25/16 01:18 PM
Making tacos at home
by Reddy45
07/25/16 12:41 PM
Wiring a new garbage disposal
by Hokiefyd
07/25/16 11:38 AM
Power Steering Fluid
by DWC28
07/25/16 10:07 AM
Troy-Built 4.5hp running problem
by Kestas
07/25/16 09:26 AM
Conventional oil instead of synthetic
by corndogzombie
07/25/16 08:05 AM
Luuey, Eskimio, Jngoose76, Ken_Clifton, HotDog15
58592 Registered Users
89 registered (AnthemBassMan, 69GTX, 1JZ_E46, 182RG, 2010Civic, 440Magnum, 8 invisible), 2023 Guests and 22 Spiders online.
58592 Members
66 Forums
252236 Topics
Page 1 of 4 1 2 3 4 >
#3105308 - 08/25/13 03:24 PM 10w30 vs 5w30
larryn Offline
Loc: mn
10w30 vs 5w30 when towing in hot weather 95/100F , oil will be changed after 5000 to 6000 mile 6 week trip.oil is quaker state UD.truck is an 09, 6L 1500 silverado.trailer is approx. 6800#.
#3105311 - 08/25/13 03:34 PM Re: 10w30 vs 5w30 [Re: larryn]
Realtech214 Offline
Loc: Florida
5w30 & 10w30 are the same approved
2015 Silverado Crew Cab 5.3 LT
2001 Suburban LT
- I NEVER THOUGHT I WOULD LIKE OIL SO MUCH -
#3105335 - 08/25/13 04:12 PM Re: 10w30 vs 5w30 [Re: larryn]
dparm Offline
Loc: Chicago, IL
No real reason not to use a 5w30 -- modern formulations are very stout.
2011 BMW M3 sedan ZCP
#3105369 - 08/25/13 04:50 PM Re: 10w30 vs 5w30 [Re: larryn]
gfh77665 Offline
Loc: Southeast Texas
Both great oils, but the 10-30 is a slightly better fit for this application. There will be no benefit with the "5" in hot summer towing. 10-30 is slightly better here.
#3105380 - 08/25/13 05:06 PM Re: 10w30 vs 5w30 [Re: larryn]
Eddie Offline
Loc: Florida, Cape Coral
Most #10s have a lower NOACK value, which I like with a DI engine.
CX5 Touring 2.5L :-)
#3105386 - 08/25/13 05:13 PM Re: 10w30 vs 5w30 [Re: larryn]
JOD Offline
Loc: PNW/WA
I doubt anyone can give you an answer that amounts to anything more than speculation, since there's really no information available regarding the specs of QSUD 10W30. OTOH, there is some information on the 5W30, both Amsoil's tests and PQIA test on 5W30 synthetics: link
The QSUD looked really good in that test, so I'd go with it since it's a known quantity. Lots of the speculation you hear about higher HTHS and lower NOACK in the 10W30 versions of oil often doesn't actually hold true when you look at the specs. Often times, it's just a more cheaply-made product.
#3105388 - 08/25/13 05:15 PM Re: 10w30 vs 5w30 [Re: gfh77665]
chubbs1 Offline
Loc: Merritt Island FL, USA
I disagree with this blanket statement but QSUD 5w30 (as most SOPUS "syns" are thin 30grade). You may benefit from the slightly thicker 10w30QSUD.
Personally I would use a thicker 5w30 like M1 or Syntec(Edge). You will have a higher VI and the same if not lower NOACK. 10w30 "syn" is obsolete and pointless IMO. If I was that worried I would just use HDEO 10w30.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#3105420 - 08/25/13 06:10 PM Re: 10w30 vs 5w30 [Re: larryn]
mattwithcats Offline
Loc: Virginia
First number is lubricity (how well an oil flows) when cold. Second number is lubricity when hot.
So the only difference between a 10W-30 and 5W-30 is at startup, and in cold weather...
Both are 30 weight oils when hot...
2009 Smart Pure
Pennzoil Platinum Euro 5W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#3105461 - 08/25/13 07:03 PM Re: 10w30 vs 5w30 [Re: larryn]
gfh77665 Offline
10-30 typically is a bit thicker at high temps, and is a bit more shear stable. Again, the "5" won't benefit any in this application.
#3105663 - 08/25/13 10:44 PM Re: 10w30 vs 5w30 [Re: mattwithcats]
y_p_w Offline
Loc: SF Bay Area
It's far more complicated than that. It's my understanding that a 5W-30 RC motor oil would likely provide better highway fuel economy than 10W-30.
The first number has mostly to do with cold weather flow, and the standard is actually at different temps. The second number has to do with viscosity at 100 C. What the viscosity is at any given temperate starting temperature varies greatly by the oil. Apparently some 0W-30 oils are thicker at 25 C than most 5W-30/10W-30 oils.
http://www.widman.biz/English/Tables/J300.html
It should be possible to formulate a 5W-30 that's thicker than another 10W-30 at a typical warm-weather temperature. That's not typical, but possible.
#3105745 - 08/26/13 12:49 AM Re: 10w30 vs 5w30 [Re: y_p_w]
BlueOvalFitter Offline
Loc: Cajun Country, La.
popcorn
2007 F150 XL, 4.2 V6, 4R75E Transmission
Pennzoil Platinum HM 5W30, M1-209 Oil Filter
"One Filter, One OCI!"
USA
#3105747 - 08/26/13 12:58 AM Re: 10w30 vs 5w30 [Re: y_p_w]
Garak Offline
Loc: Regina, Saskatchewan, Canada
That's absolutely true, and even 0w-30s can be thicker.
@larryn: If you're out of warranty or don't care or it's allowed in the manual, go ahead and use 10w-30. Personally, I'd use the 5w-30 in it year round, towing or not.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3106022 - 08/26/13 10:14 AM Re: 10w30 vs 5w30 [Re: larryn]
KCJeep Offline
Loc: Mahzurrah!
Out of vogue here no doubt but 10w30 is still useful and will usually work very well in about anything you care to use it in. Heavy towing, summer, exactly a situation where 10w30 would be useful or even a better choice.
2004 Jeep Grand 4.0 @ 133k Pennzoil HM 10w30 w/ 1 qt 10w40
Fram PH8A
KIA Sedona 60k, Ford Focus 115k, Chrysler Sebring 186k, Chrysler Concorde 120k
#3106058 - 08/26/13 10:58 AM Re: 10w30 vs 5w30 [Re: KCJeep]
y_p_w Offline
Loc: SF Bay Area
Years ago I was looking to get a new car and found myself in an Acura dealer. I asked if I could look under the engine bay of an NSX and then popped it and tried to figure out how to get it up. One up, there was the typical info for recommended oils, spark plugs, etc on the air filter housing. I was a bit surprised that the recommended oil was a 10W-30 when 5W-30 was pretty standard by that time.
However, what's really out of vogue these days is 30 wt oil except maybe for lawn mowers. I remember hearing someone comment that for ideal protection (but not necessarily fuel economy), 30 wt could probably work better if there weren't concerns about cold starts. If it's summer temps, it should flow pretty quickly, and if you could ensure that it only gets warm starts or that a block heater is used long enough before starting, it would be ideal.
#3106074 - 08/26/13 11:19 AM Re: 10w30 vs 5w30 [Re: BlueOvalFitter]
lexus114 Offline
Loc: Easton, PA
Originally Posted By: BlueOvalFitter
popcorn
Yeah I know right? ^^
2012 Mercedes-Benz C300 4matic
2015 Lexus RX350 AWD
