Here you go folks, a comparison between the very similar TG 7317 and A02.
Same base plate except for the "P" gasket on the Honda
The Honda ADBV (on top) is thinner than the TG. The TG ADBV left an impression on the endcap whereas the Honda ADBV leaves no impression at all.
Comparison...the media on the TG is a little wavy and the pleat spacing is not as even. Honda has 49 pleats including the crimped seam and the TG has 48 including the glued seam. The endcaps are thicker on the Honda, not sure what difference this makes.
The bypass valves are constructed the same, no more screen on the TG. The Honda bypass did seem to require less pressure to open. The TG was harder to push open, but not by much.
Media of the TG is thinner and a little more firm.
Media of the Honda is thicker and not as firm.
Honda
TG
After checking out the TG and seeing how similar it is to the Honda, Ill probably run 1 to see how it works out (after I run the other 2 Honda A02's I have).
Honda
TG
