Happy Birthday Merkava_4
by Trav
05/03/16 04:56 PM
When should you use grease with moly?
by Jetstreamz06
05/03/16 04:54 PM
VOA Motul 4100 Power 15W50
by GermanAutohaus
05/03/16 04:31 PM
Ace Hardware Pennzoil Yellow May 4th to 9th $2.99
by BigD1
05/03/16 04:23 PM
How often to get tires balanced?
by 2010Civic
05/03/16 03:17 PM
Manual says every 10 K on oil changes
by ceast
05/03/16 02:42 PM
Brake fluid ageing?
by LucasDK
05/03/16 02:39 PM
If Anybody has 60K Lying around
by GumbyJarvis
05/03/16 02:03 PM
144$ lot of 48 Fl-400s/L20195 Eq Filters
by GumbyJarvis
05/03/16 01:29 PM
AT Whine
by DWC28
05/03/16 01:14 PM
GM AutoTrak II fluid
by nthach
05/03/16 12:49 PM
GM 2500HD 75w-90 or 75w-110
by Stewart Fan
05/03/16 12:03 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
85 registered (ag_ghost, 2015_PSD, 69GTX, 2oldtommy, 901Memphis, 12 invisible), 1807 Guests and 270 Spiders online.
57779 Members
66 Forums
248418 Topics
Page 1 of 3 1 2 3 >
#3099521 - 08/19/13 11:31 AM Micron filter rating for NAPA Platinum oil filter
Pajero Offline
Loc: Rio Rancho, NM
Good day!
Does anyone know what the filtration micron rating for the NAPA Platinum? Not how much it holds, but at what level can it filter out particulates? I did a quick google, but found 70 microns, that doesn't seem accurate....thanks in adavnce.
Pajero
#3099525 - 08/19/13 11:50 AM Re: Micron filter rating for NAPA Platinum oil filter [Re: Pajero]
doitmyself Offline
Loc: MI
A recent discussion of this resulted in no definitive answers.
I recently e-mailed WIX and asked why many of the Platinums are rated at B2=20 and their reply was:
"I would love to clear this up over a phone call. Please give us a call at 1-800-949-6698 between the hours of 8am 5pm Eastern time, Mon Fri."
I will defer the phone call to someone else here that has better knowledge of Beta ratios etc..
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#3099608 - 08/19/13 01:30 PM Re: Micron filter rating for NAPA Platinum oil filter [Re: Pajero]
Oregoonian Offline
Loc: Bend, Oregon
Instead of a WIX Plat....may I suggest the Fram ULTRA, a top-tier filter and a 'best buy' of any long OCI filters available....with an excellent micron rateing to boot. It is well liked on this website, and good for up to 15K OCI's.
If your OCI's are in the 7500 range, you can use it for two OCI's (i.e. 2 X )7500. That what I'll be doing.
Its hard to beat at only $8.97 at WalMart.
03' Ford Focus SE(2.3L Duratec PZEV)/ 135K +
QSUD 0w20 / Fram 'Ultra'/ OCI: 7500 +/-
ATF: Mercon V w/Lubegard Red
#3099619 - 08/19/13 01:42 PM Re: Micron filter rating for NAPA Platinum oil filter [Re: Pajero]
OneEyeJack Offline
Loc: S California
In the real world how can you tell which full flow oil filter is the best for your application? Answer? Difficult, maybe impossible. No one knows the long term effects of using one filter over another. You can make a guess by looking at the inside and the quality of materials and construction. You can start doing UOA's and watch for trends or big problems. There is one way to clean the oil and start over at your original baseline, change the oil. Beyond that there may be no difference in oil filters if you stick to a filter with quality construction and material and leave it at that. With this in mind and a list of qualified filters the best one would be the one on sale.
#3099762 - 08/19/13 04:31 PM Re: Micron filter rating for NAPA Platinum oil filter [Re: Pajero]
atoalson Offline
Loc: Missouri
I would love to know the efficency of the Platinum/XP filter as well. It's hard to beleive it's not published somewhere frown
2011 RAM 2500. 6.7L CTD.
#3100071 - 08/19/13 09:41 PM Re: Micron filter rating for NAPA Platinum oil filter [Re: doitmyself]
ZeeOSix Offline
Loc: PNW
I recently e-mailed WIX and asked why many of the Platinums are rated at B2=20 ...
That's only 50% @ 20 microns. Yeah, hard to believe that, but again the Toyota OEM filters are about the same @ 51%. shocked
#3100182 - 08/20/13 04:04 AM Re: Micron filter rating for NAPA Platinum oil filter [Re: doitmyself]
dnewton3 Offline
Loc: Indianapolis, IN
"I would love to clear this up over a phone call. Please give us a call at 1-800-949-6698 between the hours of 8am – 5pm Eastern time, Mon – Fri."
I'll give it a try today ... would love to hear what they have to say.
In the past, when I've emailed and called, and got deep into the conversations, I've typically found the "tech" on the other end having a lack of knowledge and ability to understand the details. I have been very disappointed by Wix "tech" line people over the last few years. All they do is give boiler-plate rhetoric and don't lend themselves to intelligent conversation. But perhaps they've taken a new approach? It cannot be any worse than the white-wash approach of "Beta 2/20=6/20" on nearly every filter now.
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3100194 - 08/20/13 04:39 AM Re: Micron filter rating for NAPA Platinum oil filter [Re: dnewton3]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Nice double post, Dave. wink
Nonetheless, I think that's the unfortunate result of trying to discuss technical matters with customer service representatives. Someone making barely above minimum wage is not going to understand beta ratios whatsoever. Your mathematical knowledge would probably appear akin to sorcery to them. It's no different than every call to the satellite or internet company - just reboot the system and it'll be fine, or reboot your computer, or modem, or router; or, alternatively, you shouldn't have rebooted anything because now I can't diagnose the problem. smile
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3100454 - 08/20/13 11:31 AM Re: Micron filter rating for NAPA Platinum oil filter [Re: Pajero]
dnewton3 Offline
I just got off the phone with Wix; here is what they told me ...
The XP filters are 50% beta at 20 micron. I asked if that was a typo; I was told "They are made for use with synthetic oils and harsh driving conditions."
To which I replied: "Is there someone that can speak with me about the reason such an expensive premium filter is so poor at filtering?"
And the answer I got was "Sir, this is the best filter we offer. It is made for use with synthetic fluids and harsh driving conditions." (As I heard her typing in the background, searching for the answers ...)
I said "Most of your filters are rated B2/20=6/20; that would make a normal filter much more efficient at it's primary job of filtering. Why would I want to use a filter that is rated so poorly?"
The answer I got (you guessed it ...)
"The XP is specifically intended for use with synthetic fluids and harsh driving conditions."
I asked: Should I only use a normal filter with normal oil and an XP with synthetics? She said (after more typing was heard) ... "You can use any of our filters with any oils."
I retorted: If I can use any filter with any oil, they why would I pay for much poorer performance in a premium filter. Are you sure that's not a typo?
"Our XP is specially made for use with synthetic fluids and harsh driving conditions."
Seriously - someone else should call and see if I was having a nightmare or what ...
I have my doubts that the XP is that poor at 20 micron (50%), but if it is true, then I'd NEVER use one.
Sad, sad state of affaris at Wix nowdays. They used to be helpful and informational; they've become worthless in consumer information sharing. They are set up for mass-market canned answers and cannot get past the rhetoric. In all honesty, it's not that they don't make good stuff, but if this is the kind of bovine poo they are going to push on me, then I will continue to shop for alternatives at cheaper prices. They simply are not "good enough" for me to be loyal to such condescending dribble.
After a few minutes I called back, and specifically asked for a person that could answer techical questions and not read off boilerplate computer screen data; I was transferred to another desk, and was able to leave a VM for the person (with an undistinguishable name on the VM header).
Stay tuned ...
Edited by dnewton3 (08/20/13 11:37 AM)
#3100584 - 08/20/13 02:21 PM Re: Micron filter rating for NAPA Platinum oil filter [Re: Pajero]
edwardh1 Offline
Loc: Coastal South Carolina
does the fram ulltra have the cardboard end caps too?
I know women who are always late, they do not allow travel time, they think like Star trek, you leave one place and materialize somewhere else.
#3100613 - 08/20/13 02:48 PM Re: Micron filter rating for NAPA Platinum oil filter [Re: edwardh1]
ZeeOSix Offline
Loc: PNW
No, it's the only FRAM that has metal end caps. Good filter, many here rave good things about the Ultra.
http://fram.com/products/oil_filters/fram_ultra_oil_filter/index.asp
#3100618 - 08/20/13 02:50 PM Re: Micron filter rating for NAPA Platinum oil filter [Re: dnewton3]
ZeeOSix Offline
Loc: PNW
I think they must have a Stepford wife working there that needs some reprogramming. crazy
Well, at least that was a decent answer.
#3100622 - 08/20/13 02:54 PM Re: Micron filter rating for NAPA Platinum oil filter [Re: dnewton3]
Jim Allen Offline
Loc: NW Ohio
Depressing but not unexpected. I'd have called long before.... but I kinda knew.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#3100709 - 08/20/13 04:09 PM Re: Micron filter rating for NAPA Platinum oil filter [Re: Pajero]
atoalson Offline
Loc: Missouri
My local O'reillys rep came by today, he's actually a really sharp guy. I asked him to find out about the WIX XP effeciency, he instantly grabbed his cell phone and spoke to the WIX rep he works with. WIX rep said to text him the filter # and he would get back with the info. We'll see what happens. I have faith in Dan(O'reillys.
#3100727 - 08/20/13 04:29 PM Re: Micron filter rating for NAPA Platinum oil filter [Re: Pajero]
danthaman1980 Offline
Loc: SE Wisconsin
Sad, sad, sad. Wix/Napa Gold was my go-to filter for many years. I liked the fact that Wix only put their name on ONE line of QUALITY filters and didn't succumb to the 'good, better, best' marketing bu!!$hit. Now, sadly, they have a 'premium' product and can't even tell us why it is better than their standard product. I just bought two of these (Napa Platinums) and I won't use 'em if they're nothing but rock catchers.
C'mon Wix, I'm waiting for an explanation...
2003 Chevy Silverado 1500 5.3 LS Quadrasteer ~223,000 miles; PU 5W-30
2014 Mazda6 Sport 2.5 Skyactiv ~31,000 miles; PP 0W-20
Page 1 of 3 1 2 3 >
