Amsoil SMF103 oil filter
I bought 2 of these filters for my VTR1000 motorcycle. 1 to use on the bike and the other to cut open and compare it with the OEM Toyo Roki and an M1-110 auto application that will fit my bike.
First impression:
Looking inside both Amsoil filters I see dirt on bypass valve. Not just one speck but about 10 large pieces of stuff in one and 5 in the other.
Cutting open the Amsoil filter reveals a puny little filter element. Here’s the measured numbers for the three filters.
Amsoil: 36 in^2 media, bypass setting around 22 psi
Toyo Roki: 94 in^2 media, bypass setting around 18 psi
M1-110: 60 in^2 media, bypass setting around 22 psi.
All three filter media look about the same under a microscope. Thickness is about the same. Density of the Amsoil and M1 are the same with the Toyo Roki about 25% lighter.
My pressure drop measurements aren’t repeatable but it indicates the Amsoil and M1 media are about the same and the Toyo Roki is about 1/3 of them (on a square inch basis).
My conclusion is that the Amsoil filter is not something I’d ever use on my bikes or cars. Dirt in the filter is unaceptable. The small filter media with the high pressure drop can only cause the filter to bypass oil more often.
I had doubts about using the M1-110 on my bike because it’s filter media area is less than the OEM and it has higher a pressure drop. The Amsoil filter is would be a worse choice.
First impression:
